Go Back   IH8MUD™ Forums > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 01-06-05, 01:57 AM   #1
95 taco's starter contacts
Does the 95 tacoma with a 2.4 liter 4 banger have the same starter problem like the 80's do?
The one were you have to change the contacts and maybe the plunger.
My starter has started to click the first time I try the key. Maybe the second time I push in the clutch it will start.
If I turn the key with out pushing in the clutch it makes no noise.
So When I do push in the clutch I get the click on the drivers side were the starter is. I am thinking that I have the 80's starter problem.
What do you think?
Hope everybody Holidays were nice
loquito is offline   Reply With Quote
Old 01-06-05, 10:27 AM   #2
cruiseroutfit's Avatar
TLCA# 10662
Get some new contacts... ~$8 to fix it!
Kurt Williams
***Cruiser Outfitters*** - YOUR LC PARTS SOURCE!!!
Old Man Emu - ARB - Advance Adapters - Safari Snorkels
U4WDA - Historian
TLCA
Wasatch Cruisers
Mountain Yoats
Red Rock 4 Wheelers
Tacoma Territory
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 01-06-05, 11:36 AM   #3
keisur's Avatar
it's on all the starters, not just the 80's. the contacts just wear down after time and need replacing. goto 4CrawlerOffroad and you can order some from him.
keisur is offline   Reply With Quote
Old 01-07-05, 01:01 AM   #4
Thanks you guys, I'll be replacing them real soon.
Steven
Old 01-13-05, 01:45 AM   #5
Mark W's Avatar
TLCA# 6303
As mentioned above this is common to all of the Nippondenso gear reduction starters. Simple fix. You can get the contacts at Alaska Auto Electric in Anchorage. A couple of bucks a piece. Make sure you get the right contacts. The '95 taco starter uses on of the "old style contacts and one with an extended section. The older starters used two identical contacts with no extension.
Mark W is offline   Reply With Quote
Secured Loans | Web Advertising | Biker shirts shop | Loans | Loans
