Go Back   IH8MUD™ Forums > Toyota Tech Forums > 90-Series Tech
Old 04-13-07, 02:24 PM   #1
Spread the H8
TEPUI's Avatar
Meru rear axle question
Somebody just mentioned to me that the RZJ90 assembled currently in Colombia (and sold in Venezuela as Prado Meru) comes from the factory with a Dana rear axle. Is that true? if so, which Dana axle are thy putting in them?
I've seen some Venezuelan Land Cruisers with D60, but that seems like overkill for a 4cyl Prado.
just curious...
'97 RZJ90 トヨタ
Get your Land Cruiser T-Shirts, Hats, Stickers here!
TEPUI is offline   Reply With Quote
Old 04-13-07, 02:36 PM   #2
ringpinion.biz's Avatar
dana axles
I have seen some strange South American toyota stuff. I have seen pictures of late model Hilux w/ Dana rearend. It was stamped and tagged Dana, w dana numbers, etc., but it was a Toyota style dropout rearend
JTS Diff Parts & Accessories
ih8mud sponsor
866-349-6801
info@justdifferentials.com
www.justdifferentials.com
99 uzj100 35's, uniball a-arms, fox shocks, 4.88, lockers, bullbar, drawers & more.
ringpinion.biz is offline   Reply With Quote
Old 04-18-07, 03:54 PM   #3
guacharin's Avatar
yes thats tru, is Toyota 8"style dropout rearend and have the dana logo, the ring have the same holes but 5mm closer to the center and the pinion is shorted.
regards
michele carpico
hzj-73,kzj-90vx,fzj-80gx
keep cruising!!!...be free!!!
www.geocruisers.com
la coruña-spain
guacharin is offline   Reply With Quote
Old 04-25-07, 09:54 AM   #4
Tapage's Avatar
regards
Did you know the model of this Dana .. thinking it's by DanaVen . ?
HJ-60 2H-T Intercooler Tencha
Originally Posted by pygpen
Old 04-26-07, 01:23 PM   #5
guacharin's Avatar
i think that is danaven, because this car is made in sofasa colombia
for the vanezuelan market.
regards
michele carpico
www.geocruisers.com
la coruña-spain
Old 04-26-07, 02:34 PM   #6
Interesting
Hello Michele
Carl Here!
regards
ih8mud sponsor
866-349-6801
Old 04-27-07, 11:14 AM   #7
guacharin's Avatar
jejeje, yes man, so know what caind off r&p is this? have any lsd for this one.
regards
michele carpico
www.geocruisers.com
la coruña-spain
Old 05-01-07, 06:07 PM   #8
Tepui, tell me where and what to look for and I shall go see it on my Meru....
Liz (ladyliz68)
RZJ90L colombia color f43 (azul tinta) (Meru: Venezuela, Sumo: Colombia)
1991-1999: Toyota Macho was my passion!
En casa solo se maneja TOYOTA!
ladyliz68 is offline   Reply With Quote
Old 05-07-07, 03:50 PM   #9
Spread the H8
TEPUI's Avatar
Liz, it would be great if we could see a picture of your Meru's rear axle. Thanks for offering help
'97 RZJ90 トヨタ
Old 07-05-07, 12:33 PM   #10
The colombian made Series 90 comes with a rear axle made by Transejes de Colombia (DANA) and the BIG difference is that the third member contains a non standard DANA diferential, model 207, made for the Hilux (Brazil, Colombia, Venezuela) and the Prado (Colombia, Venezuela). This is a major set back for owners of colombian made Prados, because we can't use all the aftermarket parts for the Toyota 8 Inch V6 Turbo Differential. The axles are Toyota, but the differential is not. Another BIG difference is that the this Dana differential is weaker than the Toyota 8 inch V6 Turbo. (not that you will break it, but when you are buying your Toyota 4wd you expect the Toyota quality an resistance). Why is it weaker you may ask, well the BIG difference is that it only has two pinions (planetarios) inside the differetial carrier instead of four, also the differetial carrier is adjusted in the thirb member housing via shims and not with adjustable nuts.
If you want to improve your rear differential in the colombian made Prado, you'll have to change the third member with gears and all, for an original Toyota one. It will fit the axle housing with no problem. I looked into the matter and a complete third member with a Detroit TruTrac and 4.3 gears came to USD1400.
If anyone wants the service manual for the DANA differential in the Prado email me. It was given to me by the training area of Transejes de Colombia (DANA).
For in dept info on Toyota 8 inch diff go to: www.gearinstalls.com
PRADO VZJ95
JakeA is offline   Reply With Quote
Old 07-05-07, 05:25 PM   #11
8" 3rd members
We can build complete bolt in 3rd members as well with your choice of ratio and LSD/Locker/open diff.
ih8mud sponsor
866-349-6801
Old 09-08-07, 08:43 PM   #12
Tepui, sorry I have not been around for a while... so, where should I photograph? Por debajo?
Liz (ladyliz68)
Old 09-09-07, 09:17 PM   #13
FloridaFJ80's Avatar
Yeah my rear end is Also DANA..
Frank
1992 FJ80 Semi-Stock
2008 Prado VX - Semi-Stock
305/70/17 Maxxis Bighorn M/T w/ 1.5 trim spacers
Safari Rack with Fogs
HIDs
Factory Digital Inclinometer/Compass
Rear storage system
Dual Battery Setup
On Board Air
FloridaFJ80 is offline   Reply With Quote
Old 10-25-07, 06:59 AM   #14
just a little clarification, what he was trying to say is that the axle has only one planetary.
The axle case is toyota, but the rest is dana, they are very weak and i've seen them break a lot. The strenght of the USA tacoma 8" is far superior. Also, the axle breather is non existing, is just a lil plug in the axle, no hose or anything to raise the breathing point. Well, it has many flaws.
Thats just the back, the front is hideous. :/
Gustavo
Need something from Venezuela
Pm me for info.
gsiblesz@hotmail.com
GZERO is offline   Reply With Quote
Old 10-26-07, 09:09 AM   #15
GZERO - have you done any upgrades to the rear axle? What about the front? Any pics and suggestions??
Frank
HIDs
Rear storage system
Dual Battery Setup
On Board Air
Old 10-26-07, 10:21 PM   #16
worldcruiser's Avatar
TLCA# 16478
If anybody needs any information on this specific differential I can get you any data as the owner of Transejes de Colombia is a personal friend of mine.
99FJZ100 / 91FJ80 / 79FJ40 / 76 20R TRK / 72FJ40 /75FJ55
www.worldcruisers.net
worldcruiser is offline   Reply With Quote
Old 10-27-07, 01:53 PM   #17
I change my rear axle using a Prado Japan made one, the bolt-on is perfect and I win rear disc brakes too. With this made I install a ARB locker without problems.
The fron axle is identical to the japanese one, don´t need mayor work to install a locker or upgrade the pinion, etc.
Dariusz is offline   Reply With Quote
Old 10-29-07, 12:06 PM   #18
If you're looking for the cheaper "fix" that would be to find a japanese made third member and slap that in. There shouldn't be any modification.
Also, you could try to buy a complete axle as well, just make sure its from a coil spring car, since removing the leaf springs mounts to well the coil springs mount etc. would be a PITA.
Front as far as i know (and the diesel guys can tell you) is a piece of shit, the only thing you can do is drive the car nicely, because the front is weak...of course, whithin limits.
Pm me for info.
Old 12-05-07, 12:44 PM   #19
90 series 3rd members
Yes this would be an easy solution. We offer several options complete ready to bolt in (no core charge either)
For rear:
http://www.ringpinion.biz/index.php?...25fa5f1ce7337a
or
For front:
ih8mud sponsor
866-349-6801
Personal Loans | Cheap Car Insurance | Internet Advertising | Personal Injury Attorney Los Angeles | Hotel Las Vegas
