Need a new Battery
Well I would like suggestions on a good battery for an 02 4Runner. I was going to go with an Optima but it does not fit unless I want to extend the battery cables. Any suggestions on something comparable to an Optima yellow or maybe red?
__________________ Last edited by atoyot; 12-23-07 at 07:04 PM. |
You can get Optimas w/ reversed terminals("R" series)...re-check the available products and you'll find them.
__________________ Pluton '91 4x4 regcab, 22re,4.56's w/ 31's, BudBuilt CM, Bilsteins, no REAL mods...no more 87 FJ60, or '85 FJ60. Santa Monica,CA |
Keep in mind with the optimas- they don't handle rapid charging. trickle only.
I've got an optima red top in my 40, and a small current leak somewhere in my headlight relay circuit. I went too long without starting it and it drained. I didn't want to wait a day to trickle charge it, so I set the charger to 75 amp for about a minute and fired it up. It started, but hasn't held a full charge since. Since then I've read posts from others on this board describing similar issues. Not necessarily a problem, just something to be aware of. __________________ 1968 FJ40 00 Tundra 4x4 08 FJ Cruiser 4x4 |
I just changed out my battery on my 02 4Runner with a Costco unit. It's got a 3 year warranty (if you know Costco, warranty issues are resolved with ease), and 100 month pro-rated warranty. Works fine for me. Cost was $60, IIRC. Starts up great, but I think I have to change out the starter contacts.
Draining any battery down competely will kill it - whether its a AGM or regular flooded battery. A deep cycle battery works better in this application.
Optima can be fast charged (75 Amp+) just as well as any flooded battery, as long as you keep the battery temperature under control and not burn it up. __________________ 97 LX450 - Plano, TX ARB winch bumper - triple lockers - center d/l switch - reclining mid/rear seats - HIRs - map/domes/doors/cargo/tail LEDs - crystal clear lights - aux fuse block - power outlets - lots of cupholders - PriorityStart! - Optima - exact mats - Waeco fridge - Sarmonprod.com xfer case cover To be installed: OME 851/852, Bilsteins, dual batteries w/Optima D31M, JDM condensor fan, JDM fog lights. "Today is yesterday's tomorrow" |
I assume from the initial post that you require the higher quality yellow top, right? If so, get the R version as Pluton suggested. If not, my suggestion is to find a comparable-to-stock battery that has a reasonable amount of warranty such as the Costco version.
__________________ 1996 4runner, 5 spd, factory rear locker, TRD coils, OME 890s, other stuff, 285 75r16 Firestone Destination MTs on L/C wheels, rest is stock..for now! |
i have a interstate mega-tron and love it
__________________ '99 Tacoma 3.4L v6 5spd. 4x4 SAW 2.0 Deaver AAL w/Bilstein 5125s 33x12.50R15" Baja Claws MIOR sliders all-pro bumper and skids Marlin Crawler rear bumper T-Max EW9000 lockrite-rear My Pics |
Credit Counseling | Car Loan | Broadband | Web Advertising | Motorbikes safer than horses |
