Go Back   IH8MUD Forums > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 10-14-07, 07:57 PM   #1
Kneel for the Shaman
Romer's Avatar
TLCA# 13968
99 4runner Brake Light
The Brake light in dash on Rachels 4runner is lit intermittantly.
The Master Res cap was loose, I put it on good. Fluid level is good and I verified the brake itself was disngaged and nothing ubstructing the lever.
What else feeds into this warning light?
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is online now   Reply With Quote
Old 10-23-07, 12:17 PM   #2
terryjmatthew's Avatar
TLCA# 17870
The brake fluid level sensor might be bad?
Havent really looked at mine to see what kind of sensor it has.
I'll check and get back wth you.
-Matthew
2000 S/C 4Runner Ltd
98 Taco on 60's
terryjmatthew is offline   Reply With Quote
Old 10-23-07, 02:05 PM   #3
Fear the Bunny
Bighead's Avatar
TLCA# 15114
According to my 2001 4Runner FSM, either brake fluid level is low (which you already fixed) or hydraulic brake booster power supply is bad. Is she getting any buzzer sounds when when the light comes on?
Lance
2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000
2004 Land Cruiser -- Stock for now
Bighead is online now   Reply With Quote
Old 10-26-07, 12:43 PM   #4
Romer's Avatar
TLCA# 13968
No buzzer sounds.
So it doesn't have anything to do with the ebrake? like potentially a bad sensor there or needing adjustment?
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Old 10-26-07, 03:22 PM   #5
Fear the Bunny
Bighead's Avatar
TLCA# 15114
Originally Posted by Romer View Post
No buzzer sounds.
Check your PMs.
I didn't see anything about in my FSM. Here are the symptom/suspect areas from the FSM that reference a brake warning light coming on.
--Brake warning light lights up (Parking brake lever released) (note 1)
1. Brake fluid level
2. Hydraulic brake booster power supply system (Faulty)
--Brake warning light lights up and brake warning buzzer sounds (note 2)
1. Hydraulic brake booster power supply system (Faulty)
--ABS warning light lights up (note 3)
1. Anti - lock brake system (Faulty)
Notes 1, 3: The light may stay on for about 60 seconds after the engine is started. It is normal if it goes out after a while.
Notes 2, 3: Depressing the brake pedal repeatedly may turn on the warning light and buzzer. It is normal if the light goes off and the buzzer stops sounding after a few seconds.
Note 3: While ABS warning light is ON.
Lance
Old 10-26-07, 10:34 PM   #6
underthehood's Avatar
TLCA# 17696
you can try looping the wires at both the master cylinder and the p-brake lever switch. this will bypass both sensors to see if that is your problem. be sure to do one at a time. good luck
'07 FJ Cruiser TRD
Bud Built skids.(ALL)
All Pro rear bumper and trailing arms, Demello sliders and High Lift jack mounts, Demello front bumper with t-max 9k winch(synthetic), TRD cold air intake, 305/70r16 BFG MT'S, 2.5 inch leveling kit(no tire rub), Inchworm e-locker cover
underthehood is offline   Reply With Quote
Myspace Proxy | Loans | Mobile Phones | Mortgage calculator | Loans
