Old 03-23-06, 01:44 AM   #1 (permalink)
tech_dog's Avatar
Simple dual battery approach?
I've been looking for a dual battery solution with less complexity than most I've been seeing. I haven't seen anyone discuss this particular option, so I'd like to throw this out for public scorn. At first glance, it seems like it may be a very simple and effective solution.
Here's the schematic:
The Blue Sea L-series LCR is a relay that closes when either high current terminal is at 13.4 volts or greater, i.e when the vehicle is charging. Otherwise, it is open. It sells for about $150 and is rated at 450+ amps, depending on wiring gauge used.
Without the control switch, the batteries would both be charged whenever the alternater was working. The second battery would be isolated if the alternator were not generating, so you could run the winch on the isolated second battery by shutting down the engine.
Adding the control switch lets you manually open or close the relay, or leave it in the automatic mode described above.
The manually open mode allows you to isolate the second battery and winch with the engine running.
The manually closed mode allows you to use the second battery for emergency starting, or use both batteries to get home without a working alternator.
Advantages are:
o minimized length of fat, high current wiring
o no required cutting into the stock wiring
o no need to pull an "alternator good" signal
o only one small relay required (about 2" x 2.5")
o very high amperage capabilities
o supports most use/charge combinations, except those listed below
o fewer points of failure
o comparatively cheap
Disadvantages are:
o Can't run winch ONLY off of battery #1 (it's both or #2)
o Can't charge ONLY battery #2 (it's both or #1)
I think these are fairly small inconveniences.
You could also add another battery switch between battery 2 and the winch if you want to disable the winch when you're not using it, but I prefer the total simplicity of what I've got drawn above.
Blue Sea makes a control switch for this, but you could use any switch that provides +12 for closed, ground for open, or floating for automatic mode. I'm not sure if any stock Landcruiser switches can be modified to provide these three conditions but I think it's likely. Any ideas on that one?
Note that I didn't show the ground connections, but for each componant you'd have to hit the closest appropriate ground.
I also showed the control switch being powered off of the relay terminal, but you could pick up +12 from any convenient location. The switch wire current is very low, so you can use a thin wire and put the switch anywhere you like.
Comments?
1994 FZJ80 - Original Owner, dual battery, 2.5" OME Heavy/Medium, 295/75/16 Terra Grapplers, Slee front and rear bumpers, dimmable Lightforce 170s, Hanna Sliders, Slee transfer case skid plate, Warn 9.5XP, LED interior lights, Slee interior spare tire carrier, yellow box, orange dot mod
2006 LX470 - Original Owner, Daily Drive, no mods
tech_dog is offline   Reply With Quote
Old 03-23-06, 02:02 AM   #2 (permalink)
Mickldo's Avatar
Looks similar to the ARB Smart Solenloid setup and the Redarc Solenoid. They are a very good system that is fully automatic. Can't really go wrong with a system like that.
90 HZJ80 GXL, DTS turbo, 285/75R16 MTR's, 4" OME, Safari snorkel, ARB airlocker, ARB bullbar, ARB dual pivot rear bar, dual batts, etc.... SOLD
99 HZJ105R GXL standard for now.....
Mickldo is offline   Reply With Quote
Old 03-23-06, 09:58 AM   #3 (permalink)
IH8MUD Lifer - No Appeal
Mike S's Avatar
I used the BluSea ACR (Mechanical) set up on my 60 with two Optima Yellow Tops. The manual switch was a marine grade unit and fit into the knock out to the right of the steering wheel. I am sure that Cole Hersey would have a switch that works on an 80.
I was very happy with the performance, and never had any issues - cycling or failure to switch on command. Good stuff. I'll probably do a similar set up on my new-to-me FZJ80.
M
'96 FZJ80, locked, Hanna sliders, ARB bumper, Kaymar rear with spare carrier, 45 gallon Longranger aux fuel tank, OBA, Hella 4000's, OME lift, 285/75/R16 Revos & AutoHome Maggiolina rooftop tent, etc.
Custom Cruiser trailer with OverLand tent
www.AutoHomeUS.com
TLCA Member #14874
Mike S is offline   Reply With Quote
Old 03-23-06, 10:19 AM   #4 (permalink)
tech_dog's Avatar
Fantastic. Thanks for the validation.
This forum has got to be one of the most useful things on the entire internet.
Tom
Old 03-23-06, 10:46 AM   #5 (permalink)
FloridaFJ80's Avatar
What kind of control switch are you talking about, anyone in particular? I am interested in doing this to my FJ80. Maybe you can do a write up on doing this particular setup and maybe get it added to the FAQ's....
FloridaFJ80 is offline   Reply With Quote
Old 03-23-06, 11:42 AM   #6 (permalink)
Newps's Avatar
TLCA# 15243
tech_dog, I like it. I am currently investigating options for Project 80's duel battery set up. I may use this set up in my article and on Project 80. The only item I would change is a way to discount the winch via another switch.
Tare
Tare
1999 4Runner, 2x4 my daily driver.
2001 LC-100, wife's ride for now.
1994 FZJ-80, Slee 6-inch, ARB bumper, Hanna Sliders, 4x4-Labs rear bumper, WARN 12k winch, ARB lockers F&R, 37-inch Krawlers.
www.IronCrossOffroad.com
Newps is offline   Reply With Quote
Old 03-23-06, 11:58 AM   #7 (permalink)
Dumbass rookie dough-head
Hants's Avatar
TLCA# 13790
I'm also in the planning stages of a dual battery system.
Running the winch while in "auto" mode on the ACR will likely cause cycling. Switching it to "on" should resolve it.
I second adding a switch to kill power to the winch (prevents knuckle-heads from *icking with you).
You should consider upgrading the grounds on the OEM/primary battery if you're installing a winch or other high-draw accessories.
I've heard opinions both ways about fusing the high-amp positive between the batteries. I will likely run mine in the galley behind the radiator. It will be in a risky position in case of a frontal collision, and will have a battery at both sides. I'll likely fuse mine at both sides -- I'm not a fan of car-b-q's!
1997 LX450, 132K, Lockers, LEDs, Nak-o-matic mic holder, CDL w/ Pin 7, 285/75R16 BFG AT, Tool Sleeve, Slee armor, Slee speedo gear, OME 2.5" Heavy, Prophylactic HG, Line-X in place of LX trim
KD0CXL
"You don't get to vote on the way it is... you already did!" But you do get to vote on the way it will be.
"... but you have to compare it to the current political process where idiots elect liars to transfer wealth to crooks." -- Scott Adams
"Damn you, Hants White!" -- Dan-The-Man
Hants is offline   Reply With Quote
Old 03-23-06, 12:27 PM   #8 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
that is pretty much the same sutup I did, except I did not use the auto sensing relay I used a regular blue sea solenoid and I used the altenator good signal.
I was worried about cycling with the ACR.
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is offline   Reply With Quote
Old 03-23-06, 12:40 PM   #9 (permalink)
The quick brown fox .....
Beowulf's Avatar
Originally Posted by tech_dog
Advantages are:
Getting "Alt good" on your FZJ80 is trivial and well documented.
-B-
97 FZJ80 - Locked, 315 Toyos, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers + other stuff. Transformation complete.
Old 03-23-06, 12:43 PM   #10 (permalink)
Beowulf's Avatar
What fuse rating and style?
-B-
Old 03-23-06, 12:49 PM   #11 (permalink)
sjcruiser's Avatar
My plan is the same as yours plus the addition of a 4-way switch just in case the main battery needs a jump.
Frank
'97 LX450 - Triple locks - fully loaded
2.5" lift OME851/860 springs + Bilstein B46-1477/1478 shocks - 285/75/16 Bridgestone AT Revo - 3M lense protectors - Hella 100FF driving lights - blinking side markers
sjcruiser is offline   Reply With Quote
Old 03-23-06, 12:57 PM   #12 (permalink)
tlcwagons.org
FirstToy's Avatar
My electric skills are limited but when the time comes, I will be installing the Hellroaring or Granger for dual batts.
I have heard so many good things of Hellroaring (performance and customer service) so you can't go wrong.
I love cachapas!
my wip
The Original blister©
I drink your milkshake!
Old 03-23-06, 01:07 PM   #13 (permalink)
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
How far in the future are you thinking?
Brent
'94 White LC; Kaymar Rear Bumper w/tire carrier; Hanna Sliders; ARB winch ready Front Bumper; Slee Transfer Case Skid Plate; BFG MT KM2 285's, OME 850/863 Heavy 2" lift, INTI Rack; Warn M12000 Winch, Snorkel; Sputnik!
TLCA Member #13420; KI6SGO
Brentbba is offline   Reply With Quote
Old 03-23-06, 01:16 PM   #14 (permalink)
tlcwagons.org
FirstToy's Avatar
dunno Sputnik, when I get around to it... it's not a priority right now tho.
I love cachapas!
my wip
Old 03-23-06, 02:38 PM   #15 (permalink)
tech_dog's Avatar
I'll throw in fuses where appropriate. I didn't show every detail, as it makes it harder to understand.
One of my primary goals was to avoid putting anything between the existing vehicle electric and the primary battery. I saw that as a negative return on investment, as it could actually increase the chances of becoming stranded. I like the fact that everything new is hanging off of the positive terminal of the battery, and doesn't require any hits on existing wiring.
Old 03-23-06, 02:40 PM   #16 (permalink)
On the Golf Course!
Brentbba's Avatar
TLCA# 13420
Just thinking if I had the $$ we could have an install party and invite someone that knows what they are doing.
Brent
Old 03-23-06, 03:13 PM   #17 (permalink)
Mike S's Avatar
Frank
The ACR manual switch can be set to isolate or combine the two batteries. No problem to jump start from the second battery - or a third battery.
But with this set-up, the likelyhood of having to jump start is pretty remote.
I ran the batt 2 cable between the rad and the fan enclosure, and did no add in-line fuses. I used 1/0 welding cable and covered it with split loom cover, and zip tied it to the radiator ears.
M
BTW, you can toast your alternator by allowing even momemtary disconnect from a battery. That is why most marine switches are 'make, then break'. devices. They connect batt 2 before disconnecting batt 1. Just something to keep in mind.
www.AutoHomeUS.com
TLCA Member #14874
Old 03-23-06, 07:13 PM   #18 (permalink)
Hants's Avatar
TLCA# 13790
I'm looking at the BlueSea ANL fuses:
http://www.bluesea.com/product.asp?P...63&l1=7463&l2=
or Class T fuses:
Either one in 400A. With dual batteries in parallel plus 80A alternator, I figure that the only way I'd exceed 400A would be a completely discharged secondary battery AND winching at near-stall AND a winch that could/would draw > 400A. In a more typical situation, I would expect a maximum of 240A across the solenoid/combiner.
A short with AGM batteries, though, could yield > 1000A across that line (at least for a short time)!
On another note, a nice feature of mobi-arc's Isolater/Combiner is built-in current limiting. In theory at least, that should prevent the fuses from blowing even if the winch tried to draw >400A across the line.
KD0CXL
Old 03-23-06, 07:18 PM   #19 (permalink)
Hants's Avatar
TLCA# 13790
BlueSea offers several models of manual switches with AFD (Alternator Field Disconnect). I don't know the details, but I assume it is to keep from cooking your alternator if someone accidentally sets the switch to OFF (and thereby disconnects all loads from the alternator) while the engine is running.
http://www.bluesea.com/product.asp?P...58&l1=7458&l2=
KD0CXL
Old 03-23-06, 07:34 PM   #20 (permalink)
Boston Mangler's Avatar
TLCA# 9060
Here is mine
Fuses sitting in my garage waiting to be installed!
More details here: http://www.yankeetoys.org/mangler/dualbats.htm
Baja Overland
www.bajaoverland.com
2006 XR650L
TLCA #9060
Own a Land Cruiser? Join TLCA Today @ www.tlca.org
Boston Mangler is offline   Reply With Quote
Old 03-24-06, 05:48 PM   #21 (permalink)
mobi-arc's Avatar
Dare I mention???? Oh god, let me get my helmet.
'98 Land Cruiser, MOBI-ARC Underhood Welder Equipped, POWER-GATE Dual Battery Isolator, Slee Dual Battery Tray, Long Ranger 180L Aux. Fuel Tank, TJM Nudge-bar, dual Hella HID's, BFG AT 295/75/R16's
www.perfectswitch.com
mobi-arc is offline   Reply With Quote
Old 03-24-06, 07:49 PM   #22 (permalink)
What, that all solenoids are guaranteed to fail?
Rich is offline   Reply With Quote
