HopHeads, Unite!
4Runner Diff Lock Questions
Howdy--I'm researching 4Runners and have a couple questions regarding diff locks. I've been looking at some pics and have figured out that there's a diff lock diagram/light in the instrument cluster that definitely shows a center diff . . . but I've been reading on here about the rear diff lock dash switch--where is this located? A pic would be awesome!
I'm currently looking at 99-02 4Runners and have come to realize that some SR5s as well as Limiteds have at least a center diff lock, so I'd like to know exactly what I'm looking for regarding dash lights and switches... Any help is appreciated!! __________________ 1995 FZJ80 -- Factory Locked, 2.5+" OME w/ 850s and 863s, CC Plates, BFG AT LT 285/75R16, Extra stuff bolted on, replaced, inserted, thrown inside and put on top. "A world without open country would be an infinite prison." -Edward Abbey |
The center differential lock switch is just to the right of your light dimmer knob(left side near the steering wheel adjustment lever. when the center diff is locked, a yellow circle will illuminate in the
center of the 4X4 engaged light on your dash. __________________ 1987 FJ-60. Iron lift, 33x9.5 BFG AT's. 195,000 mi strong. 2000 Tacoma TRD locked/lifted & ARB'd for the High Sierras. 2001 4runner bone stock DD |
HopHeads, Unite!
Thanks!
Any beta on the Rear Diff Lock, too? This pic looks like it has, from Left to Right, a switch, the dimmer, and another switch. From what you say, the right-hand switch is the Center Diff. What would the left switch be?
I believe the left "switch" is actually an alarm LED light/glass break sensor. I had that in my old 98.
If you're looking for a Rear Diff Lock, you need to look for a 96-00 4Runner. In 2001, they did away with the Rear Diff Locker and put in the CDL. The switch location is the exact same spot on both. So, you either have a Rear Locker or CDL. It all depends on which you want. The benefits of a 01-02 are: 1) AWD system. Allows you to engage 4WD on dry pavement, unlike 96-00 (Except 99-00 Limited). 2) VSC system. (traction control). I installed a switch that turns this off. If you're in mud, snow, this system will not allow you to power your way through--it just cuts out power to "help" you avoid sliding. Install of the switch is simple, and the payoff (i.e. parking lot drift sessions) are well worth it. ![]() 3) TRAC system - allows the system to send power to the wheel with the most grip. Not as strong as lockers, but will get the job done in most cases. The new FJ's have this, along with the rear locker, which, IMO, is an awesome combo. You can always add a locker to the 01-02 4Runner, though. The benefits of a 99-00 are: 1) Rear Diff Locker. 2) Higher ground clearance for some 99 models. 3) Available 5-speed transmission. So if this will be more of a daily driver with some off-road fun, then I'd suggest going for an 01-02. If it'll be for a dedicated trail rig, go for a 96-00 with a Rear Locker. Personally, I've vote for a 02 Sport Edition. ![]()
HopHeads, Unite!
Thanks! That helps a lot!
The pic was from a local '01 with 60K on it . . . . I would definitely want the ability to kill VSC--sounds like the ASR system in my VW that I turn off most of the time. __________________ 1995 FZJ80 -- Factory Locked, 2.5+" OME w/ 850s and 863s, CC Plates, BFG AT LT 285/75R16, Extra stuff bolted on, replaced, inserted, thrown inside and put on top. "A world without open country would be an infinite prison." -Edward Abbey |
The switch turns off VSC, TRAC and ABS. I have a simple rocker switch installed (OEM aux light switch), but I want to swap it out for a push-button.
If you're interested, here is the write-up. Very straight forward. It'd probably take you half an hour. Disabling VSC & TRAC - 2001-2002 4Runner with VSC & TRAC Systems - YotaTech Forums Oh, and unless you're looking for a Limited, specifically, I'd opt for a Sport Edition. It has a better interior trim (aluminum look, sport seats), color-matched bumpers and flares, and the best part--hood scoop!
HopHeads, Unite!
Thanks again--nice truck BTW.
I don't think this would see any hardcore wheeling so I'd opt for newer and lower mileage over the OEM rear locker, I think. __________________ 1995 FZJ80 -- Factory Locked, 2.5+" OME w/ 850s and 863s, CC Plates, BFG AT LT 285/75R16, Extra stuff bolted on, replaced, inserted, thrown inside and put on top. "A world without open country would be an infinite prison." -Edward Abbey |
#8 | |
Good luck with the hunt. I'm on the hunt for a 95-97 80, myself.
#9 | |
HopHeads, Unite!
![]() Good luck! __________________ 1995 FZJ80 -- Factory Locked, 2.5+" OME w/ 850s and 863s, CC Plates, BFG AT LT 285/75R16, Extra stuff bolted on, replaced, inserted, thrown inside and put on top. "A world without open country would be an infinite prison." -Edward Abbey |
#10 |
The VSC and TRAC really proved beneficial for my Dad and I three Decembers ago in a blizzard on
I-80 outside of Laramie. Cars and semi-trucks all over the place. Out dash was lighting up like a christmas tree. This stuff really works and we were able to march on at a safe speed and to a safe place for the night. __________________ 1987 FJ-60. Iron lift, 33x9.5 BFG AT's. 195,000 mi strong. 2000 Tacoma TRD locked/lifted & ARB'd for the High Sierras. 2001 4runner bone stock DD |
#11 |
HopHeads, Unite!
I'm not denigrating the systems--they are great in most situations but in certain other situations, it is a blessing to have the ability to turn them off if necessary. I should have clarified that in my original response.
#12 | |
![]() But won't have that problem with mine. The VSC/TRAC off button was the first mod I did on the 4Runner. |
#13 |
^ I agree. 99% of the time, I want my electronic safety features on. But there's always times where I wish I could disengage the VSC and TRAC.
That rocker switch mod you posted above is great, but I wish there was a way to just disable the VSC and TRAC without disabling the ABS. I'm sure there is a way, but probably much more complicated.... |
#14 | |
Now we've got to get someone to actually figure this out!
#15 |
IH8MUD Wookie
I copied a quick blurb about 4runners.. I sure like my 96 with the rear diff lock, 2.7 litre and auto tranny... it goes places I'm not always sure i wanna be going
![]() The Toyota 4Runner was the first of Toyota's comfort-driven SUVs. Unlike the Land Cruiser, the 4Runner was designed around the rugged frame of the truck, and made to be a little more comfortable. Years given are Toyota model years, and not necessarily the years in which the 4Runner was released. 1985 In mid 1984, for the 1985 model year, Toyota brought to market a revolutionary new vehicle - the 4Runner. Based on the mechanicals of its rugged pickup, the 4Runner combined the versatility and go anywhere ability of 4WD with the comfort and utility found in passenger cars. It had a fiberglass top covering the cargo area which could be removed for open-air driving. This first generation of 4Runner was available in 2 models. The first was a little more than a pickup truck with a covered cargo area. Its emphasis was on utility. With seats on the front only, the rear of the vehicle was intended to be used for cargo. The second was designed to carry up to five passengers. It included a rear seat (with seatbelts for 3 occupants) which could be folded flat for additional storage space. The passenger model was available in the SR5 grade, and included a larger fuel tank and more luxurious interior appointments. Both models were powered by the 2.4L 22R four-cylinder engine coupled to a five speed manual transmission with two speed transfer case, and all had manual locking front hubs. 1986 Toyota added the Hi-Trac independent front suspension to the 4Runner, giving it more ground clearance and improved ride quality. In addition to the improved ride, Toyota gave the 4Runner an injection of power with the addition of a turbocharged engine available on SR5 models. 1987 The SR5 trim was available on all models, both truck and passenger, but the turbo engine was still confined to passenger models. Slight changes to the grille, headlights, and striping were also new for 1987. 1988 More power was the topic for '88. Toyota introduced the 3.0L V6 engine to the 4Runner. Because the V6 was more suited to the off-road environment that the 4Runner was designed for, the turbo model was discontinued, leaving only the V6 and four-cylinder engines. 1990 Introduced in spring of 1989, Toyota unleashed an entirely new breed of 4Runner. Based on the completely redesigned line of pickup trucks, the new 4Runner was muscular and aggressive looking, but still capable of delivering the off-road performance for which Toyota's four-wheel drive trucks had long been known. The vehicle was now available in either two or four door configuration, with either a four or six cylinder engine and with either two or four wheel drive. The new styling eliminated the removable fiberglass top, making the vehicle quieter and more weather tight. The 1990 4Runner was among the Consumers Digest "Best Buys" report and awarded the "Best Compact SUV in Initial Quality" title by J.D. Power & Associates. 1991 The 4Runner wins two more awards, again the "Best Compact SUV in Initial Quality" buy J.D. Power as well as "Best Compact SUV in Customer Satisfaction" also by J.D. Power. 1992 Minor revisions in styling came in 1992, including flush headlamps and new grille and molding treatments. Leather seats are now an option as well. Again, J.D. Power awards the 4Runner the same awards as in 1991. 1993 J.D. Power names the 4Runner "Best Compact Sport Utility" 1994 Safety was emphasized and the 4Runner received side-impact protection, a center (third) brake light, and the option of four-wheel anti-lock brakes on all V6 models. Fully optioned with a CD-player, eight speaker stereo, sunroof, leather seats and anti-lock brakes, 4Runner's price was approaching $30,000, quite a departure from its beginnings some ten years earlier as a glorified truck. But 4Runner hadn't forgotten its off-road heritage either, and remained as strong as a back-woods performer as ever. Again, the "Best Compact SUV in Initial Quality" award is given to the 4Runner by J.D. Power. 1996 Toyota's most popular SUV received a complete redesign, including all new engines, chassis, interior and exterior styling, enhanced safety equipment and added utility. It was the first 4Runner to not share wither body panels for a frame with Toyota's compact pickup trucks. This was the 3rd generation of 4Runners. Available in 2 or 4 wheel drive, in base, SR5 and Limited trim, and with 2 engine choices there was a 4Runner for everyone. Engine choices were a 2.7L 4 cylinder or a 3.4L V6, both with twin cam, multi-valve designs. The new chassis was stiffer for improved steering feel and more precise suspension travel, and was two inches longer to increase wheelbase for a more stable ride. Front suspension was a coil spring with double wishbone design replacing the previous Hi-Trac system, which resulted in greater wheel travel and ride comfort. Other features on the new 4Runner included a one piece lift up tailgate with power window, larger outside mirrors, much increased interior volume with greater head and legroom and a lowered step-in and cargo loading height. For safety, dual airbags were included along with four-wheel ABS, side door impact beams and ALR/ELR seatbelts front and rear. Awards for this model included a runner-up for the "Compact 4-Door SUV Best Buy" by Four Wheeler magazine, and "Most Appealing Compact SUV" by J.D. Power. 1997 4Runner saw only minor changes including the addition of a 2WD Limited model, revised seat fabric in SR5 models, the ability to order 16-inch alloy wheels on 2WD models and 2 new Preferred Equipment Packages. A number of awards were given out in this year: "1997 Top Three Vehicles in Initial Quality - Compact SUV" - J.D. Power. "Best SUV" - Consumer Reports magazine. "Top 10 Trucks Overall Resale Value After Three Years of Ownership" - ADP Autosource Survey. "1997 Total Quality Award - Medium SUV Segment" - Strategic Vision, Inc. 1998 Again, only minor changes in 1998. Rotary style HVAC controls, new 4 spoke steering wheel and revised audio head units were the only improvements. 1999 This was the 4th year for the 3rd generation 4Runner. More standard features and options equipped this model than any other 4Runner to date. All 1999 4Runners receive a redesigned front bumper, valence cover and grille with multi-reflector headlamps with an auto-off function, a new center console with dual cupholders, an overhead console with garage door/sunglass holder, two power outlets in the center cluster and an LCD odometer with digital dual trip meters. In addition, SR5 grades no feature as standard heated outside mirrors and cruise control as well as an upgraded optional Sports Package which includes color-keyed bumpers with projector fog lamps, fender flares, a new wheel design and a sporty hood scoop. The 1999 4Runner Limited model received a new multi-mode 4WD system as standard. The new multi-mode feature is actually a full-time all-wheel-drive system with 2WD capability and can be used in normal driving conditions on all types of roads including dry, hard surfaces such as pavement. Awards for 1999 are the "Best Compact SUV in Initial Quality" by J.D. Power and the "Best Compact SUV Segment" also by J.D. Power. 2001 All 4Runner models are standard equipped with the 3.4 liter V6 engine and automatic transmission, Vehicle Skid Control with traction control, multi-mode 4WD and a 2WD/4WD selector switch and a pre-wired trailer hitch harness. The brake booster is changed to hydraulic assisted and the rear differential lock has been discontinued. the 2001 4Runner also boasts new interior additions and three new exterior colors. Notes What does 4Runner mean? Combine 4-wheel drive and off-road Runner and you have a 4Runner, Toyota's fun-to-drive off-road vehicle. All 4Runners are built at the Tahara Plant in Tahara, Japan. All of the above information is provided by Toyota Motor Company, Inc. Site Map Home Links Parts Bin Articles/Info Project Center Gallery Guest Book Mile Marker Message Board Contact ToyotaOffRoad.com is independently operated by Mike Kelly and is in no way affiliated with Toyota Motor Company or its subsidiaries. copyright ©2000 - 2006 Mike Kelly - ToyotaOffRoad.com 1,748,492 __________________ -girlfriends 84 BJ60 3B diesel (752,500 km) & [82 BJ60 donor vehicle, ARB BullBar] -96 4-runner, 2.7L auto, stock rear diff lock, ARB BullBar, 235 85R16's Michelin LTX M/S (289,000 km) -05 dbl cab TRD Tundra, 4.7L 235 85R16's Michelin LTX M/S(13,200 km) |
Samsung | Remortgaging | Car Insurance | WoW Gold | Broadband |
