Well It's time I finally got around to putting my build thread on a bit more accessible site. I've been doing a SAS on my 1998 toyota 4runner. I started the build at the end of August and was able to work on it for a good week before I had to head up to New Brunswick for School. Since then I've been going home on weekends to work on it so it's been painfully slow since September.
Here's what I'm working with:
1998 Toyota 4runner Limited 180k miles, 3.4L stock 4.30 gear ratio.
Goodyear wrangler RT/II's 36x12.5x16.5 bias ply
Axle's going in:
1997 FZJ80 Elocked axles w/ 80k miles on them, picked up for 300 bucks courtesy of cash for clunkers.
Trans and manual tcase:
1996 T100 auto with passenger side drop tcase from same junk yard for 200 bucks.
Other parts i ordered and who i got them from are as follows:
Ballistic Fabrication:
Frame reinforcement plates p# TOY-1308
Adjustable coil buckets p# BRK-1049
Sky Manufacturing:
Tacoma oil pan conversion kit p# Taco-SAOK-001
(has 2wd t100 pan and all other pieces needed)
Weld in treaded tube inserts for fj80 TRE's
PSC:
high and low pressure hoses and field serviceable fittings for stock toyota power steering pump to fj80 steering box
Camel4x4:
1 set fj80 front 4" lift springs
1 set fj80 front HD stock height springs (for rear of 4runner)
1 set fj80 extended break lines
1 set fj80 adjustable caster bushings 0 to 3.5 degrees
Trail-Gear:
pair of fj80 tie rod ends, one left one right for drag link
Stuff i still need:
Shocks, I will be making extensions for the rear shocks for the time being till i can save up some money again and get new ones. Front I'm considering Bilstein 5150's but don't know what length yet
Shock towers, I will most likely be using the mid 80's ford shock tower which mmml4 used in his build, i'll get the part number and post it up when i remember.
lengthened front drive shaft
4.88 gears, will come next spring hopefully once i get funds back up
oh yeah a little disclaimer, this is temporary to get me through the winter here in jersey, next summer i will be doing a 3link on the truck, just right now i dont have the extra funds for the extra material and it needed something since the trans was going bad.
I will post up pictures of the build in a little bit when i get home to my desktop
Axle's going in:
Sky Manufacturing:
PSC:
Camel4x4:
Trail-Gear:
Stuff i still need:
