Go Back   IH8MUD™ Forums > Toyota Tech Forums > 90-Series Tech
Old 03-17-08, 08:14 PM   #1
Bosvark is on a distinguished road
Front Suspension on Colorado
Hi, newbie here.
I was wondering, if you put a spacer in between the top shock/coil stud and the retaining plate, will it give better front droop? Will this also give a bit of lift to the front end if I use new std height springs/coils which is 20% stiffer?
Or do I need to fit spacers between the strut assembly and the mounting bracket to lift the front end .
Regards
Bosvark
Bosvark is offline   Reply With Quote
Old 03-22-08, 02:16 AM   #2
KZN185W is on a distinguished road
a coil spacer will increase ride stiffness since you are preloading the springs. a top-out spacer will give you the lift desired without preloading the springs so the harshness of the ride doesn't suffer.. so go for the top-out spacers..that is the spacer between the top plate and the mounting frame..
KZN185W is offline   Reply With Quote
Old 03-26-08, 11:48 AM   #3
Hi KZN185W
I have made a 30mm spacer out Aliuminium and fitted it between the assembled strutt and mounting bracket.
It has give me the lift I were looking for. Before new springs the ground to fender lip height was 865mm and now it is 960mm. The front tyres ,305/70R16 MT's is'nt touching any where now and the steering/handling feel more accurate.
The rear sits 50mm higher but it will level out as soon as I put all the stuff in what I normaly carry around.
I will upload some pictures later after figuring out how to do it
Regards Bosvark
Loans | Mortgage | Halloween Costumes | Mortgage | Loans
