Go Back   IH8MUD.com > Toyota Tech Forums > 90-Series Tech
Old 03-23-07, 08:54 PM   #1 (permalink)
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
1KZ-TE Engine manual
Hey this was posted by another member...
Is the a manual for one of the engines in a 90 series?
diesel manual. http://etoymag.free.fr/manuels2/1KZ-TE.pdf
If not Tepui, pls delete. But if it is, I thought it might be a good resource for the 90 series owners.
Cheers, BB
-91 FJ80, wife's ride
Old 03-23-07, 09:05 PM   #2 (permalink)
Spread the H8
TEPUI's Avatar
Thanks bear! in fact the 1KZ-TE 3.0L engine is found on the KZJ90 & KZJ95 diesel powered 90 series Prado and some 70 series Prados (KZJ71W & KZJ78W)
From Wikipedia:
"The 1KZ-TE is a 3.0 L (2982 cc), 4 cylinders, 2 valve per cylinder turbo diesel engine. Bore is 96 mm and stroke is 103 mm, with a compression ratio of 21.2:1. Maximum output is 130 hp (97 kW) @ 3600 rpm with maximum torque of 29.3 kgf·m (287 N·m) @ 2000 rpm. Redline is 4400 rpm. First produced in 1993, it is still used in new model vehicles today. 1KZ-TE also adopt the electronically controlled fuel injection, ETCS-i (Electronic Throttle Control System - intelligent) technology which is similar in basic construction to a modern gasoline injector, although utilizing considerably higher injection pressures, making it a very efficient engine.
Used in KZJ71W, KZJ78W
The intercooler equipped version of the engine power up to maximum output of 145 hp (108 kW) [Aust. 130hp (96kW)] @ 3600 rpm and maximum torque of 35.0 kgf·m (343 N·m) @ 2000 rpm.
Used in KZJ90 (Prado, Colorado 3-door), KZJ95 (Prado, Colorado 5-door)"
http://www.rallyglobal.com
'00 トヨタ 4Runner VZN185
'97 トヨタ Land Cruiser Prado RZJ90 SOLD!
Get your Land Cruiser Apparel & Stickers here!
TEPUI is offline   Reply With Quote
Old 03-23-07, 10:30 PM   #3 (permalink)
Mod in Hibernation
brownbear's Avatar
TLCA# 15584
Great then those with that engine should save this file on there computer.... cheers BB
Old 09-25-09, 09:39 AM   #4 (permalink)
Is there a similar manual for the 3.0l D4D 120kw engine? KDJ90...
jema is offline   Reply With Quote
