Go Back   IH8MUD™ Forums > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 02-13-08, 09:37 PM   #1
Kris's Avatar
97 T-100
I found a 97 T-100 with 150,00 and a 5speed. Besides the timing belt and the clutch what else goes wrong with these trucks at this kind of mileage? The guy wants $7200 but it hasn't had the timing belt changed or really anything at all except for the oil. I just don't want to walk into something that i'm going to have to dig out of later.
And I could super charge it.
88 4-Runner - Getting a makeover.
71 Fj-40 - Runs, Power Steering.
88 pickup - DD.
22rte - Done.
Kris is offline   Reply With Quote
Old 02-13-08, 11:16 PM   #2
KliersLC's Avatar
Those are great trucks. Have a look at the firewall where the clutch pedal attaches--it cracks there.
You can supercharge it, but the TRD system is definitely NOT bolt on. Unless you do some extensive fuel management mods, you will have problems with running lean.
Cheers!
Dan
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition
01 Sequoia Limited
02 Camry--Poor replacement for an 80
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
KliersLC is offline   Reply With Quote
Old 02-14-08, 08:07 AM   #3
bkg
Check for cracking around the passenger spring perch on the axle. Very common issue as well. Check the tailgate latch - they go bad (mine's bad) and are a PITA. Look for rust under the chrome wheel well trim on the box. Make sure it's had the relay rod recall completed.
Other than that, pretty solid. I just bought on on Sunday.
Brian K. Gallus
bkg is offline   Reply With Quote
Old 02-14-08, 07:46 PM   #4
Kris's Avatar
Would the cracked firewall rattle when driving at 2500-4000rpm? Because i noticed that on the test drive. Why do they crack there?
88 pickup - DD.
22rte - Done.
Old 02-15-08, 01:57 PM   #5
KliersLC's Avatar
The mount is just not as well designed as it could be. 10 minutes with a welder and it will never crack again.
The rattle is probably the exhaust shields on the crossover pipe behind the engine. No worries there.
01 Sequoia Limited
Send Money Online | Mobile Phone | Personal Loans | MPAA | Personal Loans
