Go Back   IH8MUD™ Forums > Toyota Tech Forums > 95+ Gen Toyota Trucks
Old 09-15-07, 07:56 AM   #1
The Perfect Cruiser's Avatar
help with 2003 tacoma
lost all turn signals I checked the fuses but nothing was blown
if I turn on the switch not evan a light comes on.
could it be a bad relay ?
Got paid to drive my fj40 in the movie The Perfect Storm
1974 fj40 4.88 gears 36inch Q78 powertrax up front open rear ford 300i 4.9 np435 3speed case rear disc brakes
The Perfect Cruiser is offline   Reply With Quote
Old 09-15-07, 01:47 PM   #2
KliersLC's Avatar
Do your Emergency flashers work? If not, and you checked the fuses both inside the cab and under the hood, your flasher unit might be bad. If they do work, then you could have a bad turn signal switch.
I would also verify that all the bulbs are good because I am not sure how the new trucks act when they blow a bulb.....
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition
01 Sequoia Limited
02 Camry--Poor replacement for an 80
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
KliersLC is offline   Reply With Quote
Old 09-15-07, 02:58 PM   #3
nothing works hazard or turn signals and all the bulbs are good.
Old 09-17-07, 03:26 PM   #4
thanks for help it was a bad flasher relay
Synchronization fast and easy | Daddy Yankee | Myspace Codes | Malaysian Property | Loans
