LinkBack (3) Thread Tools Display Modes
Old 04-24-06, 07:42 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
Cruiser Jimmy's Avatar
Location: Indy,IN. But currently on the road: SoCal,NV,AZ,NM.
TLCA# 12112
Timing Adjustment for a 3FE Motor
Many threads have been raised regarding how to time a 3FE motor. Many have contributed to the cause of helping a fellow MUD'er out when in need but I have not run across an illustrated thread. Well, you can thank our current Moderator [Ken Romer] for asking someone to post up some 3FE threads to add to the FAQ's for us 3FE guys. So here goes.
0. Warm up the engine to operating temperature.
1. Loosen the bolt that holds the distributor. Don't remove the bolt.
2. Monitor the engine idle RPM. Idle rpm should be 650 rpm. The tach in the dash cluster can be used to monitor the rpm's but the FSM states that you should connect a tachometer test prove to terminal [IG] on the diagnostic's box.
3. In the diagnostic box, use a small diameter piece of wire and connect Terminal TE1 and E1. Recheck the rpm's.
4. Connect a timing light to number 1 cylinder spark plug lead.
5. Aim the timing light at the back of the engine on the passengers side as in Pic 2. Turn the distributor so that you see the large circle align with the small wire probe. You'll see the circle move back and forth as you move the distributor. This is what the FSM calls for timing, when the large circle and the wire mark are aligned, it's 7º BTDC.
Pic 1: Diagnostic box showing terminal TE1 and E1 connected.
Pic 2: Location of timing access view whole.
Pic 3: Shows the timing mark and TDC mark. The large circle is the 7º Before Top Dead Center (BTDC). The two small circles are Top Dead Center (TDC).
Good luck.
TLCA Chapter Club
'83&'87 FJ60, '92 FJ80
Cruiser Jimmy is offline   Reply With Quote
Old 04-24-06, 08:13 PM   #2 (permalink)
TLCA# 12112
Some additionally notes:
You're going to have a hard time getting a line of sight if this is your first time timing the rig. Find your best line, it'll come to ya.
If you can't get the engine to idle at 650 rpms, you could have the idle adjustment not set property and/or the TPS sensor [Pic 2] is out of adjustment.
Adjust the idle screw to the desired 650 rpms [Pic 1]. (When my idle was not right I adjusted the idle screw.) That did not work so I took off the throttle body and cleaned it out [Pic 2]. There was a lot of carbon build up in the two hose ports on the top of the TB. Cleaning those up and the general cleaning of the TB fixed the problem. I could get the idle back down to 650.
While the throttle body was off, I took the TPS off as to not contaminate it. To put in back on and adjusted it property takes an ohm meter. The TPS must be set right for the proper signal to register at the computer.
TLCA Chapter Club
Old 04-25-06, 07:57 PM   #3 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
your write up came in quite handy,
Thank you
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is offline   Reply With Quote
Old 05-06-06, 07:36 AM   #4 (permalink)
TLCA# 12112
alkaline747trio
alkaline747trio,
Did you get your distrubutor fixed?
RT,
Thanks man.
TLCA Chapter Club
Old 05-06-06, 08:57 AM   #5 (permalink)
always broke
alkaline747trio's Avatar
Yea, got it to turn after some PB Blaster and a pair of Channelocks. Set it to 11 deg. and no pinging. Definatly has a little more pep now.
What?
Upstate Cruisers
alkaline747trio is online now   Reply With Quote
Old 12-15-06, 06:29 PM   #6 (permalink)
Rookie
Newbie needs help in locating hole for 3FE
Hello!
I am new to the FJ80 3FE engine. Compared to a 2LTE Diesel LJ78 Prado, this engine is totally alien to me!
Anyway, I can't seem to find the timing hole!
Could someone reply with where exactly this hole is . What is it next to? Close to starter? All I know is that it is somewhere in the rear, passener side.
The picture is too focused on the hole and does not give a reference to parts close to it.
Thanks!
ezgrand is offline   Reply With Quote
Old 02-28-07, 04:44 AM   #7 (permalink)
Can you give us info how did you adjust tps using ohm-meter...... any ohm references ect?
Best regards
nikos is offline   Reply With Quote
Old 02-28-07, 12:34 PM   #8 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
Originally Posted by ezgrand View Post
Hello!
Thanks!
If you look at the picture you can see the end of the side cover on the engine, that should get you in the area, the hole will be covered by a plate held on with one 10mm bolt.
Best regards
the manual has this info.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 02-28-07, 08:56 PM   #9 (permalink)
MJADDICTION's Avatar
I did this a couple of days ago. Thanks for the write-up. I have used so many things from this site lately. This is one of the best. My 3FE is runnin' great...
Thanks!!
-Now I'm Cruiserless, temporarily...
-'97 Ford 4x4 F-350 Super Cab, long bed, 7.3L Diesel, Straight Piped, AFE intake, Chipped, 33's Weld Super Single Wheels. MONSTER
MJADDICTION is offline   Reply With Quote
Old 02-28-07, 11:40 PM   #10 (permalink)
TLCA# 16520
Raven,
The 91 and 92 3FE port is actually covered by a rubber plug, look in the second pic that jklubens put up, follow the heating line rail along the head and at the back of the block you will see the plug you are looking for.
Dave
"The time has come" the Walrus said," To talk of many things.."
In the Trees.... OH
80 fj40, 2.5 OME Dakaar springs, 33" bfgs. "Charlie Brown"
88 fj62 Bone stock, Daily Driver, Bone stock. "Moby"
PHAEDRUS is online now   Reply With Quote
Old 03-01-07, 03:26 AM   #11 (permalink)
I dont have an FSM............ :(
Can you support us with one scan from fsm to get info regarding tps adjust?
Old 03-01-07, 10:39 AM   #12 (permalink)
TLCA# 12112
Nikos,
I'll see if I can get some pics up on the TPS tonight for ya.
Are you able to buy an FSM in Poland or do you need someone to help out with the logistics?
TLCA Chapter Club
Old 03-01-07, 02:30 PM   #13 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
no sorry, my 1990 FSM is in FL with my FJ62.
Originally Posted by PHAEDRUS View Post
Raven,
that is interesting. I am surprised that they changed it.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 03-01-07, 03:02 PM   #14 (permalink)
treehugger's Avatar
very cool
treehugger is offline   Reply With Quote
Old 03-01-07, 06:19 PM   #15 (permalink)
TLCA# 12112
Nikos,
if you take the electrical connector off you will see four electrical leads.
From the top (closest to the hood) to the bottom the name of the wires are:
VC
VTA
IDL
E2
Legally I can reproduce the page from the FSM. But in summary, here's what you need to do:
1. disconnect the sensor connector.
2. insert a thickness guage between the throttle stop screw and stop lever. (This is on the opposite side of the TPS.)
3. With an ohmmeter, measure the resistance between each terminal.
At 0.0mm clearance between lever and stop screw the resistance should be 0.3-6.3kΩ between terminals VTA-E2.
At 0.77mm clearance between lever and stop screw the resistance should be less than 2.3kΩ between terminals IDL-E2
At 1.09mm clearance between lever and stop screw the resistance should be infinity between terminals IDL-E2
At 'throttle valve fully opened position' clearance between lever and stop screw the resistance should be 3.5-10.3kΩ between terminals VTA-E2
At '-' clearance between lever and stop screw the resistance should be 4.25-8.25kΩ between terminals VC-E2.
TLCA Chapter Club
Old 03-01-07, 09:51 PM   #16 (permalink)
This is a great thread, I am about to tune-up my truck, and I am having trouble getting my truck down to 650 rpm. I will follow your thread and try th cleaning of the AFM and see what happens.
LIfe's short,
Drive Hard!
91' Landcruiser 80 series
2" body lift
32-12.5 Swampers
Hi-lift Jack
Kenwood CD with Hardwired Ipod 40 gig
Infinity 6.5 seperates with Infinity Basslink Sub
Roof Rack
livelarg is offline   Reply With Quote
Old 01-19-08, 01:26 PM   #17 (permalink)
Central Scrutinizer
MoGas's Avatar
TLCA# 17188
I can NOT get a good sight line to the flywheel marks.
92 FJ80 3FE
Dave
Mine: 1993 FZJ80, Classic White.
ARB Commercial, Warn 8274, Aussie Locker, Hanna Sliders, CDL, P7, JD HIRs, Slee harness, Dual Batteries, 850/863, Slee 25mm spacers, SS brake hoses, Norcold 60.
Hers: 1988 FJ62, Red, OME Dakar, Norcold 45, "El Rojo Grande"
1986 4x4 Hilux 22RTE
1965 M416 Trailer.
Copper State Cruisers Member #85
"I would remind you that extremism in the defense of liberty is no vice. Let me remind you also that moderation in the pursuit of justice is no virtue."
Barry Goldwater
MoGas is offline   Reply With Quote
Old 01-19-08, 02:05 PM   #18 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
92 FJ80 3FE
Dave
It is difficult but doable
1988 FJ62 on 33s
1996 LX450 on 33s
Old 01-19-08, 10:01 PM   #19 (permalink)
Central Scrutinizer
MoGas's Avatar
TLCA# 17188
I used an inspection mirror. The fellow aircraft guys know these well.
1965 M416 Trailer.
Barry Goldwater
Old 01-25-08, 10:27 AM   #20 (permalink)
TLCA# 12112
I sometimes view it from the front on the engine bay. I have to move some wires and hoses to get a some what good line of sight.
TLCA Chapter Club
Old 01-25-08, 10:45 AM   #21 (permalink)
TN_LandCruiser's Avatar
I see references to the factory setting of 7* BTDC, and one other that references 11* BTDC...does anyone have input on other various degrees and how it effected their performance AND gas mileage?
Thanks!
1992 FJ80
198k
7 Pin CDL Mod
265/70-R16 Maxxis Buckshot Mudders
OME J's front
OME Heavies Rear
ProComp 9000 shocks
Custom built Rear bumper & sliders
http://forum.ih8mud.com/tn-stlca/198...ml#post2927590
TN_LandCruiser is offline   Reply With Quote
Old 02-23-09, 03:13 AM   #22 (permalink)
joedm's Avatar
hi there,
ok, maybe I'm just going crazy but I looked and I swear I can't find it...
I spent a good 30 mins with my head in that engine bay..
I couldn't find anything that looked like that timing window...
Plus I have another issue..
My cheapo timing light needs to be connected in series with the spark plug and lead from cylinder 1.
I'm guessing I'm gonna have to try and source the FSM.
Anyone know where we can get these in pdf form nowadays? Or portions of it?
joedm is offline   Reply With Quote
Old 02-23-09, 11:11 AM   #23 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
See the second picture at the top of the thread, the panel in the picture is the right side cover of the engine, follow it all the way to the back where the block flares to meet the bell housing you will find the cover/plug for the timing window.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 03-22-09, 08:49 AM   #24 (permalink)
PabloCruise's Avatar
TLCA# 10713
Question, are you supposed to set timing ONLY at 7* BTDC on 3FE and let ECU do the rest, or can you advance initial setting a little?
I live at ~5000' and have timing over 7* BTDC on my 2F for power/vacuum, but not sure if that will mess with the 3FE ECU...
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
CO/WY - Horsetooth 4 Wheelers Cruiser Club
<<CLICK HERE>> for my Tech Threads
PabloCruise is offline   Reply With Quote
Old 03-22-09, 09:42 AM   #25 (permalink)
TLCA# 12112
I have heard that others have played with the timing a little for more power. However, it's a good idea to adjust the MAF sensor also so the engine does not knock.
I have had the timing at 12º before. That was during the winter, then as the seasons changed I adjusted back down 7 because I started to get pre-detonation.
TLCA Chapter Club
Old 11-07-09, 08:53 AM   #26 (permalink)
Rookie
Please help..I'm replacing the distributor on my fj60 but now i can't get the motor going! I did mark the old distributor body in relation to the block with the the rotor facing number1 and the full circle mark lined up with the timing peg. The mark is similar to your pic but further from the fw's outer edge. \before I put in the new dizzy I removed the rocker cover to make sure that no1 had both valves closed and no6 was rocking. However, I'm not sure about the timing mark on the flywheel. Apart from the circle mark, there is also a semi circle mark the same distance from the fw's edge. If i line the new dizzy up with the full circle, no1 is not on compression stroke, so i lined it up with the semi circle which was perfect...but she will not start. Even if i turn the distributor body in both directions while someone else cranks the engine! There is spark and the contact breaker gap is correct. I'm confused... please help...
Johann Botha is offline   Reply With Quote
Old 11-08-09, 07:10 AM   #27 (permalink)
TLCA# 10713
Hi Johann, and welcome to MUD!
A few items:
If you are working on an FJ60 (w/ manual trans) your flywheel will look different than the automatic tranny flywheel pictured. You will have a 2F vs. the 3FE we are discussing primarily in this thread. The 2F and 3FE are very similar. Your flywheel will have a line for TDC and a "ball" or "BB" sticking out of the flywheel for 7 degrees BTDC.
When you have the line or BB in the timing window, and cylinder #1 as at TDC, I believe your rotor should be pointing towards the cylinder #4 vicinity.
Try these out and let us know!
What year is your 60? Where are you located?
Good luck!
TJS
1978 FJ-40
1974 FJ-55 w/ 3FE
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/90392-timing-adjustment-3fe-motor.html
Posted By For Type Date
FJ60 and FJ62 FAQ ********* start here and come back often ********* - IH8MUD Forums This thread Refback 03-08-09 01:42 AM
land cruiser hzj 80 - Forum 4x4 This thread Refback 02-18-09 10:33 PM
Toyota FJ80 Land Cruiser 3FE Resources | Pacific Northwest Backroad Adventures This thread Refback 12-18-07 03:10 AM
