Well my two years and a little more were up, time to do a second coolant flush and fill,
After pulling out the overflow and pouring off the coolant I looked in and found a thick mud like deposit at the bottom maybe 1/8-1/4" thick. I stirred it up with a screwdriver, it was not solid or particularly stuck together more just settled, it acts like river silt or wet clay. last time I found just small amounts in a few places like settled right in front of the thermostat and alike and it was grayish green in color, my 80 came with a mix of red and green coolant, this time the sludge is an earthy beige to brown. Color from the red coolant? or is it a different material this time?
Well anyway I put some water in the overflow and shook it up and the stuff came out like chocolate milk, I have it settling in a mason jar overnight.
I have always had some sludge in the radiator cap between the two seals, even if I cleaned it off it came back, I think I know why now the tube in the overflow gets its fluid from the very bottom where all this silt was, every time the engine cools it sucks up a load of this crap, so I cut about 1" off the tube to make it level with the low line, now anything that settles in the overflow will stay there not bothering the water pump or radiator, only downside is that if the level gets very low the radiator is more likely to suck air and will not have access to the last inch of fluid in the overflow bottle but that should not be a problem as I keep a good eye on it.
I am going to have a good size sample of this stuff I need to find a way to test it. Unfortunately I am a light weight in chemistry. going to re read Rich’s separation process. There is a lot of larger black sand like bits in it also,
pics
Original tube
Trimmed tube
Jar full of settling funk
pics
Original tube
Trimmed tube
