Old 12-25-03, 11:34 AM   #1 (permalink)
Steering Spindle
I bought a 95 and repacked the steering knuckles. I noticed that the bronze bushing in one of the steering spindles has been turning in the spindle. It's supposed to be pressed in. I didn't think it was an emergency so put it back together but ordered a new part from ToyotaParts.com. The new part has a combination bronze bushing and needle bearing (i.e. very small rollers). Before I take the knuckle apart I just wanted to confirm that this part is an inkind replacement with a design upgrade. Anybody been down this path?
malcolm is offline   Reply With Quote
Old 12-25-03, 11:57 AM   #2 (permalink)
Supporting Vendor
sleeoffroad's Avatar
Re:Steering Spindle
Did you order a new spindle or just the bushing? New spindles come with roller bearings. However you can purchase the brass bushing on it's own and just replace that.
sleeoffroad is online now   Reply With Quote
Old 12-25-03, 08:51 PM   #3 (permalink)
Steering Spindle
I was concerned that the ID of the spindle may have been machined out so that I wouldn't get a good press fit if I bought only a new bushing. The bushing is like 70 USD but the bushing and spindle assembly is 200 USD. I didn't want to buy a bushing then discover I had to then get the bushing spindle assembly.
Thanks for your reply, malcolm
Old 12-26-03, 08:49 AM   #4 (permalink)
Supporting Vendor
cruiseroutfit's Avatar
TLCA# 10662
Re:Steering Spindle
$200 isn't a bad deal for the spindle/bushing/bearings... I would rather have more than enough parts to do the job...
Any pics of the bushing "turning into the spindle"?
cruiseroutfit is offline   Reply With Quote
Old 12-26-03, 09:59 AM   #5 (permalink)
ThinkTank Waterboy
landtank's Avatar
Steering Spindle
I'm planning on going to the new style spindle on the next axle rebuild. The brass bushings will have @160k on them. I've already had a problem with one going dry and it seems that in a AWD setup and the shafts turning constantly that the needle bearings are worth the expense.
landtank is online now   Reply With Quote
Old 12-26-03, 08:22 PM   #6 (permalink)
Re:Steering Spindle
I could see galling type marks where the shaft had grabed the bushing and spun it. The inner seal leaked and 90w apparently washed the grease out of the knuckle. Now I look at the knuckes for signs of oil leakage. I'll put the bearing spindle in and let you know how it went.
Old 01-03-04, 05:50 PM   #7 (permalink)
Steering Spindle
I installed the new spindle in my 95 and it seems to work fine. The new variety has a bearing in it rather than just the bushing. It runs fine and a minor clunk I had on occasion seems to have has gone away. It took about 2 hours to change it out.
