Go Back   IH8MUD™ Forums > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 05-17-08, 11:51 AM   #1
94landcruiser's Avatar
Toyota Announces Customer Support Program EXTENDED TO 15 YEARS!
http://www.toyota.com/pdfs/TacomaCus...ortProgram.pdf
TORRANCE, Calif., March 7, 2008 – Toyota Motor Sales (TMS) U.S.A., Inc. will launch
a Customer Support Program to extend warranty coverage on certain 1995 through 2000 model
year Tacoma truck frames.
Toyota has received reports regarding a small number of Tacoma vehicles exhibiting
excessive corrosion of the frame, causing perforation of the metal. The frames of some vehicles
may not have adequate corrosion protection. When exposed to severe environmental conditions,
including accumulation of road salts, these vehicles may develop corrosion beyond normal
surface rust commonly found on metal after years of exposure.
Instances of this condition are isolated and largely confined to states which use salt for
winter de-icing of roads. However, to assure customers of its commitment to satisfaction, Toyota
is extending a rust perforation warranty covering 1995 to 2000 Tacoma truck frames for a period
of 15 years from original sale, with no mileage limitation, for corrosion damage resulting in
perforation of the frame material.
Should a customer’s vehicle experience this condition, they will be requested to present
it to any Toyota dealer for inspection. Upon confirmation of rust perforation, Toyota will, at its
option, repair or repurchase the vehicle. If it is determined that no rust perforation is present, the
extended warranty will be in effect for 15 years from original sale.
It is important to note that this is not a recall or special service campaign. The extended
frame corrosion warranty provides goodwill assistance to owners who have experienced, or may
encounter, frame problems as a direct result of rust perforation. Owners will be notified by first
class mail beginning mid-March 2008. Customers with questions or concerns should contact the
Toyota Customer Experience Center at 1-800-331-4331
Toyota Tacoma Frame Rust - Tacoma World Forums
ARB Bullbar, Front OME 850J Rear Custom Slee springs approx.10% stiffer than OME 863 pin 7 mod & CDL, Kenwood DVD/Garmin NAV, Power inverter, auxfan, rt temp gauge mod & a bunch of other things……
94landcruiser is offline   Reply With Quote
Old 09-26-08, 06:55 AM   #2
FlatlandTRD's Avatar
TLCA# 17,033
Toyota extends rust warranty on older Tacoma pickups to 15 years
Most are already aware, but here's some additional..
Dealer Communication Letter (From Toyota Corp to all Dealers)
http://www.showstop.org/images/truck...munication.pdf
Warranty Policy Bulletin #POL08-03 (Details about what is covered and VIN ranges)
http://www.showstop.org/images/truck...nty-policy.pdf
Vehicle Inspection Procedure
http://www.showstop.org/images/truck...inspection.pdf
FYI, there have been some '01-04 models in the current buy back, those are rated at KBB Excellent, whereas the previous models are KBB + 150%. All this is thanks to Dana Corp.
'01 Tacoma dbl cab trd, fabbed rear tire carrier, ARB bumper, sliders and cup holders.
FlatlandTRD is offline   Reply With Quote
Advertising Forum | Bleach Anime Forums | WoW Gold | Loan | Credit
