Go Back   IH8MUD™ Forums > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 05-20-08, 05:33 PM   #1
DocLX450 is on a distinguished road
Tires pressure and Tranny fluid rec.
I have the OEM 17s on my 04 Sequoia. My tires indicated 40 psi, while the sticker on the inside of the rig stated " 32 psi" all the way around.
I have 60K on the Sequoia and wanted to change the tranny fluid. I bought 2 qts of OEM type 4 fluid. Should I change it now. Im ready for a long trip to FL in the summer with my family. Just worry
where are you hurting?
DocLX450 is offline   Reply With Quote
Old 05-21-08, 05:54 PM   #2
___Pastafarian___
LukeZero's Avatar
TLCA# 14442
LukeZero is an unknown quantity at this point
The door sticker is what Toyota wants to see- the tire label is "maximum pressure" probably not the recommended pressure specifically for your vehicle. When the tires are designed and manufactured- the manufacturer states a "not to exceed" number, how could the tire manufacturer know which vehicle their rubber would end up on?
As far as ATF- I believe the recommended interval for flush & fills is 60K miles. 2 quarts isn't going to do it- try like 10-12 (if you can flush out the torque converter) if not, then subtract 4.
Best wishes, Luke
I'm kinda' like Han Solo; always strokin' my own Wookie.
1998 4Runner Limited
1964 FJ45SWB
Hoosier Cruisers
LukeZero is offline   Reply With Quote
Old 05-21-08, 09:56 PM   #3
thanks,
I read the manual, it indicated 2 US quarts. I even ask the tech, he indicated 3.
It just drain the bolt and refills.
Old 05-22-08, 05:43 AM   #4
___Pastafarian___
LukeZero's Avatar
TLCA# 14442
2 quarts will drain the pan, which is not all bad. A complete flush and fill, done with power machine, will replace all the fluid, in total will be 10-12.
1964 FJ45SWB
Hoosier Cruisers
Loans | Credit Cards | Online Advertising | Loans | Fantasy Football Experts
