Go Back   IH8MUD™ Forums > Toyota Tech Forums > 90-Series Tech
LinkBack (4) Thread Tools Display Modes
Old 10-17-07, 10:06 AM   #1
whining noise. help please
i have just bought a 1997 colorado (prado) automatic 3.0 TD. i'm very plesaed with it apart from a whining noise that seems to be coming from the lefthand front footwell. it does it in all gears,neutral, park, hi and lo range, difflock, OD in fact every combination of everything. its not the fan or air con. once driving it's not so noticable as other noises drown it out. sometimes it doesn't happen 'til it's done a few miles.
some have said it may be a vacuum hose located somewhere behind the glovebox. also the fuel return valve has been mentioned. until my workshop manual arrives i don't know where to look. can you help?
thanks.
nordic venture is offline   Reply With Quote
Old 10-17-07, 04:46 PM   #2
Just tell her it's your truck and to shut up. Maybe buy her a nice dinner.
ohhh...wait never mind.
_____________
J Gordon
12/1985 FJ60
"After all, It is just a crew cab tractor." - D'Animal
jgordon is offline   Reply With Quote
Old 10-18-07, 02:28 AM   #3
funny, but not really helpful. actually, having just come from 4 years of driving a landrover 110, she's well pleased.
anyway, back to the noise. sometimes when cold it doesn't happen but then starts after about 20 minutes.
any ideas?
Old 10-19-07, 07:09 PM   #4
FloridaFJ80's Avatar
Does the noise only happen when your driving? Have you checked maybe your CV Boots, front axles, etc? I am thinking it could have something to do with your drivetrain as you describe the issue as happening through all gears. I would check everything up front, maybe your tires are not balanced.
Frank
1992 FJ80 Semi-Stock
2008 Prado VX - Semi-Stock
305/70/17 Maxxis Bighorn M/T w/ 1.5 trim spacers
Safari Rack with Fogs
HIDs
Factory Digital Inclinometer/Compass
Rear storage system
Dual Battery Setup
On Board Air
FloridaFJ80 is offline   Reply With Quote
Old 10-20-07, 01:09 AM   #5
it makes the noise when parked as well as when driving. sometimes it doesn't start until the engines warmed up.
Old 10-20-07, 08:46 AM   #6
HDJ100L's Avatar
I would suggest stop driving the car......
2000 Toyota Landcruiser 100
1HD-T 147HP@0.82 Bar
HDJ100L is offline   Reply With Quote
Old 11-23-07, 05:12 PM   #7
I have the same noise you describe. I have a manual gearbox Prado 11/1997 hdj90. The only thing I think that is related to the noise is the engine revs. I have gave-up trying to find it, so if you find it you have a case of beer from me!
sabink is offline   Reply With Quote
Old 11-28-07, 06:22 AM   #8
ah ha! on top of the injector pump is a banjo bolt on the fuel return side which contains a spring loaded ball valve. the spring weakens causing the ball bearing to resonate. i removed the bolt and took the ball and spring out. then i stretched the spring slightly and replaced. the spring is similar to that inside a ball point pen. put it all back together again and hey presto!
it's hard to believe that this could cause such a whistling noise coming up through the footwell but it does (did).
let me know if this works and i'll PM you my address for that case of beer!!
bear in mind i live in th UK
Old 11-29-07, 02:34 AM   #9
I had this banjo bolt replaced earlier this year after a lot of searching and headache, and the noise disappeared.
What finally solved the problem was a tech guy at my local Toyota dealer that remembered a recall from Toyota on the banjo bolt in the late 90's. I don't have the recall note here, but I'll try to look it up later.
Reven is offline   Reply With Quote
Old 12-02-07, 04:17 PM   #10
The answer is..... Vacuum leak....
me....
UZJ100
CDN80eh? is offline   Reply With Quote
Old 12-03-07, 12:54 AM   #11
Thanks for the replies fellas! I ordered the Banjo bolt and I will report back the result. The beer is in in a cold place waiting for the winner
Old 12-03-07, 05:13 AM   #12
try taking the top off the banjo bolt and stretching the spring while you're waiting. it will take you 5 minutes and you'll find out if that's the problem straight away.
Old 12-08-07, 10:58 AM   #13
YES! I stretched the spring and 2 days now, no noise! Amazing
nordic venture, PM me with your address to send the
I'm from Bulgaria, but I will arrange something
LinkBack to this Thread: http://forum.ih8mud.com/90-series-tech/183224-whining-noise-help-please.html
Posted By For Type Date
Norsk Land Cruiser Klubb :: Vis Temaet - Tips - ulyd This thread Refback 04-24-08 12:28 PM
Norsk Land Cruiser Klubb :: Vis Temaet - Tips - ulyd This thread Refback 02-17-08 01:45 PM
Norsk Land Cruiser Klubb :: Vis Temaet - Tips - ulyd This thread Refback 01-30-08 10:38 PM
Norsk Land Cruiser Klubb :: Vis Temaet - Tips - ulyd This thread Refback 01-30-08 04:28 PM
Web Advertising | Remortgages | Credit Cards | Web Development | Internet Advertising
