04-24-06, 01:03 AM
| | 250+ Club
| Ramsey winch questions Which Ramsey winches will mount in an ARB winch bumper? Are there some Ramsey winches that are better than others? I seem to recall reading a thread in the 80 section recently where someone mentioned that one series of the Ramseys is "better than anything made by Warn, except maybe the 8274" (I'm paraphrasing).
TIA! |
04-24-06, 10:22 AM
| | Site Addict
Join Date: Jan 2005 Location: Shufflin' Through the Texas Sand
| I think their worm drive winches are not compatible. The Patriot and REP series should fit, but call ARB to be sure. Ramsey builds a great winch...made in Tulsa Oklahoma by folks that know quite a bit about getting stuck and unstuck. I had one on a '77 Bronco that was absolutely indestructible.
__________________ Houston, TX
1997 FZJ-80, factory lockers, OEM 13L subtank, OME-Js, BFG's, ARB, dual batteries, rear seat DVD. Lone Star Land Cruisers |
04-24-06, 11:44 AM
| | Forum Lifer
| Matt,
I've thought about their cheap 9000lb one. It is made in the US unlike the other companies cheap lines. http://www.sams4x4store.com/Ramsey.htm
Their Platinum and Patriot Series winches are very nice even compared to Warn's top of the line. The one problem I've found is price. They don't seem to be as competitive in the upper end on price.
__________________ Eric V. TLCA 7328 ADIDALC LICENSED OVERLANDER
99 UZJ100 "Barnicle Edition" Vorfab front bumper and sliders, MHHS diff drop, ARB front locker, 4x4 labs rear bumper with custom designed swingouts, OME springs/shocks/torsion bars
FJ68 PROJECT LEGO 60body/80chassis
PM me about Wagon Parts FS
"real environmentalists don't pave roads" "dents are like tattoos with better stories" www.WildWildWestArt.com |
04-24-06, 02:17 PM
| | Forum Lifer
| dmc has a Patriot 9500 on his 80 with ARB. Don't know if it required any mods. |
04-24-06, 02:31 PM
| | 250+ Club
Join Date: Apr 2004 Location: Wandering the Western Hemisphere
| Quote: |
Originally Posted by FZJFillmore dmc has a Patriot 9500 on his 80 with ARB. Don't know if it required any mods. |
yes i do. Patriot 9500. It is mounted using a standard winch plate that can be purchased at 4wheelparts or whereever. Winch was mounted to the plate. Then new holes were drilled into the plate to mount it to the ARB. I bought the truck with it mounted that way. So far it has worked just fine. I can take pics if you're interested.
dmc |
04-24-06, 03:05 PM
| | fatherofdaughterofromer
| Quote: |
Originally Posted by dmc yes i do. Patriot 9500. It is mounted using a standard winch plate that can be purchased at 4wheelparts or whereever. Winch was mounted to the plate. Then new holes were drilled into the plate to mount it to the ARB. I bought the truck with it mounted that way. So far it has worked just fine. I can take pics if you're interested.
dmc | Or better yet, crawl all over it next week
__________________ Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon |
04-24-06, 03:22 PM
| | Forum Lifer
| the pics are welcome .. nice .. thanks . !
__________________ HJ-60 2H-T Intercooled Tencha
Cruisers on my mind, blood and soul ! Join us at our local Panamá Off Road Forum Quote:
Originally Posted by crushers if you are achieveing the max boost then it isn't the boost that is going to kill your engine... it is your right foot. | |
04-24-06, 03:31 PM
| | Forum Lifer
| Platinum 9500 will fit in an 80 ARB without issue
__________________ "Knowledge without experience is just information"--Mark Twain Copper State Cruisers #003 |
04-24-06, 04:37 PM
| | 250+ Club
| Cool. DMC, you're coming to Moab? I will be checking out your winch set-up for sure! |
04-24-06, 05:45 PM
#10 (permalink)
| | 250+ Club
| Planetary winches should mount fine, though Im not sure to what size. The Ramsey worm gear winch can be successfully mounted with some adaptions. Check out the following link: ARB bull bar and Ramsey RE12000 fitment
Cheers.
__________________ - '95 FZJ80, factory locked, 12000 lbs worm gear winch, ARB front bumper, custom rear bumper and sliders, on board air, bosch ralleys, Pin 7, and a few other goodies...
- Practice your offroad skills in Penticton. Good wheeling here. |
04-25-06, 12:31 AM
#11 (permalink)
| | 250+ Club
| So what are the benefits of worm gear vs. planetary? Is one more bullet-proof? |
04-25-06, 10:25 PM
#12 (permalink)
| | 250+ Club
| Among other things, the main benefit is its strength. The bad that offsets the good include slower speed and unusual mounting style. This winch (powered in the hydraulic motor form) is an industry standard for commercial haulers and tow trucks.
Cheers.
