Go Back   IH8MUD Forums > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 10-12-08, 11:50 AM   #1
TLCA# 18486
Help with '99 4Runner SAS
I am preparing for a SAS on my '99 4runner Ltd but want to stick with a Toyota axle. Also I want to keep the OEM rear axle. Is there anything toyota that matches up???
JLHEEPETR is offline   Reply With Quote
Old 10-12-08, 02:19 PM   #2
_Sgt. Sardonic_
LukeZero's Avatar
TLCA# 14442
79-85 mini truck front axle should be about the right width, let you keep 6 lug wheels, has disc brakes, etc.
EDIT: My information was not helpful- I completely overlooked the differential being on the wrong side. Sorry.
Originally Posted by Hank Hill View Post
I'm tryin' to stop this outbreak, and you're drivin' the monkey to the airport.
1998 4Runner Limited
1964 FJ45SWB SOA,SR,383SBC,SM465,NP203/205,ARBs,Longfield Inners & Outers,36"Swampers,Caged
Hoosier Cruisers
LukeZero is offline   Reply With Quote
Old 10-12-08, 08:18 PM   #3
toyminator's Avatar
TLCA# 17965
79-85 mini truck axles have a right side drop. 96 and up use a left side drop so you can't use one without heavy modifications to move the 3rd member to the other side. I've seen it done but its a lot of work. Besides, 79-85 front axles are only 55" wide and the 99 rear is about 61" wide.
Take a look at Diamond Axles. Diamond Axles - Welcome
They make axle housings virtually any way you want. You can use Toyota 3rds and outers or Toyota 3rds and D60 outers or whatever and they'll put the pumpkin on either side and cut it to any width you need.
1989 Toyota Pickup - 255,xxx miles, SAS, Bed Bobbed 14", 95 4Runner front clip, Hanemman Fiberglass front fenders, All Pro 5.5" lift, Hi Steer, 5.29 gear rear Detroit locker, front ARB locker.
1988 4Runner - Blown up 3.0 V6
1999 4Runner SR5 Sport Edition
1992 Lexus SC400
toyminator is offline   Reply With Quote
Old 10-13-08, 03:16 PM   #4
find a jeep grand wagoneer. they have a D44 up front with a driver drop, 6 lug, the width you need and are fairly cheap. the only way to keep it all toyota is to either switch out the transfer case with an adaptor and use a LC or mini truck front end (lots of work) or have a stock toyota axle built which is stupid since you can build up a D60 for what that would cost.
slow95z is offline   Reply With Quote
Old 10-18-08, 04:18 PM   #5
Can you do a doubler then use a rear t-case with a passenger side diff? Could put a 80 series front axle up front with that set up. Won't an 80 series t-case bolt up? They should be the same transmission in the later model 80 series, but you'd have to use both landcruiser axles.
jetboy,
75-40
Jetboy is offline   Reply With Quote
Old 10-28-08, 02:03 AM   #6
TLCA# 14737
Sheesh. Sure you can. Just get a T100 xfer case from a 3.4 T100. You'll need the T100 oil pan too to clear the mini truck axle. You'll also need a widening kit. Brakes won't be as good from the toy mini axle though.
Also google 44runner if you want to swap US iron.
Lars
TLCA #14737
www.GoldCoastCruisers.com
larsdennert is offline   Reply With Quote
Old 10-28-08, 07:33 AM   #7
toyminator's Avatar
TLCA# 17965
An 80 Series transfer case uses offset/offset outputs and I think your fuel tank may be in the way of the driveshaft. You can check out Inchwrom gear. I think they make an adapter to use older right side drop transfer cases on your transmission.
1992 Lexus SC400
Old 10-28-08, 10:10 AM   #8
just go with the D44, thats the best option out there and plenty of info on ttora about it.
Old 11-05-08, 07:44 PM   #9
Spread the H8
TEPUI's Avatar
I've seen it done with a Toyota axle, but you'll spend more time fixing stuff than wheeling it.
Go with the ultra proven Dana44 setup.
Steve at Sonoran Steel is your friend. Sonoran Steel Custom Metal Fabrication L.L.C.
'97 トヨタRZJ90
Get your Land Cruiser T-Shirts, Hats, Stickers here!
TEPUI is offline   Reply With Quote
Loans | Bad Credit Mortgages | Cheapest mobile phones | Loans | Credit Cards
