Go Back   IH8MUD™ Forums > Toyota Tech Forums > 90-Series Tech
Old 11-03-06, 07:27 AM   #1
Spread the H8
TEPUI's Avatar
Hood rattle
I've had this annoying rattle for the last few months. Seems to come from the hood. It started after a ride on the sand dunes. I think i finally discovered where it comes from, I can replicate the sound when I press the front (center) of the hood. Does anyone know how to stop this annoying rattle?
'97 トヨタRZJ90
Get your Land Cruiser T-Shirts, Hats, Stickers here!
TEPUI is offline   Reply With Quote
Old 11-03-06, 09:34 AM   #2
Tepui,
You can probably adjust the rubber stops on the corners of the hood so it keeps the hood a little higher. Or adjust the latch mechanism down so it will keep the hood tighter against the stops. You'll have to see for yourself.
HTH
Mark
1982 BJ 45 Troopcarrier
12H-t, H55-f, 60 series PS, cable lockers, HZJ73 rear axle w/disks, parabolics, 255/85/16
troopie is offline   Reply With Quote
Old 11-06-06, 06:59 AM   #3
FJ60_cruiser's Avatar
Originally Posted by troopie View Post
Tepui,
HTH
Mark
I second that!!, before I changed mines the hood was really really noisy and after I put them in you can't imagine the amount of noises that I save by just putting the rubber of the corners of the hood
Land Cruiser... because everythnig else just sucks
FJ60_cruiser is offline   Reply With Quote
Old 11-13-06, 03:21 PM   #4
Spread the H8
TEPUI's Avatar
Tepui,
HTH
Mark
I adjusted the rubber stops but the noise is still there. I'll keep investigating.
'97 トヨタRZJ90
Old 11-13-06, 05:05 PM   #5
Tepui have you checked if the crossmebers underside the hood have separated from the top part ( look under the insulation under the hood). Its something tha can happen from a crash or hard 4 wheelin. If that is the case you have to glue it back together probably in a body shop.
PRADO VZJ95
JakeA is offline   Reply With Quote
Old 12-11-06, 04:45 PM   #6
Spread the H8
TEPUI's Avatar
They look fine. My vehicle hasn't been crashed or wheeled hard. The rattle is killing me. But I'm very optimistic about finding it, I'll keep tracking it down.
'97 トヨタRZJ90
Old 01-15-07, 05:09 AM   #7
Spread the H8
TEPUI's Avatar
Finally found the annoying rattle! The A/C condenser's lower mounting points were loose. Added a screw on each side.
'97 トヨタRZJ90
Old 02-08-07, 01:27 AM   #8
rattles and squeaks
Don't you hate those annoying noises!!! Body rattles can travel and be amplified to come out in the oddest spots.
The 80 has had a squeak in the rear for years - as I cleaned out the crud to get ready to sell it - i found a shiny bottle top jammed under the cargo barrier! No more squeak!!!
Roktruk is offline   Reply With Quote
Personal Loans | Secured Loans | Car Insurance | Problem Mortgage | Mortgage Calculator
