Oil Plug 2002 Tacoma
I just changed my oil on my truck. I tightened everything up, no leaks....The next day I find a 3-4 inch puddle of oil under my oil plug....So I re-tighten the plug.
My Question: Did the plug on the 2002 tacoma 4wd V6 3.4 come with a oil plug washer? Cause I didnt see it when I removed it, I hope I didnt lose it..... THANKS |
Every car I've worked on had a washer. I would get a washer ASAP. Good luck with that messy project!
![]() Also, are you sure that is where it's leaking from? Check your oil filter, too, and make sure the gasket is in place and sealed properly. __________________ 2001 Tacoma DC TRD Off-Road |
Tricking my truck
My '01 V6 has a washer.
I 2nd checking the source of your leak! Good luck! __________________ 97' LX450 (WIFE'S) OEM CUPHOLDER, PHH, POWER ANTENNA FIXED & RECENT FRONT AXLE REBUILD! 01' TACOMA DBL CAB, LIFT, ARB, ARE SHELL, HI-LIFT, SLIDERS, WINCH, ETC. ORDERED & WAITING ON SNORKEL..... |
My 2002 has a washer.
__________________ 1994 JDM Surf RHD 1995 FZJ80 - Factory Lockers, CDL switch and ARB bumper 2002 Tacoma Double Cab 4x4 TRD - National Springs Add-a-Leaf 1990 4x4 Short Bed Pickup - Farm Duty in the Ozarks Location - Okinawa, Japan |
Toyota part number 90430-12031 10 pack:Replace Pts>Filter Parts and Accessories for 2002 Toyota Tacoma
Jacque __________________ toyotatrailriders.com 96 TACOMA 06 TACOMA http://forum.ih8mud.com/tx-white-trash-elwood-chapter/ |
Thanks coonass for the link Just orderd washers....
All my Toyota engines have washers.
__________________ Noel 97 LX450 (lockers retro 50%), CDL, Pin 7, HIRs, Cup Holder, 100 pads, George's LEDs, OEM grab bar, sidemarkers, ARB winch bar, PIAA 520, 295/75R16 NTG, Kaymar Deluxe with tire carrier, Slee speedo gear, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter. Awaiting installation: OEM subtank, OME850J/863, slee SS brake lines, 3* blue bushings/caster plates, BIC 95300B dual batts. .... 94 4Runner, OEM 4.88 gear, V6 3VZE 04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, groucho sliders |
Loans | Advertising | TV News | Mortgages | Credit Cards |
