Go Back   IH8MUD™ Forums > Toyota Tech Forums > 90-Series Tech
Old 04-01-07, 01:36 PM   #1
Is it possible to mount steering damper on TLC95?
Hello,
I have 1997 TLC 95 and I orders 2" suspension lift. I'm planning to put 165/75/16 Goodyear MTR tires. Because bigger tires will load up the steering system I wish to put steering damper if possible. I cannot find any info on mounting steering damper on TLC95.
Is it possible at all?
Thanks for any help!
sabink is offline   Reply With Quote
Old 04-01-07, 06:27 PM   #2
nope since it has rack and pinion steering
TFS55 is offline   Reply With Quote
Old 04-01-07, 06:31 PM   #3
Deep Thought's Avatar
I hope you mean 265/75/R16 because 165's would make a nice pizza cutter. I've got MTR's on mine and no problems with the steering at all.
Regards
D.T.
LC Prado GXL-TD 95 Series. OME Suspension, ARB Steel Bullbar, Warn M8000 winch, Safari snorkel, K&N Air Filter, 3" Exhaust, DPChip, Homemade Roller Drawers, Rock Sliders. & No self righteous attitude.
Deep Thought is offline   Reply With Quote
Old 04-02-07, 11:31 AM   #4
Yep, I meant 265.
Thanks for the info fellas!
Old 04-02-07, 11:11 PM   #5
dhula's Avatar
I have 265/75R16 Yokohama all terrains on mine and find them no probs at all.
I spose you could fit steering dampers to the front end, but seeing as it is R&P ---> how much money you have would be the limiting factor.
I guess if you got the right size (length) damper then you might be able to mount one between the tie rod end near the wheel and mount the other end to the chassis somewhere.
You'd probably need two, one for each side and then it may not work anyway. Interesting thinking about it tho.
KZJ95 3.0TD and auto. Front bar by ARB. Winch by Warn. Tyres by Yokohama.
dhula is offline   Reply With Quote
Samsung | Mobile Phones | Home Loan | Debt Loans | SMS-Sprüche
