Go Back   IH8MUD™ Forums > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 05-20-08, 05:33 PM   #1
Tires pressure and Tranny fluid rec.
I have the OEM 17s on my 04 Sequoia. My tires indicated 40 psi, while the sticker on the inside of the rig stated " 32 psi" all the way around.
I have 60K on the Sequoia and wanted to change the tranny fluid. I bought 2 qts of OEM type 4 fluid. Should I change it now. Im ready for a long trip to FL in the summer with my family. Just worry
where are you hurting?
DocLX450 is offline   Reply With Quote
Old 05-21-08, 05:54 PM   #2
_Sgt. Sardonic_
LukeZero's Avatar
TLCA# 14442
The door sticker is what Toyota wants to see- the tire label is "maximum pressure" probably not the recommended pressure specifically for your vehicle. When the tires are designed and manufactured- the manufacturer states a "not to exceed" number, how could the tire manufacturer know which vehicle their rubber would end up on?
As far as ATF- I believe the recommended interval for flush & fills is 60K miles. 2 quarts isn't going to do it- try like 10-12 (if you can flush out the torque converter) if not, then subtract 4.
Best wishes, Luke
Originally Posted by Hank Hill View Post
I'm tryin' to stop this outbreak, and you're drivin' the monkey to the airport.
1998 4Runner Limited
1964 FJ45SWB SOA,SR,383SBC,SM465,NP203/205,ARBs,Longfield Inners & Outers,36"Swampers,Caged
Hoosier Cruisers
LukeZero is offline   Reply With Quote
Old 05-21-08, 09:56 PM   #3
thanks,
I read the manual, it indicated 2 US quarts. I even ask the tech, he indicated 3.
It just drain the bolt and refills.
Old 05-22-08, 05:43 AM   #4
_Sgt. Sardonic_
LukeZero's Avatar
TLCA# 14442
2 quarts will drain the pan, which is not all bad. A complete flush and fill, done with power machine, will replace all the fluid, in total will be 10-12.
Hoosier Cruisers
SEO Friendly Directory | Remortgages | Secured Loans | Best Credit Cards | Novela cuerpo deseo
