12-17-03, 07:56 AM
Winch
Do you guys think that a warn 9500 is strong enough for the 80? What is the concensus on what strength winch you need for an 80?
12-17-03, 08:56 AM
Winch
PO put a Superwinch X9 (9000lb) on my truck. It's been fine for pulling people out of snow or simple stucks, but I would feel a looooot better with a 12k.
12-17-03, 09:28 AM
Supporting Vendor
Re:Winch
I have a 8000lb on the ShortBus. The truck weighs about 5700lbs. I have pulled it out of all kinds of situations rocky trails and snow and it has worked fine. However, I doubt it would pull it out if it is stuck in a mud bog.
I went with 8k for the weight saving on that truck and what it is used for. However on the Schoolbus I run a 12k winch. It all depends on what you are going to expect the winch to do.
12-17-03, 10:33 AM
Winch
An extra $200-$300 for the Warn 12K is cheap insurance.
12-17-03, 10:49 AM
Winch
[quote author=FZJFillmore link=board=2;threadid=8889;start=msg76872#msg76872 date=1071676587]
[/quote]
The X9 and S9000 are 11900lb units... they are rated at 9k because of the cable size. Compare the specs of them to the Warn 12k.
12-17-03, 12:57 PM
Winch
Like Slee said Short of being in a mud bog buried to the frame you'll be fine....
I have a XD9000i Warn on my other full size about 6300 lbs loaded. Get a snatch block and accy's and do double line pulls when you think the motor will have to "work' to get you out.
Pokemon (who can drive to Warn ind in 20min.)
12-17-03, 01:47 PM
Winch
[quote author=Pokemon link=board=2;threadid=8889;start=msg76948#msg76948 date=1071691025]
[/quote]
You live in Portland or the 'Couve? I live 2 min. from the Warn Estate
12-17-03, 02:20 PM
Winch
[quote author=bjowett link=board=2;threadid=8889;start=msg76906#msg76906 date=1071683354]
The X9 and S9000 are 11900lb units... they are rated at 9k because of the cable size. Compare the specs of them to the Warn 12k. [/quote]
Specs don't tell you the whole story. I know because I've had two of each. Pull them apart and you quickly realize the X9 is pure dog crap. Rotten hardware, rotten everything. X9 is a total POS.
12-17-03, 04:01 PM
Winch
yeah, but will they let you in the estate?
12-17-03, 04:17 PM
#10 (permalink)
Winch
[quote author=Junk link=board=2;threadid=8889;start=msg77004#msg77004 date=1071696029]
[/quote]
Please elaborate a bit more.... I have not found much build info on the Warn models. The X9 uses a decent Iskra motor w/ ball bearings, needle bearings in the single stage planetary gear box (look up planetary gear systems to what works and why). About the only problem I have heard about with the Superwinch X9 was the lack of sealing gaskets on the earlier model motors. This allowed water to enter.... the rest is history. I've seen a Warn Winch do this, also.
12-17-03, 04:48 PM
#11 (permalink)
Merchant of Death
Winch
[quote author=firetruck41 link=board=2;threadid=8889;start=msg76971#msg76971 date=1071694069]
[/quote]
The last Warn(Mike) sold the company in 2000, to a bunch of venture capitalists, they sold it in 2003 to Dover Industires.
one of the Warns also has a flooring(like tile and hardwood) company in WA, forget the name but its a big wholesale outfit
John H (full of worthless info)
12-17-03, 05:18 PM
#12 (permalink)
Winch
Since you guys are on the topic of winches, what do you think of the warn 8274?
I've just got an ARB commercial bar and i'm trying to figgure out what i'm going to fill the giant hole with.
-Bryan
12-17-03, 05:25 PM
#13 (permalink)
Merchant of Death
Winch
[quote author=Mr.Bryan link=board=2;threadid=8889;start=msg77077#msg77077 date=1071706739]
-Bryan
[/quote]
IMOP there isnt a better winch then the 8274, I have 2 of em, one on a 45 and one a 40, LOVE that winch. On the 60 its a 10k warn, 80 is a 12k warn, I think they are a bit better suited to the weight of the big wagons, but I wouldnt' have issues running a 8274 on either of them, If you already have the commerbar I would so the 8274-50.
12-17-03, 10:03 PM
#14 (permalink)
Winch
[/quote]
Ben, I live directly on the other side of the Columbia River from you. The last town before the start of the Columbia River gorge scenic area. Troutdale, Or.
Bryan, the 8274-50 is good choice as well. The line speed is excellent on these winches, It's by far the best in an 8-9K winch.
But the new price might be awful close to the 12K Warn, soo...
12-18-03, 05:56 AM
#15 (permalink)
Supporting Vendor
Winch
-Bryan
[/quote]
No doubt the 8274. I love that winch. I still have my dad's from 1972 vintage. I ran that on a commercial bar on the blue 80 and never had a problem.
12-18-03, 06:09 AM
#16 (permalink)
Admin
Re:Winch
I've been winched around by most every brand out there....not sure that's a good thing, but I've formed opinions...
Superwinches are slow....very....I could have run a snatch block and righted myself before that thing had me halfway off the ground....
Ramsey's don't impress me either...a friend went thru 3 one summer, non held together. I also recall their design on the new models allowed the cable to bind between the spool and housing and split the case.
MileMarker electrics....worse than the Superwinch for speed...pathetic...unloaded, loaded, line out, etc....useless. I'd rather use a comealong...
I've by far been most impressed with the Warn for speed and reliability.
Speed doesn't SOUND like a big deal....but line speed when you are respooling the cable is nice when the weather sucks and you are the one standing out there taking care of it. Line speed is nice when you are using the rig to assist with the pull, since you are much less likely to overrun the cable and cause it to wrap loosely and get damaged on the drum. Line speed is wonderful when you are upside down and want to get yer junk righted quickly, saving as many fluids as possible.
I've got a old 1974 Warn Bellevue on the garage floor that works awesome....manual brake and everything. Loved that winch, but no power out option...so I replaced in 2002 with an 8274-50 and have zero complaints.
12-18-03, 08:44 AM
#17 (permalink)
Winch
The Superwinch can be slow, but it is faster than the Warn 12k up to about 4 or 5k lbs. no load 32 vs 30 FPM, 2k lb 18 vs 14 FPM, 4k lb 9 vs. 8 FPM... then the Warn starts to go past.... probably twice as fast at 9k pounds. The Warn costs over twice as much. Bang for the buck, the Superwinch is hard to beat in many ways. Priorities are different, though.
Let's face it, just about any 8k lb+ winch will get a Landcruiser out of 90% of the messes one is likely to get in on. How long it will last is another question that probably can't be answered easily.
12-18-03, 09:19 AM
#18 (permalink)
When In Doubt, Go Higher!
Location: Port of Indecision...otherwise Northern Arizona
Winch
My Ramsey Rep 8K is 9 1/2 years old on its third vehicle and it works great for moderate self recovery and getting the occasional errant vehicle unstuck. Picked it up for $399 new...
That being said, for serious recovery usage....go with the Warn 12K.
-H-
12-18-03, 12:42 PM
#19 (permalink)
Winch
O.K. so the 12K or the 8274. I know the 12K means 12K pounds but what about the 8274? And more importantly, what will fit in a ARB bull bar? I thought the 9500 was the largest that would go in there. ??? I guess i need to read up on my winch specs better.
12-18-03, 04:16 PM
#20 (permalink)
The quick brown fox .....
Re:Winch
CJ,
You have to have the ARB Commercial winch bar to use the 8274.
-B-
12-18-03, 04:37 PM
#21 (permalink)
Oh...Durka Durka Durka.
Winch
[quote author=concretejungle link=board=2;threadid=8889;start=msg77414#msg77414 date=1071776563]
[/quote]
8274= 8 thousand pound winch
2 directional power (in and out)
74 year that it was designed and put into production.
As per WARN.
ARB makes a bull bar for the wagons that uses the 8274-50, it is not the same as the bars used for the low mount 8, 9, 12 or 15K winches.
Good luck!
-Steve
12-18-03, 05:50 PM
#22 (permalink)
Winch
Well, since the 8274 has gotten such wonderful reviews, its hard to say no, my only concern then would be power. For the majority of the wheeling (99%) I do it wouldnt be a problem, but everyonce in a blue moon i'll get stuck in mud. I'm not going to be in any humongus hurry to get the truck out, so setting up a snach block wouldnt be a problem, I'm just wanna know if the winch would be the best option, or should i spend the extra $150 or so and get a 12k? Opinions?
-Bryan
12-18-03, 06:24 PM
#23 (permalink)
Winch
12K
12-18-03, 06:32 PM
#24 (permalink)
Winch
8274 (24V if you can  ) Awesome winch.
Stuck in mud like this?
60 loaded for 2 wks of camping (heavy) - not mine...
Yep, dragged it out (mate's), the other tyre marks going down the left side of the picture are from dragging another mate's LWB patrol and trailer first (loaded for 2wks)
Both winched out - single line pull, synthetic rope, on my 24V 8274 on my pissan patrol shorty.
george.
12-18-03, 06:41 PM
#25 (permalink)
Re:Winch
You could always figure out what it would take to run the new M16.5ti...
12-18-03, 09:59 PM
#26 (permalink)
Winch
Concrete,
I greatly prefer the M12k over the X9, but I would probably go for the commercial bar + 8274 vs the arb + 12k. I know that's hard to imagine since I always say go for the most pull, but the 8274 comes with 150' of cable which means you can double line pull further. There was a study of them about 2 years ago, comparing them to the 12k and others and the 8274 did quite well. There are some good mods you can do to the high mounts and there is a better market for them used. Overall, it's pretty much just about equal either way.
I would heavily vote against the X9 though, unless you want to buy used one.
12-18-03, 10:05 PM
#27 (permalink)
Winch
Just remember, it would really suck to be in a bad situation and your winch not be enough to get you out.
The below buggy is on 42's, and that's the mild section of the trail. That's the trail I snapped a birfield on during Memorial Day this year, and needed a tug from the X9 (mounted in front of the rear bumper) and it let me down. That kind of sucked.
12-18-03, 10:37 PM
#28 (permalink)
Winch
18Dec2003 (UTC -8)
I have the M12000 on the HDJ-80, and it's been a very faithful beast. However, on the lighter FZJ-80, I got the Warn 9500ti 'coz it's waterproof and faster than a 24v M12000.
Wanr is marketing the 9500XP, as the *new* competition winch with continous duty solenoids. I wonder how good it really is in the real world ?
12-23-03, 10:50 AM
#29 (permalink)
Re:Winch
Get the commercial ARB bar and the 8274 and never look back! Don't even worry about the power and all that crap! 8274 is known as the work horse of the industry.
Ali
ps remember to size your front coil springs accordingly for the extra weight.
