brakes?
I just got a 98 4runner limited and seems one of the rear breaks is draging and every now and then you can hear it but then the sound goes away but comes back. somtimes the "brake" light on the dash will go on and then go off like you pulled the E brake???
any ideas??? Thanks!! __________________ My weekend friends love Top Gun... (Gay yes I know) http://www.youtube.com/watch?v=xHklGtW3rwU build thread http://forum.ih8mud.com/40-55-series...r-builder.html Last edited by LukeZero; 08-31-08 at 10:28 AM. |
frozen caliper
for sure coming from rear... so those are drums....
__________________ My weekend friends love Top Gun... (Gay yes I know) http://www.youtube.com/watch?v=xHklGtW3rwU build thread http://forum.ih8mud.com/40-55-series...r-builder.html |
Sounds like your e-brake is not fully releasing (maybe needs adjustment), which would also explain why your brake light is coming on. There's an adjustment nut under the driver's side, also check the rear drum to see if the lever is releasing, maybe a kink in the line?
__________________ '01 Tacoma dbl cab trd, fabbed rear tire carrier, ARB bumper, sliders and cup holders. |
#5 | |
parking brake lever engaged low fluid in resiviour. mis adjustment has no effect on the light. |
#6 | |
Ludwig van Crunkthoven
Pull off your drum and see if your missing (rolling around) a hold down spring for the brake shoes. Fairly common and allows the shoe to over adjust itself causing your complaint. Check them out. __________________ It makes me wonder if the word of god is lost in the man This is for the children of Iraq, lost in the sand This is for the illest emcees that'll never be known And this is for all the soliders that'll never come home |
thank you guys!!!
It does if there is brake drag (first sentence!), hence the "out of adjustment". It's in the FSM (section BR-6 & BR-8), and it will activate the light. I assumed he wouldn't ask the question if he didn't first check the brake fluid level in the resevoir.
#9 | |
I believe what you are telling me. word for word, what does the FSM say? |
#10 |
well I did redo the front and rear brakes... the ebrake stuff was stuck but the front brakes were also very bad so got it all done... stops like a champ and no brake drag... :-)
thanks again guys!! __________________ My weekend friends love Top Gun... (Gay yes I know) http://www.youtube.com/watch?v=xHklGtW3rwU build thread http://forum.ih8mud.com/40-55-series...r-builder.html |
#11 |
Guess same way it determines if the e-brake lever is pulled a click or two (as I'm not an engineer). I just know what has worked for me, and what others have determined on their 4rnrs, and the FSM lists that as a step to check when troubleshooting. But his is fixed now, so good for you apeterson!
#12 |
The brake light will not come on if the rears are dragging. The adjuster on my drivers rear went nuts and pushed the shoes so far out the tire could barely move. No light during that entire mess.
Ended up having to replace all the shoes, hardware and hammering a tab back into place that retains the lower (6 o'clock) part of the shoes. My guess is that your return spring for the e-brake is messed up. __________________ 1997 4x4 4runner / Budbuilt Skids / Homemade front&rear bumper / Stubbs Sliders / E-Locker / Icom Radio (KE7MWX) |
#13 | |
#14 |
The bias valve has a switch that senses unequal pressure between the front and rear brake circuits. If the brakes are massively out of the adjustment, have air in them, leaking or other such malidy the pressure differential will trip the sensor.
A shame I didn't see this earlier or I would have recommended you upgrade to the Tundra brakes to prevent warping in the future. |
#15 | |
Yahoo Personals | The eBay Song | Advertising | Credit Cards | Proxy |
