Go Back   IH8MUD™ Forums > Toyota Tech Forums > 90-Series Tech
Old 12-11-06, 04:34 PM   #31
Spread the H8
TEPUI's Avatar
Originally Posted by Venom View Post
Dafs, where did you buy the book?
(Max Ellery's Vehicle Repair Manual for the Toyota Prado 1996-2004)
Is in pdf format or a hard copy?
I'm very interested in that kind of stuff.
Venom,
I have the same manual and got it at amazon.
Click here
'97 トヨタRZJ90
Get your Land Cruiser T-Shirts, Hats, Stickers here!
TEPUI is offline   Reply With Quote
Old 12-18-06, 10:35 PM   #32
Originally Posted by dafs View Post
The first I want is a suspension upgrade, so my question is: Why so many of you are installing OME shocks with King Spring, instead of OME shocks and springs?. You went with the comfort option or the normal option with the shocks?. Someone know the quality of the IRONMAN Suspension compared with OME?
My previous car was a TOYOTA FZJ-70 '94, I'm trying to get used to the lack of power (compared with the 4.5L 1FZ-F 205 HP) of the 3RZ-FE 2.7L (150 HP), I'm listening for any tricks to make this engine gain some HPs (without the TRD).
TEPUI if you read this, please tell me the link to the inclinometer that you bought (You have it already?, was easy the installation?). Thanks in advandce.
Sorry for the long of this post. BTW, I have the Max Ellery's Vehicle Repair Manual for the Toyota Prado 1996-2004 (Serie 90 and 120), if someone need some information I'm here to help.
Silla (See'ya)
Bienvenidos a los Venezolanos (estamos como llenando ya el forum de latinos!! jajaja).
Ok, what you ask most people can answer, jumbo sells the king springs because they usually don't have the OME springs and they can make more profit out of the King Springs, rather than the OME.
I import OME stuff, the Long Wheel Base (LWB) is the same as the Short Wheel Base (SWB), but off course, you have to consider that the LWB is heavier for the rear, for the front they are close in weight.
My advice to you guys is, if you are going to get bumpers (Vigas) and maybe a winch get the soft Springs (OME880 Front, OME890 Rear) with Firm valving shocks (N91S Front, N86 Rear). If you're getting more things than that (roof tent, double battery, stereo, etc.) go with the heavy all around. Also if you want higher lift, go with the heavy, remember that weights determines the height your springs will actually give you.
(si alguno necesita ayuda con algun tipo de traduccion mandenme un mensage y con mucho gusto los ayudare en lo que pueda)
Welcome to the forum and let the teaching begin!
GZERO is offline   Reply With Quote
Old 12-27-06, 07:21 AM   #33
Spread the H8
TEPUI's Avatar
For all you Venezuelans out there, click here
'97 トヨタRZJ90
Old 12-27-06, 08:29 PM   #34
dudes!!!! welcome...
panas!!!! bienvenidos...
rmirandayopo is offline   Reply With Quote
Old 12-28-06, 04:51 PM   #35
Hi Guys,
I am also in Venezuela and found this forum to be an interesting one. My Prado (2 doors) is still stock, no changes so far.
Meruv is offline   Reply With Quote
Old 12-29-06, 05:54 AM   #36
Spread the H8
TEPUI's Avatar
Originally Posted by Meruv View Post
Hi Guys,
Welcome to ih8mud Meruv!
'97 トヨタRZJ90
Old 01-12-07, 12:36 PM   #37
Arrow Prado 4 doors
Hello, my Name is jerry also from venezuela now living in Bogota, Colombia.
I bought a Prado 4 doors 90 series here in colombia, since the prado is also made in colombia they have here lots of accasories for it.
Here are some things I just installed
Arb bullbar, 9.5xp warn winch, ipf lights, OME suspension, procomp wheels and geolandar MT 285 tyres, TRD supercharger, 2cm suplements body lift, digital Altimeter compass etc, outback roof console. I just bought an 7th injector kit from TRD for Prado which they said that increase torque and speed like 30% more...my surprise was that the kit only fits american 4runner & tacoma and prado that has america computer system ......So, a lot of waste of money.
I will send you some pictures.
khasana is offline   Reply With Quote
Old 01-12-07, 12:44 PM   #38
Spread the H8
TEPUI's Avatar
Welcome to the forum Jerry!
Lets see some pictures! (Since you have so many upgrades, it would be interesting to start an individual thread on your vehicle)
I'd like to learn more about the problems you experienced with the 7th injector kit. That may deserve its own thread too.
'97 トヨタRZJ90
Old 01-12-07, 01:09 PM   #39
Thank you .
I will send detail pictures.
The thing with the 7th injector kit was that since the computer wasnt amercian it wont regulate the gas current. So the told me to buy an HKS AIC 3 (Additional Injector Controller)Part # HK 4204-RA005 which is basically operates the injectors by controlling the current, it can control both high & low resistor injectors.
Long story short .... there was 2 alternative which was to bring the regulator and at the same time the DYNO machine of Toyota's factory had to be American coded (which wasnt) or They also had to have a machine to program again the ECU ( which they havent too) ...So nothing to do !
Sorry about my english !!
Old 01-14-07, 10:59 AM   #40
yeap, 7th injector wont work on non us cars. What you should do is tune the car, it will be the same and even better since the 7th injector is a band aid fix and tuning is the correct way to fix it.
Need something from Venezuela
Pm me for info.
gsiblesz@hotmail.com
Old 01-15-07, 10:35 AM   #41
GZERO,
What do you mean exactly when you says Tunning your car. Because Toyota said here that there is no way to install the 7th injector kit.
Maybe you could help me.
Old 01-16-07, 09:26 PM   #42
GZERO,
Well, as with any other engine modifications, if you increase the amount of air an engine consumes you need to use more fuel to balance the mixture. The kit that toyota suplies to the US market is a band aid so that engines won't blow, and just by fixing the ignition (which i'm not entirely sure) and fuel tables they gain power. Now, why does this happends? well...its easy, when you add the supercharger you start injecting air into the engine, but you don't have enough fuel to use all that air, so if you add gas the car makes more power, which is what the 7th injector does......sounds easy, but its really a little more complicated than that.
Well, to sum things up, by saying tune i meant to get a system (either a stand alone computer or a piggy back) to get the Air to Fuel ratio to proper levels so that you start making more power and so that you're engine last longer (oh yeah, if you run too rich or too lean you start to destroy you're engine). Also, if by any chance you're injectors are too close to their limit, is better to buy 6 bigger injectors and tune that way.
its too late, so if i wasnt clear ask me. I'm glad to help. (tambien puedo explicar en español)
Pm me for info.
Old 01-28-07, 06:07 PM   #43
SurfPonto's Avatar
Originally Posted by Dariusz View Post
Price close to $29000, the engine is the 2.7 4 cyl
Is that the same 4 cylinder they use here (U.S.) in the Tacomas?
We have one in my wife's 4x4 Access cab 4x4 and I am impressed by the power.
Bob
SurfPonto is offline   Reply With Quote
Old 01-28-07, 09:35 PM   #44
Bob
Yes Basicly it is the same, altough the differences is on the accesories and stuff.
Pm me for info.
Old 02-15-07, 09:03 AM   #45
albertom's Avatar
khasana
I hope you read this... i tried sending you a PM. I also live in Bogota, i have a FJ70 and would like to ask you where you purchaced your accessories in bogota and/or venezuela, i was thinking about doing a trip out there (San Cristobal maybe) to accessorize my rig taking advantage of the exchange rate (dollars to bolivares). Lemme know if you can help me out! thanks!
Albertom
albertom is offline   Reply With Quote
Old 02-28-07, 11:46 PM   #46
Damn, those are some nice looking Merus you have there! Mine is still stock, I will def do some changes to it soon.
BTW, for the fellow who ask the price, the Prado 2 doors here in Venezuela are worth about bs. 65,000,000 wich is about $17,000. 1 USD = 3,800bs.
Pepeman is offline   Reply With Quote
Old 03-01-07, 05:31 AM   #47
Pepeman, I´m from Venezuela to. I´m not sure if you know but exist the Club Merú de Venezuela, we have meetings all the fridays nights in caracas in the CCCT at 8:00pm. If you like, meet us some day.
We have a big event the 16, 17 and 18 of March, the 2d national meeting in Aguirre Edo. Carabobo.
From what part of Venezuela you are?
Dariusz is offline   Reply With Quote
Old 03-01-07, 05:46 AM   #48
Spread the H8
TEPUI's Avatar
Hi Dariuz,
I'm counting on you to show us some pictures of the Club Merú national meeting That would be a great opportunity to spread the word about our 90 series forum on ih8mud as well. Good luck and enjoy the meeting!
'97 トヨタRZJ90
Old 03-01-07, 06:16 AM   #49
No problem, I post some pictures and a little text about the event.
Old 03-01-07, 06:40 PM   #50
Hey Dariuz, yeah I've seen some videos from the club Merú in youtube, looks like a great club. Thanks for the invitation.
I'm from Puerto Ordaz. So thats a bit far away from me, although I will check out the site and keep an eye on the events.
Old 04-03-07, 12:11 PM   #51
Spread the H8
TEPUI's Avatar
So, how did the club meeting go guys?
Who wants to start a thread about it and show some pics?
'97 トヨタRZJ90
Mortgage Calculator | Download movies | Literatura fantástica | Mortgage Calculator | Mortgages
