Go Back   IH8MUD.com > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 11-07-09, 04:35 PM   #1 (permalink)
simpletallman's Avatar
Garage
Coilover Adjustment & Alignment
Ok, so lifted my 4runner up front with some adjustable King coilovers about a month ago. They were adjusted for about 1.5" of lift. Wanted about 2" total lift, so I cranked them up a bit with a spanner wrench that Darren over at Twizted Engineering in Broomfield made for me.
It was a BITCH! Jacked up at crossmember to relieve some load on the springs and cranked away. I have seen advice that said to use two cuttoff screwdrivers or rods to insert into the adjustment holes and twist with that, but it wouldn't budge. I got them to turn with the wrench, but with the 4runner upper mount in the way, it was not easy. Kinda mucked up the adjuster on the coilover.
Any advice for a better way? Obviously, could take them off to adjust, but off... adjust... on... check height.... off again... and repeat. Would suck. I would say that getting coilovers with the adjustment on the bottom would have been best. Or maybe drilling more adjustment holes into the adjuster... dam... maybe that would have been best. There are only three, so getting to the next one without interference after 1/3 turn, was tight. Had there been six... maybe easier. What do ya think?
Next up: I noticed the tires have started wearing unevenly; worn more on outside than inside (too much positive camber). So... being that tires are on their last leg and I'm too broke at the moment for new ones, I decided to try my hand at adjusting the alignment a bit and save money for a real alignment until I can afford new tires. All I did was move the cams on the bottom control arm out one notch each, thus moving the positive camber more towards the negative.
I had never done this before, so I don't know the relationship between one notch on the cam and how much lower control arm adjust. I figure unless I overshot the mark (0 degrees camber), it will be an improvement over my existing condition, and if I don't notice my tire wear evening out, I can go one more notch.
Any comments, advice, suggestions?
1996 4runner Limited - retrofitted E-locker, manual hubs, front King Coilover 2.5" lift, rear Landcruiser 3.5" lift, drop panhard bracket, Tundra brake conversion, 2000 4runner center console/e-brake conversion, K&N air intake, throttle body spacer.
simpletallman is offline   Reply With Quote
Old 11-14-09, 08:52 AM   #2 (permalink)
Rookie
I have about 6 holes on my adjusting collar, which is easier, to find a hole with the wrench. When I adjusted mine I had to use a 2' cheater bar on the end of the spanner wrench. The only other option would be to compress the spring and then adjust it, but the $250 or so for a decent coil compressor is not worth it unless you plan on adjusting the coilovers monthly.
As for you alignment, I'll take mine in for that.
flyingyogi is offline   Reply With Quote
Old 11-14-09, 12:46 PM   #3 (permalink)
Punching the clown
Bighead's Avatar
TLCA# 15114
Maybe a silly question but did you take out the set screw before cranking on the adjustment collar (if there is one)?
2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000
2004 Land Cruiser -- OME Medium | Slee Dual Battery
Bighead is online now   Reply With Quote
Old 11-14-09, 01:20 PM   #4 (permalink)
Garage
Yeah, loosened the set screw. I got them adjusted, it was just hard to get the wrench on square cuz of the top shock/coilover mount. I think adding some holes to the adjusting collar will solve the problem for next time. Appreciate the good suggestions.
Old 11-22-09, 10:09 AM   #5 (permalink)
Deer season!
bowyer2002's Avatar
TLCA# 19920
When I did my brothers and my C/Os adjustments not only did we take the entire load off the spring but we also greased the threads on the shock AND the spring face that the collar is rotating against - it made a lot of difference, reducing that additional friction. Just my .02 - good luck!
97' LX450 (WIFE'S) OEM CUPHOLDER, PHH, POWER ANTENNA FIXED & FRONT AXLE REBUILD.
01' TACOMA DBL CAB, LIFT, ARB, ARE SHELL, HI-LIFT, SLIDERS, CUSTOM REAR BUMPER, WINCH, 2" COILOVER SWAY-A-WAYS, GARMIN, ETC.
bowyer2002 is offline   Reply With Quote
