Water-Intercooler installed
Fitting:
![]() Pipe fitting: ![]() The intake pipe "welded" by Techno-Weld (Techno-Weld) Not nice, but itīs tight: ![]() Intake with homemade gas pedal cable holder: ![]() The radiator, the water pump and the swirl tank: ![]() The swirl tank: ![]() Here it is, all installed: ![]() The front view, I managed to get the radiator very close to the bumper hole: ![]() But there was a lot of heat under the hood at slow speeds (in traffic hour) and at high speed too (120 km/h). My bull bar is blocking quite a lot the radiator hole in the front bumper. So I install a fan (10") for the intercooler radiator. ![]() I made this temperature controlled (it starts at +40C and shut down under +30C). Parts needed: -Air-to-Water intercooler, core size: 10"x4.5"x4.5" -Radiator (Fiat Cinquecento) -Water-circulalation pump (Bosch 0 392 020 064, 1200 liter/hour) -Swirl tank 0,75 liter (homemade of aluminium drinking bottle) -Expansion tank (VW Golf) -76 mm/63 mm aluminium pipes -76 mm to 51 mm 45° Silicone Reducer + 3" 90° bend -19 mm hoses -Clamps -Brass fittings -Wires+relay+switch -10" fan +relay+temperature switch It works very well, it feels more powerful and the torque is better too. 8) Here is a dyno sheet (original motor gives 125 hp and 295 Nm): ![]() This model is manufactured without intercooler, like all Toyotas with 1KZ-T(E) in Europe. And those who think there is no space under the hood for this kind of device, I have 2" bodylift. It makes this project possible.
__________________ Land Cruiser KZJ90 -96 -2" bodylift + 1.25" spacers at front -33x12.50R17LT tires -Water Intercooler -3" exhaust pipe (incl. down pipe) Last edited by -MaTTi-; 07-04-08 at 04:37 PM. Reason: dyno sheet translated to english |
LIFER with a 2F-ETI
Do you know you pre and post inter cooler temps?
__________________ If the wife's not complaining your not spending enought time with your 40! 2F+3FE+T+I-3F=2F-ETI THE MULE @ 400hp max Est @ 15PSI DYNO'd at 8PSI 155kw/208hp and 650Nm/480ftlb @ the RW Links Sponsored by OZZIEWEBHOSTING Mac's Space
I have only measured ones, when driving 120 km/h, boost 0.7 bar, ambient 22°C, pre was 97°C and post was 60°C.
Not good at all. The cooler was very hot.So, I add a 10" fan. I think itīs much better now. I have to take more measurements. P.S. Your water-ic looks very nice! And the rest of the project too.Edit: I measured post-intercooler temperature with the fan, itīs about 30-35°C at normal cruising 80-100 km/h and rised to 46°C at 120 km/h. Ambient temperature was about 15°C. I only have one termometer, so I didnīt took pre-intercooler temp at this time. __________________ Land Cruiser KZJ90 -96 -2" bodylift + 1.25" spacers at front -33x12.50R17LT tires -Water Intercooler -3" exhaust pipe (incl. down pipe) Last edited by -MaTTi-; 07-05-08 at 02:06 PM. Reason: new measurement results |
What is the swirl tank for?
marin |
In my case, just for increasing water capasity of the system. Itīs made of an aluminium drinking bottle (0,75 liter).
__________________ Land Cruiser KZJ90 -96 -2" bodylift + 1.25" spacers at front -33x12.50R17LT tires -Water Intercooler -3" exhaust pipe (incl. down pipe) |
oh ok, you made it sound more technical calling it a swirl tank, which is why i asked. lol.
marin |
Unsecured Loans | Consolidation | Debt Consolidation | Cheap Car Insurance | Libros |
