Go Back   IH8MUD.com > Toyota Tech Forums > 90-Series Tech
Old 10-18-07, 01:50 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Upgrading a Land Cruiser
Hi guys,
I own a Land Cruiser 90, V6 3.400cc, 5door, 2001 model, AT tires, IFS (independent front suspension), with all original parts (no extras).
The car is EXCELLENT on and off road!!!
I am tempted to spend some money on the car to:
a) increase the height (+4cm or appx 2inches), and
b) install rear air locking differentials
I am sure that somebody out there must have already done such modifications. i would like you to recommend brands and share your experience.
My main concern is not to sacrifice the car's overall excellent performance (on and off road) and not to affect the cars long term reliability.
Thanks for your replies!
Foris
Foris is offline   Reply With Quote
Old 10-19-07, 07:03 PM   #2 (permalink)
FloridaFJ80's Avatar
Foris
Before I can give you some recommendations its good to know what your wheeling is like?
How do you wheel your rig (moderate trekking, some mud, lots of mud)? How often do you wheel? Do you wheel for fun or because you have to? What type of performance attributes dont you want to sacrifice?
Frank
1992 FJ80 Semi-Stock
2008 Prado VX - TRD'd
305/70/17 Maxxis Bighorn M/T
TJM 3" Suspension Lift
Safari Rack with Fogs
Factory Digital Inclinometer/Compass
Rear storage system
Dual Battery Setup
On Board Air
FloridaFJ80 is offline   Reply With Quote
Old 03-30-09, 10:35 AM   #3 (permalink)
Hi guys,
First, allow me to apologize for not popping in earlier (1,5years ago to be more precise ....) .... no excuses .... so many things have happened ......
Well, coming back to , I have looong ago installed the OME 2" kit and 265/75/16 STT's .... the car is great (I LOVE IT!) and it performs
excellent all over & even in very tough off roading.
The only area which is of some worry is the IFS ... although excellent for on road traveling, the off road performance and improvement ability (modifications) are significantly limited by this .....
Is there any viable ($$$) mod for the IFS??? ok, swapping to an axle makes sense but it kills the sweetness of the IFS and costs another car ....
What can be done to the IFS to improve off road performance and retain on road sweetness ?
Reliability is a major concern ... the car is RELIABLE and has to remain RELIABLE... no need for split cv boots or broken links ...
LC 90 VZJ95 (LWB), V6 3.400cc 5VZ-FE, OME 2", STT 265/75/16 + wife, kids, lots of snow & mud
Old 04-01-09, 10:54 PM   #4 (permalink)
Hi guys,
I guess that no replies means no solutions for upgrading the IFS ..... :b ang:
so ... no chance for more articulation in the front ........
I will keep on looking into the issue .......
In the meanwhile, enjoy and if you run into something interesting, let us know ...
Old 04-02-09, 05:38 PM   #5 (permalink)
Matty Awful's Avatar
If you're worried about the lack of articulation in the front then fit an ARB Air Locker that way it doesn't matter if you lift a front wheel - you'll still have drive to the other front wheel. It's going to take something pretty serious to stop you then, trust me on this.
The other thing to remember is that whilst the front doesn't have huge articulation, the rear end has buckets of it.
For the record I wheeled mine with some pretty serious solid axle trucks & more often than not they would get stuck & I wouldn't. So get a set a set of lockers, keep your Prados road manners and call it good.
Cheers,
Matty
Matty Awful is offline   Reply With Quote
Old 04-03-09, 12:07 PM   #6 (permalink)
Very well put !!!!! you are right ...
I also do not have a huge problem with this off road ... it is just the matter of limitation which is frustrating when considering upgrading the suspension ...
But in the end .... it is just as you very nicely said ....
I was planning to fit an ARB blocker in the rear but am hesitating because the LSD is working quite nicely .... so I will consider putting the blocker in the front .... might be a reasonable solution although most cruiser's I know fit 1 blocker in the rear .... will think about this ...
Old 04-30-09, 05:39 PM   #7 (permalink)
Rookie
The only area which is of some worry is the IFS ... although excellent for on road traveling, the off road performance and improvement ability (modifications) are significantly limited by this. The other thing to remember is that whilst the front doesn't have huge articulation, the rear end has buckets of it
voip software
stwee321 is offline   Reply With Quote
Old 08-01-09, 09:46 AM   #8 (permalink)
GRVIT's Avatar
Hi all.
Ok,since I cant find an 80 available over here,my other option is a Prado 95 (lwb) 1996-98 for example.
Im also considering of doing a solid axle swap on the front end to get rid of the IFS.
I have a pair of FJ62 axles in my warehouse.
Your help is needed here.
Questions :
1-Is the t-case of Prado the same with another LC like 80 for example?
2-Are there available t-case reduction gears in the market?
3-Anyone knows the front-rear track width (96-98 model) ?
I m thinking of keeping the rear axle and put the FJ62 front axle on the front end or at worse,replace both of them with the 62s.
I know that its narrower than the 80.
4-stock ring /pinion ratio ? After market options? Diffs same as other Toys?
5-Is it considered to share parts like frame,front IFS with another Toy model like 4runner for example?
6-On which side are Front and rear diff pumpkins,i.e driver's? passenger's side ?
7-Frame rails are at same width from front to end? or they get narrower on the front end ?
I guess thats all for the moment.
Thank you.
Suzuki Sidekick 1600 16v
SAS,custom coil suspension,OTT kicker3,ARBs F-R,33X12,5X15
GRVIT is offline   Reply With Quote
Old 08-06-09, 09:56 AM   #9 (permalink)
Spread the H8
TEPUI's Avatar
How many kms or miles on your engine?
The 5VZFE requires a timing belt change at around 150.000 Kms.
http://www.rallyglobal.com
'00 トヨタ 4Runner VZN185
'97 トヨタ Land Cruiser Prado RZJ90 SOLD!
Get your Land Cruiser Apparel & Stickers here!
TEPUI is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/90-series-tech/183404-upgrading-land-cruiser-90-greece.html
Posted By For Type Date
??????4?4 Off Road Club • ??????? ??????? - ????????? ????? ???. ????? ? ??????? ??????????? This thread Refback 06-09-09 07:34 AM
