04-10-06, 10:19 AM
always broke
3FE Owners Check-In
Everyone on here that has the rare and ultimate 3FE equipped 80 post here, and don't forget to mention any 3FE specific junk you've done!
Hopefully this will make it easier to find other 3FE owners to ask for help, etc. when that rare problem arises!
RE-Edit: aw hell, chat away, just give me enough info to compile it to a "database" type arrangement so that I can make a thread with everyone who has done what and who just owns the beastiest 80's
Vehicle: 1991 and 1992 FJ80's
Location: South Central North Carolina (Right near Uwharrie Nat'l Forrest)
3FE Junk: 1) Custom 2.5" Exhaust (pics to come)
2) De-smog (in progress, write-up to come)
3FE Issues: Coolant Loss (plastic tank crack, suspected rear heater and engine bay by-pass hoses)
04-10-06, 10:22 AM
Vehicle: 1991 FJ80 "The Pinnacle of Land Cruiser development"
04-10-06, 10:40 AM
Location: Indy,IN. But currently on the road: SoCal,NV,AZ,NM.
Vehicle: 1992 FJ80
De-smogged
2.5" lift
Extremely intimate with the following:
Tranny [A440F]
Coolant system - each and every component replaced
Dash - removal and install for the above
Carpet - removal and install for cleaning
Timing of engine - How to...
Throttle body cleaning
Brake booster and brake system - replace
front and rear diff overhauls
EGR system - track down a no vacuum problem
Rebuild engine
Fixed sticky hand brake system
Reason: Updates
04-10-06, 11:16 AM
Dave Callister,
92 fj80, only 3fe specific is for the valve adjustment.
unfortunately the 3FE in mine is getting ditched for a 1fze in the next few months, It will be a sad day.
oh yeah I am in Salt Lake City (technically West Jordan)
Dave
"The time has come" the Walrus said," To talk of many things.."
In the Trees.... OH
80 fj40, 2.5 OME Dakaar springs, 33" bfgs. "Charlie Brown"
88 fj62 Bone stock, Daily Driver, Bone stock. "Moby"
04-10-06, 11:35 AM
91 Desert Sand, Emissions removed, MAF header, full mandrel bent exhaust 2 1/2 to 3" after muffler. Currently looking into a "RV" type cam, and an extreme valve body.
Pictures: http://forcedinductionz.50megs.com/cruiser/
01' LX470, 285/75/16 BFG KO T/A, Stock, 73k 03' Honda CR500AF 08' Aprilia SXV 550
04-10-06, 12:11 PM
'92 FJ80 in Western MA. Messed with alternator (isn't that completely unique? The older 62s and the 93+ are different), starter (how the ^!@%! DOES ONE PUT THE RUBBER PLUG back in?), exhaust, seats, carpets, transmission shifter), speedo cable, thermostat and dash (different bulbs). Evertyhing else I did was pretty much the same as my '94. Still to come is the VSS and cruise control.
'92 FJ80 stock | '94 FZJ80 not stock and currently *down* | '08 Tundra Grade DCSB 4x4 5.7
04-10-06, 01:37 PM
Rookie
1991 check in
1991 bone stock 118k miles. Birfs done at 95k. Replacement radiator not OEM, at 100k then again at 101 k. I will go with OEM next time. No rust. Oh yeah, igniter replaced at 110k. New starter also . And the infamous relay fix. Need ds rear window fixed, glued to the top and non-operational.
04-10-06, 05:04 PM
'92 original birf's no clicks tho, no cats and flowmaster exhaust with pipe cut off after the muff. new rear axle on one side and all new seals. sig line says most of the rest.
'92 "The Albino Tractor" D.D. 239K, now with 4BT POWA! 700R4, ARB/Slee6" 37"IROK, PG 4.88, SROR sliders/rear bumper/QP armor, J-Moose roofrack, Dual Batts
To Come- FF Rear installed, Locker, Intercooler installed, and Fhodeez on 20's
-Official Thread Killer
04-10-06, 06:21 PM
My sig. line sums it up.
forced,
Could you give some more details on your exhaust set-up? Do you like the MAF header? What kind of muffler? Noise level overall? Noticable performance increase?
Brad
91 FJ80 AKA- Landsnoozer
George's front and rear dome lights
Slee headlight harness and aux. harness
Mot's fog lights
285/75/16 BFG AT
04-10-06, 08:19 PM
#10 (permalink)
Location: Usually in the house, sometimes in a tree or a tent or a boat
92 with 179k pretty much stock. Did the belt replacement thing this last weekend. As far as i know its all original A doctor in Salt llake City had it before me. I just drive it. when it breaks i fix it.
92 fj80 222K
98 4 Runner Ltd 150K
When its time to shoot, Shoot, Don't talk
04-10-06, 08:25 PM
#11 (permalink)
’91 bought in 93 (for book value $$$)
3FE Specific:
Throttle body bored 3mm over by RC Engineering (RC Fuel Injection ) Need to optimize Air Flow sensor to get the most out of it
Jacobs Off Road ignition (waste of money/too lazy to remove)
Dual Batts ( Dual Batts on FJ80, ANYONE?????? - Page 2 - IH8MUD.com )
Delco 100 amp Alternator (custom bracket)Alt from any 94/95 GM truck fits and is easily upgradeable to <200 Amp
2.5” exhaust w/magnaflow
Heavier gage wiring for fuel ignition relay
Mods:
Newfield Birfs--replaced again (clicking) less than a year after install- CV Remanufacturing hooked me up for free
’94 rear FF/Disc Brake axle and an ARB locked FJ60 3rd member installed.
4.56 gears
GM auto-leveling Air pump to run ARB
Sanden OBA in place of smog pump for tires and back up ARB air
Build HD rear bumper/receiver/tire carrier
ARB Bull Bar w/ 9000#T-Max trimmed and tucked 2 5/8" closer to the body
Local “master fabricator” (Vorfab) made sliders
2” front coil spacers (between bump-stop/spring and frame mount) also made by Vorfab
OME850 Heavy front & OME 860 Medium rear springs (w/1 trim packer ea)
OME firm shocks front & rear
Slee extended brake lines
315/75/16 BFG/ATs
Future Mods:
Replace/Remove? Cats
Past Problems:
Fuel ignition relay wiring
OEM Birfields
OEM Alternator burnt up 4 years ago. Replacement NAPA one fried 4 times in 4 years at most inopportune times
OEM CD player quit—Replaced with JVC mp3 player, Pioneer AMP, pioneer Speakers, and CB radio in empty slot
Body half clearcoated, half pealed
Greg
'91 FJ80
315/75/16s, OME Heavy/Med lift, 2" Vorfab front spring plate spacers, Dual Batts, Tucked/toughened ARB Bull Bar, 9000 lb T-max, Home brew rear bumper W/2 swingouts, Bored throttle body, '94 FF rear axle, ARB LockeD F&R, 100 Amp Delco Alternator conversion, Dual ODA Electric & Sanden
04-10-06, 08:30 PM
#12 (permalink)
-As-
See my Garage in my sig line..........
Eric Hagan - Auburn, AL
94 - Scallywag (noun) a deceitful and unreliable scoundrel
04-10-06, 08:31 PM
#13 (permalink)
92 FJ80, and I believe I am the champ so far with 220K on this high powered beast. Birf's done a little while ago, new PS pump, clogged valve cover wouldn't let the PCV system work and oil, oil, everywhere! Took a couple grand to figure out that one. Ugh.
Oh yeah, Mot hooked me up with rear LED's, clear blinkers/side markers, and Cdan took care of the front corners. Ripped the ghetto fabulous step bars, sissy crash bar, bug shield, window shields, and sunroof shields from previous owner (what was it with him and shields??) And now, it's starting to look cool.
Managed to stop a Dodge 1500 the other day when he couldn't seem to, and now I need a new rear bumper, any suggestions?
Oh yeah, burns no oil, PS fluid, coolant, or brake fluid.
Richmond VA or thereabouts.
-Jared
'92 FJ80 with rear LED's, clear blinkers and side markers(thanks MOT) and clear corners (thanks Cdan!)
'99 100 series with ARB front and big OEM fogs (thanks again Mot!), Slee diff drop, OME lift.
04-10-06, 08:46 PM
#14 (permalink)
'91 FJ80 W/ 243,000 miles (which now makes me the champ I Believe!!)
OME 3" lift , heavy duty front swaybar, adjustable panhard bars front and rear, HD tie rods, extended S.S. brake lines.
Just rebuild knuckles w/ new wheel bearings, Experienced the PITA timing, replaced fuel injection manifold and injectors.
Cats have been removed
Today I adjusted my valves and rebuild P/S pump since the woodruff key became shrapnel.
Tomorrow paint valve cover and put it back together!
Brian
BFletch
'93 4Runner - 3" Suspension lift, 32" Cooper SST, Custom Sliders and front bumper
04-10-06, 08:51 PM
#15 (permalink)
Gonna go ahead and ignore the no chat order... Damn Bfletch, you took me down man. Only because I bought the 100 tho, I've put about 50k on it in the last year and let the 80 sit idle. Don't worry, I'll get you yet!
How have the exhaust mods helped with power? I'm ready to cut the cats and put the MAF headers on tomorrow if it'll help at all.
04-10-06, 09:54 PM
#16 (permalink)
1991 FJ80 197k miles
Pretty much stock...Will be adding lift, bigger tires, arb bumpers rear and front, fog lights, roof rack...and more. Bought it next to nothing after a mechanic told previous owner repairs will run him into thousands...took the chance bought it, replaced starter and voila!!! works ....runs like a champ!!!
Bought it about a week ago...got around it yesterday hooked up new starter and belts....and today I left my 4runner at home....and drove it to commute to work ....I am in heaven!!!
Planning on driving it down to patagonia argentina in about a year!!!
04-11-06, 03:30 PM
#17 (permalink)
[QUOTE=TiredIronGRB]Vehicle: 1991 FJ80 "The Pinnacle of Land Cruiser development"
Echo that!
Stock 91' got it 5 years ago @62k miles, currently @94kmiles. Only problems I've fixed myself are the passenger side window getting disloged, adjusting throttle cabe and the kick down cable & tweaking front bumper back into shape. I hope have'nt just jinxed her.
91' tlc white kinda stock w/33x12.50bfg mt's.ome2.5" lift & arb up front 2nd owner 119k
85' toyota 4x4 truck orig. owner. 160k sold after 22yrs.
04-11-06, 06:05 PM
#18 (permalink)
91 fj with 3inch ome,arb,and snorkel 181,000 on the clock
needs valve adj,birf,r axle oil seal other then that i wheel it every weekend
04-11-06, 07:06 PM
#19 (permalink)
91' FJ80
My 3FE is in bad shape right now. Bad oil leak, probably pan gasket, blown o2, PS gearbox leaking. Been out of work for past few months now I have 2 jobs so project cruiser is in effect. Also my hood has clear-coat failure all over it.
Things I've done, pretty much is valves, birs, pinion seal, new batt, brakes, which I'm overdue for now
Nick Martinez
TLCA # 14984
07' Tacoma PreRunner 5spd Brought home 12/29/06
05' SR5 Tacoma Brought home 4/24/06 Flipped 12/06/06
1991 FJ80 155k - Traded in 4/25/06
04-11-06, 08:37 PM
#20 (permalink)
92 with 87k, got it last month. getting plugs, cap, rotor, wires, belts, and hoses this week. Planning the birfs this summer, knuckles are starting to look bad, no clicking though. Has anyone had their transmission flushed? Did you use a dealer or somewhere else?
Brian
71 FJ55 - Stock for now
05 Highlander
04-11-06, 09:07 PM
#21 (permalink)
always broke
Changed my mind, and am gonna make a database out of this thread for the FAQ on who to ask for what, etc.
Bird, no need to power flush the tranny. Just drop the pan and clean it out, put in more/new magnets if you wish, and fill 'er back up with some good lube of your choice. This bus tranny USUALLY doesn't have any issues (knock on wood). Glad to see there are more black sheep on this forum than I thought! 3FE POWA!
04-11-06, 09:28 PM
#22 (permalink)
Love my 92. Just rolled over 100K in February. Hope to see it roll over a couple of more times before major service. Relatively stock w/ exhaust mods and a few bling things. Repainted original 4K1 color, clean and unblemished, inside and out. Anally maintained mechanically including synthetic fluids and grease throughout.
Thinking about possibly doing some tweaking on the head in the fall (shave, grind, and port/polish) to give it a little more testosterone. I have a bud that works at a machine shop.
And more important, the 3FE fraternity also has the best avatar on the board....
JKLubens your avatar is the clear winner
92 FJ80, 120K, Duals w/ FlowMaster catback exhaust, 31" Tires;
87 FJ60, 101K, Not Quite Stock, Just Broken In; 87 FJ60, 238K, Stock, Project Truck (FOR SALE); 88 Chev K1500, 138K, 4x4, 350, Headers, duals w Flowmasters, Rear Locked, 33" tires.
04-12-06, 02:24 AM
#23 (permalink)
fixes
'91 FJ80 Ms. Piggy 171,000
So far, in the 5 months Ive owned her-
Aftermarket radiator(all brass) water pump, power steering(aftermarket) rear main, front crank seal(3x by dealer and still leaking) oil pan and valve cover gaskets, new longfields, axle shafts, drive plate,side gears. The dealer bent me over on the seal thing, replacing the plate behind the timing gears(n00b me!). Took same stupid dealer 3x times to run valves right, under warranty.
Still to do: u-joints x4(thanks C-Dan for good price), non working rear pass window, cruise control problems, Clunks, and pesky damn oil leaks.
Happy with the radiator, 8000 trouble free miles so far, and the stock ride, performs in snow and ice well, but I have twice what she is worth tied up so far, with little end in sight. How can I stop the madness?
NEVER NEVER NEVER buy from a doctor on ebay!!!
04-12-06, 09:12 AM
#24 (permalink)
'91 "5Runner" @ 135,000 miles
Maintenance/repairs: head gasket, radiator (2X), thermostat & various sensors, alternator, brakes (& LSPV), birfs, window regulator and various wiring.
Modifications: OME Heavy suspension, 33x12.5 BFG/AT on black steelies, re-geared to 4.88, ARB lockers F&R, swaybars removed, flares removed/holes braized, Safari snorkle, ARB front, IPF, Kaymar rear, 9,000 winch, brake controller & 7-pin harness, george's LEDs, JDM grab bar, 2nd & 3rd rows removed and floor covered in labrador fur.
Needed: valve adjustment, injectors, CC actuator, cat
04-12-06, 01:31 PM
#25 (permalink)
92 80 with 265K. Original Owner. Completely stock..!!! I am in Central Florida.
04-12-06, 04:25 PM
#26 (permalink)
1990 FJ80
3F-E Engine - Rebuilded
Custom Exhaust
A440F tranny
No lockers
OME 2.5 lift
BFG M/T 35x12,5R15
04-12-06, 05:13 PM
#27 (permalink)
1991 - 225K miles or so, can't really remember it keeps on running
In the last three months:
new brass radiator, new hoses, belts
New cats waiting for break in the rain to install
New 02 sensors, see above
OME medium 2.5" lift
Alpine w/aux input for GPS/MPS/XM
DELL Axim X5 for GPS
Kelly M
Menlo Park, CA
1991 FJ80 - 225K 3FE power going strong but slowly, diesel conversion in the future?
04-12-06, 05:38 PM
#28 (permalink)
K&N and new OEM O2 sensors(problem area), tune up and fluids. That is all.
See sig line.
05-10-06, 10:54 AM
#29 (permalink)
_
Stock 1992 FJ80 with 263k+ reliable miles.
96 FZJ80 | 97 FZJ80
05-11-06, 02:57 PM
#30 (permalink)
91 FJ80 w/ 137K miles in Afton VA.
Future trail rig once my kidneys give out from driving the 40.
Mods: small dent on the passenger side fender where the wife hit a deer. Actually she was driving up the mountain so the deer probably hit her
In the market for a passengers side marker light if anybody has one to sell.
