Go Back   IH8MUD™ Forums > Toyota Tech Forums > 90-Series Tech
Old 03-04-07, 12:57 AM   #1
Lockers
Cheers Gents & thanks for the welcome.
I generally only use it on roads but when i get the chance I take it offroad. Hopefully when I have the cash i will install a front ARB locker. I think the rear factory fit locker is good enough.
Can anybody explain what a 3rd member is & why do I require one to get an ARB locker at the front (or rear)? The costs involved for this '3rd member' make it extremely expensive modification.
gavinpears is offline   Reply With Quote
Old 03-05-07, 05:26 AM   #2
Spread the H8
TEPUI's Avatar
Hello Gavin, and welcome to mud!
You already have a third member, it's the mechanism sits in the middle of the axle, and houses the differential, the gears -ring & pinion- and all related bearings.)
'97 トヨタRZJ90
Get your Land Cruiser T-Shirts, Hats, Stickers here!
TEPUI is offline   Reply With Quote
Old 03-06-07, 01:51 AM   #3
Thanks for the welcome & info. Does that mean that if i buy an ARB from locking diff & air compressor it will slot right into the front diff housing without having to buy anything else?
I was told by 2 offroad 4x4 part companies in the UK that I would require a 3rd member or a different one as the ARB locker RD90 would not go straight in. I wrote to ARB in Australia & they couldn't tell me either.
Old 03-06-07, 07:13 AM   #4
Spread the H8
TEPUI's Avatar
It should fit right in your front diff without having to buy anything additional.
Are they authorized ARB dealers? ARB specifies the RD90 for many IFS Toyota models (mostly 96-03), and they clearly state that it fits all gear ratios. What are they claiming to be wrong with your current 3rd member?
'97 トヨタRZJ90
Old 03-08-07, 10:11 AM   #5
Tepui,
They are claiming that they don't have any experience with my model & are not sure what mods are required to fit an RD90 with regards to a 3rd member. Unbelieveable!!!
Thanks for the info though. I may try to get it fitted next time home.
Old 03-08-07, 12:22 PM   #6
Spread the H8
TEPUI's Avatar
Look at the link below. The author is Steve Schaefer, he has plenty of experience with 3rd gen 4runners, which share the same diff with the 90 series Prado. If your rig is full time 4WD there might be some minor differences, but I don't think they affect the ARB install at all.
http://www.sonoransteel.com/front_locker.html
Steve is a member here on ih8mud, and he's always very helpful. You may want to try contacting him directly through his website. (sonoransteel.com)
Also, you may find additional information on www.yotatech.com. I've seen a few threads there about the RD90.
'97 トヨタRZJ90
Old 03-08-07, 12:24 PM   #7
Spread the H8
TEPUI's Avatar
More info here: http://www.sonoransteel.com/ARB_RD90.pdf
Hope it helps you!
'97 トヨタRZJ90
Old 03-09-07, 06:56 AM   #8
Thanks Tepui,
Great links. I will have a look in more detail.
Old 04-13-07, 02:42 PM   #9
ringpinion.biz's Avatar
it uses the rd90 front diff
You have the clamshell style 7.5 reverse frontend. They use the rd 90 diff.
JTS Diff Parts & Accessories
ih8mud sponsor
866-349-6801
info@justdifferentials.com
www.justdifferentials.com
99 uzj100 35's, uniball a-arms, fox shocks, 4.88, lockers, bullbar, drawers & more.
ringpinion.biz is offline   Reply With Quote
Remortgages | Mortgages | Earth for Energy | Homeowner Loans | Loans
