Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 95+ Gen Toyota Trucks
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
95+ Gen Toyota Trucks Covering the later Tacoma, 3rd Gen 4Runner, T100, Tundra, Sequoia, Highlander and other 4WD Toyota rigs
Thread Tools Display Modes
Old 11-13-10, 08:12 AM   #1
SBFJ60FIG
3.4 Timing belt tensioner compression-need some help!!
Hey all,
I'm doing a t-belt as we speak. I got the Schlay tool to compress the tensioner. I did not seen to find the spot for the locking pin to fit into so I removed the compression tool. Well, now the the tensioner does not seem to be returning to tension...it seems to be stuck compressed?
Anyone seen this? If I remember correctly, the tensioner's function is not linked to oil pressure or the engine running.
More succinctly, can you compress the tensioner too far and get it stuck...or is this just a function of this truck having like 250k miles on it and that it will pop out soon enough?
Thanks in advance for the assistance all.
'97 LX-450-TRD Supercharger sitting on the garage floor...moved it to the basement! Gotta get to work on that I/C and hood scoop!
'87 FJ60, 350, NV4500, EFI, SOLD July '08, Happily hitting trails in S/W Colorado now!
'96 civic EX 4DR 5SP 30+ mpg all day long!
SBFJ60FIG is offline   Reply With Quote
Old 11-13-10, 10:31 AM   #2
mmml4
mmml4's Avatar
Garage
IIRC it is operated by oil pressure. One reason I say that is when you compress it, it forces the oil out very slowly. If it were a spring you could compress it quickly.
99 4runner SR5, leather, 3.4, auto, 2wd to 4wd, SAS using 80 series LC axles
My Build http://www.toyota-4runner.org/3rd-ge...ild-build.html
mmml4 is offline   Reply With Quote
Sponsor 11-13-10, 03:01 PM
Sponsored Link
advertisement
Old 11-13-10, 03:01 PM   #3
ken_79-fj40
Addict
ken_79-fj40's Avatar
If it's got 250k on it why not just replace the tensioner? I change it every time I do the belt. They come with a locking pin in them already. Bolt it on, take out the pin, and it tensions the belt. IIRC the tensioner wasn't much more than the tool.
79 FJ40,89 325is,96 Tacoma,89 pickup,84 Capri RS
ken_79-fj40 is offline   Reply With Quote
Old 11-15-10, 04:55 AM   #4
SBFJ60FIG
For one, I don't like to replace parts that are still good. Very often people put new parts on just because. Example the thermostat, probably the MOST replaced part that is almost all the time still good...to a lesser degree a water pump. If you need to take a ton of stuff off to get to the part (water pump) and you're replacing the timing belt anyway sure. But the if the tensioner is perfectly functional and good for the life of the engine and more...therefore, I would not replace it.
I took some detailed photographs of what the issue was with this tensoner which I'd imagine I'm far from the only person who has had this problem...I'll post them later with an explanation.
Also, since it has 250k on it, I don't want to take the AC compressor or anything else off that I don't have to. This thing is a rusty, broken bolt kinda car. Everything took a lot longer than it should have to complete...like 3x as long! It kind of sucked.
Old 11-15-10, 05:11 AM   #5
Blue77FJ40
Addict
Blue77FJ40's Avatar
If the vehicle is that rusty, you should become acquainted with the best penetrant on the market, Kroil.
'77 FJ40: HFS, 33's, Locked and Low'd
'04 Taco XCab, bone stock
Blue77FJ40 is offline   Reply With Quote
Old 11-15-10, 07:53 AM   #6
SBFJ60FIG
Have to check it out...had the truck for awhile, so I was able to SOAK and I mean soak many of the crusty parts with a mix of PD blaster and plain old engine oil for days on end. Didn't do shit. The little washer in between the AC idler pulley and the bracket it mounts to, the big washer sort of thing was so rusted on that I actually broke the adjuster bolt while turning it to loosen it up. The pulley would not adjust at ALL. Finally got it apart and go the rest of the bolt on, sanded it and now the adjuster works just fine.
In my experience, I just soak stuff with engine oil and hope for the best. Rust really makes a car hard to work on. Ten minute jobs become two to three hours.
Old 11-16-10, 12:41 AM   #7
cruisertom
cruisertom's Avatar
If I remember correctly you compress it still mounted and I just used a small allen wrench to keep it compressed then unbolt it. As far as the Tstat I have had them fail after a coolant flush, and other work assoc. with the coolant system. Sometimes they just fail and the bad thing is when they fail closed. Think of it as preventive maintenence.
cruisertom is offline   Reply With Quote
Old 11-16-10, 06:33 PM   #8
zetasig
Addict
zetasig's Avatar
That is an oil compression type of tensioner and should return back up to its normal position in a few minutes once the tensioner tool is removed. I have the same tool and mine worked fine, after many broken bolts, a can of PB Blaster, and two days of soaking everything.
Love road salt.
1970 FJ-40 , SOLD
'97 4Runner bone stock.
'00 4Runner, 33s, TJM, Snorkle, Sliders, courtesy of the PO
'08 Sienna with 13 cup holders
Work harder, millions on welfare depend on you.
zetasig is offline   Reply With Quote
Old 11-17-10, 09:40 AM
Sponsored Link
advertisement
Old 11-17-10, 09:40 AM   #9
SBFJ60FIG
Yes, it does have fluid in it...thanks...the issue was complicated, but as simplified as I can get, the pin the pushes against the pulley bracket was rotated slightly. Thus, once compressed the pin would NOT go into it. I thought it was not compressed far enough, push a little harder and cracked the pulley.
After installing the new pulley, I grabbed the pin with pliers, twisted it, and then compressed it and the pin would then lock it in place. I took detailed pictures of the little pin thing and will post them later to help any others who experience this issue. I compressed it 5 or 6 times and the pin would not lock it. Only after I broke it did I wise up and twist it.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
