Closed Thread
LinkBack (32) Thread Tools Display Modes
Old 03-20-06, 08:27 PM   #1
Kneel for the Shaman
Romer's Avatar
TLCA# 13968
Romer is an unknown quantity at this point
FAQ for 80/LX450 - April 26, 2008 - Added leather replacement w/ links to seat heater
The Frequently Asked Questions (FAQ) for the 80/LX450 series tech section continues to be a work in progress. The goal is to have links in the below to other threads and tech articles. By having these linked, instead of pasting the text, the threads will remain live. The live threads can continue to be updated and/or modified for things such as part numbers, adding on additional insight or after a period of time, some follow up information.
These FAQs have been put together by FORUM members. They have put extensive time and research into them. So when you find yourself using them, it would not be a bad thing to send off a thank you.
Again, these will continue to be updated and we will continue to add new ones as we move forward. If you have an idea for a new faq, or would like to take ownership of pulling one together, then don't be shy about it, you'll be helping everyone
Acronyms and Definitions - Wondering what those Acronyms mean, look here. PM a mod if you see one missing.
Thinking of Buying- If you are thinking of buying or getting ready to look at an 80 or an LX450, look here for helpful links.
General - The General Links include descriptions of differentials, Factory Service manuals, links to Slee's and Safari's Technical Page and how to find a place to fill your CO2 tank
Modifications - Need to start modifying your rig? Look here for what other forum members have done from roof racks, speedo corrections, tires to . . . . If you have an idea, let us know and we can add it! Some modifications are also included in the Accessories link below
Maintenance/Trail Fix items- If you need to perform some maintenance from Rear/Front Axle rebuilds, Changing Starter Contacts, pesky Heater Hose, Fluid Changes, Filters, Injector Cleaning to wiper blade changes, look here! In addition, our local Oil experts provide their recommendations.
Bling- Need to add a little Bling, treat your leather, make the paint shine, look here!
4 Repairs - Need to replace your Headgasket or rebuild your Transmission, look here!
Want to see how those Accessories look - - Links to threads showing, bumpers, sliders, lifts, tires, OnBoard Air Systems, etc. as they look installed on your fellow members rides. Also a Link to Storage ideas can be found here
Where can I get those Accessories - Links to Vendor sites for lots of those great accessories.
Engine Enhancements - A new section dedicated to Engine Enhancements such as Turbo and Super Chargers
Forum Members ROTW (Rig of the Week) Write-ups. Learn here what others have done to their rigs.
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:27 PM   #2
Romer's Avatar
TLCA# 13968
Acronyms and Definitions for FAQ
Common Forum Lingo:
AFAIK - As far as I know
BTW - By the way
FWIW - For What it's worth
FYI - For your information
IIRC- If I recall correctly
IMHO - In my humble opinion
IMO - In my opinion
LMAO - Laughing my @$$ off
LOL - Laugh out loud
OTOH - On the other hand
ROTFLOL - Rolling on the floor laughing out loud
ROTFLMAO - Rolling on the floor laughing my ass off
RTFM - Read the F-ing Manual
YMMV - Your methods/mileage may vary
Technical Acronyms:
A343F = Automatic transmission used in LC's from 95-97
A442F = Automatic transmission used in LC's from 93-94 AKA "the bus tranny", Also some diesels from 95-98
A440F = Automatic transmission used in LC's from 88-92 (Non-electronically controlled predecessor/version of the A442F)
ABS - Acronym for Anti-lock Braking System. This system uses a computer to control your brakes on your car by applying and releasing your brakes quickly to prevent skidding or sliding from occuring.
ALT - Alternator: power generator for automobiles
ARB - australian 4x4 accessories manufacturer
AT - Automatic Transmission
AT - (tires) All Terrain
ATF - Automatic Transmission fluid
BIRF - Birfield: Found in the front axles of our rigs; they are constant velocity joints that transmit power through variable angles, at constant velocities.
CEL - check engine light, sometimes refers tocode that cuased light that can be read by a code reader
CDL Switch- Center Differential Lock Switch- Switch installed to allow the Center Differential to be locked when the transfer case is in High. The actual Center Differential Lock is in the Transfer Case.
Reference on operation of Center Differential. Diffs and Difflocks for Dummies (George Couyant from www.lcool.org) - Can Purchase CDL from Cdan (Totota) or Slee offroad[/i]
DS- Driver's side
DS: Drive Shaft=shafts that carry power and torque from the engine/tranny/xfer case to the axles.
DC DS=Double Cardan Drive Shaft=a pair of joints in a drive shaft that allows the tube to move in various directions and angularities.
Diffs - Differentials: found in the front and rear axles that consists of gears that transmit equal power and torque even if they rotate at different speeds.
ECT - Electronically Controlled Transmission - allows the engine to rev to a higher rpm before shifting to the next gear. Basically changes the shift points for the transmission. (Best for towing or heavier loads)
EGR = Exhaust Gas Recirculation valve
EWD or WD - Electrical Wiring Diagram, (part of FSM set)
FAQ - Frequently Asked Questions
FHH = Firewall Heater Hose
FJ80 - An 80 series Land Cruiser powered by a 3FE engine.
FSM - Factory Service Manual. The "bible" as published by the manufacturer. Used to guide in repairs
FZJ80 - An 80 series Land Cruiser powered by the vastly superior ( ) 1FZ-FE engine.
HDJ80 - An 80 series Land Cruiser powered by a 1HD-T turbocharged diesel engine.
HDJ81 - Japan Domestic Market HDJ80
HG - Head Gasket
HZJ80 - An 80 series Land Cruiser powered by a 1HZ naturally aspirated diesel engine.
HZJ81 - Japan Domestic Market HZJ80
IAC = Idle Air Control solenoid
JDM- Japan Domestic Market- Refers to items particular to vehicles manufactured and sold in the Japanese market.
Items include but are not limited to:
Power retracting mirrors
Dual air conditioning
Adjustible shocks
Winches
and various cool and some gawdy accessories.
LB/FT - pound feet of torque
LB/IN - pound inches of torque
LHD (Left-Hand Drive): steering wheel on the left side, driving on the right side of the road
LSPV - Load Sensing Proportioning Valve
MAF - Mass air flow sensor
MIL - Malfunction Indicator Light (same as a CEL)
M&S - (tires) Mud and Snow
MT - Manual Transmission
MT - (tires) Mud Terrain
NA - Naturally Aspirated - An engine that is not turbocharged nor supercharged
OBDII - On Board Diagnostics Port available on ALL cars sold in the US 199 and later. Allows a common intercface tool to be connected to read and reset engine fault codes (CEL). Many Autpart stores will read your code for free vs. paying the dealer.
OEM - Original Equipment Manufacturer. (Toyota in this case)
OME - Old Man Emu. An Australian four wheel drive specialty manufacturer that makes all kinds of cool stuff that causes us to empty our billfolds.
PCV Valve - The Positive Crankcase Ventilation valve is an emissions control device that routes unburned crankcase blowby gases back into the intake manifold where they can be reburned.
PHH - Pesky Heater Hose. A 100 mm length of 16mm (5/8 inch) straight heater hose located at the extreme LH rear corner of the 1FZ engine cylinder head. So named because it is not the easiest thing to change-out even under ideal conditions.
PI - Propane Injection - Propane is injected into the intake as a diesel catalyst for a more complete burn and additional power
PM - preventive mantenance
PM - private message
PO - Previous owner
POS - Piece of S#1T
PS- Passenger side
PSI - Pounds per square inch - A measure,emt of pressure.
RHD (Right-Hand Drive): steering wheel on the right side, driving on the left side of the road.
RPM - Rotations Per Minute
SOA - Sprong Over Axle - A suspension lift for a leaf (Vs 80 series coil) spring suspension. It places the leaf springs on top of the axle vs the bottom.
SC or S/C = Supercharger/Supercharged
SSM - Special Service Materials
SST - Special Service Tools
SUA = Spring under axle. Stock configuration for a Leaf (80's use Coil)Spring Vehicle (vs. SOA previously mentioned).
TB - Throttle Body: controls air flow into engine system in response to gas pedal depression.
TC or T/C = Turbocharger/Turbocharged
TLCA - Toyota Land Cruiser Association (tlca.org) - The Toyota Land Cruiser Association (TLCA) is a 4 wheel drive organization open to all Toyota 4 wheel drive vehicles (except sedan types). This includes all models of Land Cruisers, 4Runners, and 4x4 trucks.
TPS = Throttle Position Sensor, may also be the "kick down" cable
USDS- US driver's side or the left-hand side of the vehicle.
USPS - US passenger side or the right-hand side of the vehicle.
VSV - Vacuum Switching Valve. An electrically controlled valve that diverts vacuum according to the position of the switch.
xfer=Transfer case: sits behind transmission, has front and rear drive shafts coming out of it, and distributes power from the transmission to the front and rear differentials/axles.
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:28 PM   #3
Romer's Avatar
TLCA# 13968
FAQ Chapter 1 Thinking of Buying an 80
Slee Off Road Newbie guide (Use this if your thinking of buying)
How to check if the truck originally was issued with factory lockers (Forum Members, Mar. 2005)
Differences between 95, 96 & 97 (Forum Members, June 2005)
Toyota FZJ80 vs Lexus LX450 (Forum Members, May 2004)
cruiserdan and forum members discussion of the costs of ownership thread - Dec 2006
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:29 PM   #4
Romer's Avatar
TLCA# 13968
FAQ Chapter 2 General
General
Diffs and Difflocks for Dummies (George Couyant from Don't understand How Lockers work, click here
Basics on differentials
Basics on 4wd vs AWD (Forum Members, Mar 2004)
Factory Service Manual(s) via PDF (RavenTai, April 2004)
How Big a Winch should I get for my 80/LX450 (Forum Members Dec 2005)
Slee Off Road Tech Links Page Pin 7 Mod, Alarm manuals, PHH, Newbie guide. and many more tech articles
Safari Tech Links
Color codes for these rigs are discussed here
New need a replacement or new FOB (Remote for Alarm) try this link on the various options.
Should I get a Brush Gaurd for my rig?
On the brush gaurd. They provide limited protection only when hit from specific spots and actually multiply the damage when hit from any where but the middle.
Here is a small example of what a brush guard does
Here is a great example of what protection an ARB will give you. - However, Slee and others also make great bumpers that provide protection.
Why should I get Sliders? - If you plan on wheeling, Sliders are great protection
A picture says a 1000 words, or several thousand dollars of body damage:
Where can I get my CO2 Tank Filled - This link takes you to a listing of different sources to fill your tank. This includes a link to the National Welders supplies and gases assoc, member suggestions for Fire Extinguisher and Beverage suppliers are also candidates. Make sure you call before going over.
What happens to my speedometer with bigger than stock tires? Go to this link to see how tire sizes will impact your speedometer
What Tires are right for my rig? - This link provides a broad description of different tires that you can use on your 80.
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:32 PM   #5
Romer's Avatar
TLCA# 13968
FAQ Chapter 3 Modifications
Modifications:
This section deals with the common and not so common modifications many forum members have completed.
The first set of modifications people do have to do with Lifts:
Discussion of OME Lifts - Examples of Forum member lifts can be seen in the Accessories section below
Here is a thread were members posted info on their lifts, castor and drive shafts.
Also with the installation of lifts, noises and grinding can occur due to the different pinion angles. Could be large enough of an angle you need a CV shaft, or enough of an angle your tired U joints are acting up and need replacing. See the Drive shaft/drive train threads in the Maintenance section.
New - IronYuppy's review of 4Crawler 1" body lift
Difference in OME Medium vs Heavy springs (Romer, May 2005)
Shock options and specs (Semlin, June 2005)
Modifications to add Lockers, modify the Drive train, Provide more Center Diff Functionality etc.
Retro-fitting OEM electric lockers (Forum Members, Nov. 2004)
BostonMangler's difflock install/retrofit
Diff & Gearbox Breather Extension (George Scolaro)
Forum members Pin 7 Mod
Tutorial: removing the viscous coupler - - Mike P Dec 2006
Want to extend the Diff Breathers? - Important for water crossings to keep water out of your diffs.
Adding a fuel Tank to extend your range.
There are several styles of tanks to choose from. This link will go into detail on the 13 Gallon OEM tank(Romer 2007) and provide other members setups and links to other tank options.
NEW -OEM 13 Gallon tank (elmaraichi March 2008) - Elmarcaichi did exhaustive research to make this completely OEM
Electrical Modifications to install Dual Batteries, Lighting and other toys
95-97 Coolant Temperature Gauge modification (RavenTai - Oct-Dec 2005)
Yellow Box Speedo Correction - Woody Jan 2006 - Romer found out later to make sure you order what is called the 3 wire set-up
Forum Members Dual Battery Set-ups
FloridaFJ80's two threads on his 3FE Dual battery setup
First thread discussing it before hand
His completed write-up on his 3FE Dual Batt Setup and Homemade Rack
80 Series Lighting (Cary, Feb 2004)
Forum Members Light modifications - This link includes auxilary, added and upgrade of lights or headlights
NewAdd some bling and convert to HID lights - MikePL
Tech - How to install an auxiliary fuse box for less than $20 - Arya Ebrahimi Nov 2006
Landtank's auto up window modification[/url]
Rear cargo light install- elmariachi
UpdatedNeed to replace the aftermarket stereo? Here is some info. This includes both the 80 and LX450
new -jditom's write-up on the AVN6620 Nav Stereoinstall
Bumpers Racks, Sliders, Spare Tire Clearance, AC Dryer Protection - There is more info on some of these modifications in the accessories section below
Roof Racks (Forum Members, Mar 2004)
Rear Bumper Ideas (Forum Members)
Increase clearance under spare tire (Forum Members, Mar 2004)
How to remove the steering stabilizer (Forum Members, May 2004)
Relocation of AC Dryer (Junk, July 2004)
Slider Variations (Forum Members & Vendors Oct. 2005)
Landtanks Blue Fan Clutch modification for improved cooling operation
Other Modifications - Unique and the not so common:
Grab Bar - Koffer and Nakman
Nakman's Seat Recliner Mod
Nakman's Under the hood Grill, for cooking
Turbocruisers Carbon Control Project- April 2006 - Trap carbon from the PCV to keep it out of the manuifold
Rich's coolant system filter to capture sludge[/url]
Most Cost Effective Modifications (Forum Members, Mar 2004 - current)
Want to line your fenders and flares with Durabek:
MaddBaggins Thread
Concretejungles Thread Part 1
Concretejungles thread part 2
NEW Need to change out your leather and/or install Seat Heaters. Read the thread by Romer with links to TomH's thread
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:38 PM   #6
Romer's Avatar
TLCA# 13968
FAQ Chapter 4 Maintenance
Emergency Start Troubleshooting Procedures - If your truck won't start, try these steps.
Preventative Maintenance Items:
Think you might have some issues with your front end? Loose Bearings Tie rods, etc. See Lantanks write-up on checking the front end
Front Axle/Birf Rebuild Your Front Axle Service should be performed once every 60K Miles. One of the first PMs (Preventative Maintenance) items to be performed after buying a rig without know it’s history. Thread also includes front Brakes.
Clownmidgets Rear Axle rebuild write-up & Rear Drive Shaft U Joints - Excellent write-up with photo's by Clownmidget doing his Rear Axle service and replacing the U Joints on his Drive Shaft
Rear Axle Service - Full Floater (Forum Members, June 2004) Rear Axles need to be PM’s as well
Rear Axle Service on FF {93 & up} (Rookie2<- dude in purple shirt & Beno, Mar. 2005) – Another Rear Axle PM thread
Building a Rear Axle SST
Changing Front Brake Pads Description - Driley Feb 2006
Pesky Heater Hose {PHH} (Forum Members, Mar 2004) – The PHH tends to fail and is a suggested PM item for over 100K miles.
New -Have water leaking in the cab? here is tomatopants and other members write-up on cleaning the sunroof drains or Jersey Cruisers write-up and modifying them
New - Posers E Brake write-up
New - Mars Brake Pad and caliper replacement
New - Slomos Brake Caliper rebuild thread
New Is your AC not as cold as it should be, try adjusting the water valve - cartercd
Need to change your PCV valve? - Nak and RavenTai - Nov 2006
Radiator Flush (Forum Members, April 2004) Part of base lining your fluids and regular PM
Power Steering Flush - RavenTai Feb 2006 Often overlooked Fluid Baseline
Transmission Fluid Exchange (Snow Cruiser, July 2004) Part of base lining fluids in the vehicle
Cleaning the coolant system (e9999, April 2004) A good step for Base lining vehicle Radiator Flush
Toyota Red vs Green Coolant (Forum Members, May 2005) Now that I am flushing my Radiator, should I use Toyota Red or Regular Green?
Wiper blades and refills (Forum Members, April 2004) Using OEM replacements is recommended, but takes some effort.
How to replace the air filter (Forum Members, May 2004) Clogged air filter creates poor performance. A Regular PM Item.
Changing Starter Contacts -Note: Wrong Dealer Pic tags in pictures (George _tlc Nov 2005 ) Common failure over 100K mile vehicles. Suggested PM Item
Fixing the broken Antenna Mast - John E. Davies March 2006
Oil pan arch seal - alia176
New -Fluid Recommendations per the Factory Service Manual
Engine oil
Dry fill 8.0 liters (8.5 US qts, 7.0 Imp. qts)
Drain and refill w/ Oil filter change 7.4 liters (7.8 US qts, 6.5 Imp. qts)
w/o Oil filter change 6.9 liters (7.3 US qts, 6.1 Imp qts)
API grade SH, Energy-Conserving II multigrade
engine oil or ILSAC multigrade engine oil and
recommended viscosity oil, with SAE 5W-30 being
preferred engine oil
Differential oil
Front w/o Dfferential lock 2.80 liters (2.9 US qts, 2.5 lmp. qts) Transfer Case takes the same fluid type as the Differential
w/ Dfferential lock 2.65 liters (2.8 US qts, 2.3 lmp. qts)
Rear 3.25 liters (3.4 US qts, 2.9 lmp. qts)
Hypoid gear oil API GL-5
Above -18°C (0°F) SAE 90
Below -18°C (0°F) SAE 80W-90 or 80W
Transmission
11.0 liters (11.6 US qts, 9.7 lmp. qts)
1.9 liters (2.0 US qts, 1.7 lmp. qts)
ATF DEXRON®II
Engine coolant:
w/ Front heater 12.5 liters (13.2 US qts, 11.1 lmp. qts)
w/ Front heater and rear heaters 13.4 liters (14.2 US qts, 11.8 lmp. qts)
Ethylene-glycol base
NEW - Cleaning the Fuel Pump Relay contacts to fix starting and running issues. See SUMOTOY's thread with pics
New - Want to know what the engine codes are, here are some links
How to break in those new brake rotors
Have an overheating problem? It may be the Fan Clutch!
cary's tips and comments on replacing the Radiator
Drivetrain Maintenance and Issues:
Drivetrain Maintenance, Issues and Troubleshooting
Possible Driveshaft/Tranny Clunk & Maintenance (Semlin, Sep. 2004)
how to replace the u-joints in your 80 (Semlin Dec 2005)
Adjusting the throttle cable - Tech Article (Randy F, 2003)
New - Beno's set of links used to help diagnose Drivetrain issues
Maintenance
NOTE: Head Gasket and Transmission Threads are found in FAQ Chapter 6 4 Bannana Repairs
Forum Members advice on Oil, Filters and Gear Oil This thread is a compilation of our own oil experts cary and RavenTai posts and advice over the last 3 years.
Discussion thread on Toyota Red Anti-freeze - Lots of technical posts about the properties of Anti-Freeze with considerable input by RavenTai
Get an Engine Light or have a CEL Code? look here for a listing of the codes (Maybe for only 96-97 OBDII). Note: You can get codes pulled free at lots of Autoparts stores.
Your CDL not actuatings as it should? Look at Tools thread on the CDL Actuator
Technical Service Bulletins (not complete list)
Want to be able to download the Factory Service Manual, Here are updated instructions on how to do it
Seat Belts sticking and not retracting all the way? Try this
Timing Advance Instructions from Safari4x4.com
Using the Vehicle Computer Codes to help Diagnose problems
If you have a 96 or newer vehicle you have an OBDII diagnostic port. You can eitehr buy a code reader or got to one of the many autoparts stores that will pull the code for you. The code will then tell you what the computer has logged as a fault. The nice thing about OBDII, is the code reader will work on ALL vehicles made 1996 and up.
If you have a 91-95 Land Cruiser, you can still pull the code with the paperclip method:
To be supplied
In addition, you can pull the TCM code. A TCM code is where your o/d light is flashing and pertains directly to the transmission only
Originally Posted by semlin
To identify the code
1. get a metal paperclip or jumper wires
2. switch the o/d button on
2. go to the DTC output box on the fireall of the engine (small black plastic box with a pop up lid which may be labelled "DLC1". lift the lid. You should see two small grids of 3x3 contacts and the inside of the lid should have a label code. identify the E1 and TT contacts.
3. turn ignition on
4. go back to the DLC box and insert one end of the paper clip in the E1 hole and one end in the TT hole. BE CAREFUL AND DO NOT GUESS ON THIS. If you don't have ther label code post up in the forum
5. go back inside and watch the o/d light flash pattern.
if it blinks continually in 2 second intervals you no longer have a problem so just pull the 10 amp dome fuse to clear the code
6. otherwise count the flashes to get a 2 digit code. the flash sequences are sapareted by a 1.5 second pause. If there are 2 codes there will be a 2.5 second pause between each fresh code.
7. remove the paper clip. turn truck off.
8. post your codes in the forum or look up in the FSM to decipher.
Other Maintenance or Reapair Items:
Leaking Tcase Speedometer O-ring (Nakman, Mar 2004)
How to Replace Oil Pump seal w/ Pics (zjz4476- Zane Zwerenz Dec 2005)
New Power Steering Pump and High pressure Hose Removal and Replacment - Jan 2007
Power Steering Gear Box and Pump Rebuild Thread - jklubens June 2006
Power Steering Pump Replacement - cruiserdan April 2005
Cleaning ABS sensors that acting up (FZJFillmore, May 2005)
EGR & code PO401 & P0402 (Kurt {Dr. EGR}, Mar 2004)
Fixing Slow Drivers Door Power Lock (IdahoDoug, July 2004)
Injector Cleaning and/or Replacing (Forum Members, Apr. 2005)
Increase MPG and more on cleaning fuel injectors (Landtank, Apr. 2005)
K&N Air Filters, Yes or No (Forum Members, Sep 2004)
Sealing OEM Roof Rack Holes (Forum Members, Sep. 2004)
jklubens shakey sideview mirror FIX
elmariachi's Cleaning AC System and Evaporator
Forum Members Maintenance Tips and Tricks
Trail Fix
How to unlock a locked factory locker (Forum Members, April 2004)
3FE (Some links to 60 section)
Yoopers write up on solving his fuel supply problem
3FE Performance Mod discussion
jklubens thread on timing a 3FE Motor
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:38 PM   #7
Romer's Avatar
TLCA# 13968
FAQ Chapter 5 Bling
Bling
LED's for Interior (treerootCO March 2008)
Restoration of Center Caps Part 1 (Forum Members, Mar 2004)
Restoration of Center Caps 2(Forum Members, Mar 2004)
Speaker fit, stock appearance (Tucker74, Mar 2004)
Leather Treatment for Your Seats (Turbo Cruiser, Mar 2004)
Want Your Truck to Shine at the Mall? (Forum Members, Sep. 2004)
Cupholders (97 FZJ80 Feb. 2008)
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:39 PM   #8
Romer's Avatar
TLCA# 13968
FAQ Chapter 6 - 4 banana repairs
4 repairs
Trannsmission rebuild
Head Gasket Threads
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:40 PM   #9
Romer's Avatar
TLCA# 13968
FAQ Chapter 7 Forum Member Accessories
Links to members, Bumpers, Lifts etc.
Front Bumpers - Forum Members Jan 2006
Rear Bumpers - Forum Members Jan 2006
Sliders - Forum Members Jan 2006
Forum Member Tire Choices
Forum Member Lifts
6 Inch lifts
CO2 on board air solutions - Forum Members Jan 2006
On board air (Non CO2) solutions - Forum Members Jan 2006
Storage ideas and solutions - Forum Members
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 03-20-06, 08:41 PM   #10
Romer's Avatar
TLCA# 13968
FAQ Chapter 8 Where can you get those great accessories
From our great supporting vendors
Support IH8MUD Advertising Vendors!
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
Romer is offline
Old 06-26-06, 07:48 PM   #11
Romer's Avatar
TLCA# 13968
FAQ Chaper 9 Engine Enhancements
So you want your truck to go faster? There are two standard methods; a Turbocharger and a Supercharger
TURBO FAQ - What is a Turbo Charger and how does it work
SUPERCHARGER FAQ(in development)
Installation Links and Topics:
George's Super Charger Install Instructions
Dual Pod install - To install gauges to go with the supercharger - boydmick Nov 2006
blarsens cool supercharger intercooler
Romer is offline
Old 02-07-07, 08:36 AM   #12
grown up MOD
reffug's Avatar
TLCA# 14549
reffug is an unknown quantity at this point
Week Start Week end ROTW
A 5/9/2005 5/15/2005 lx450landcruiser
B 5/16/2005 5/22/2005 Gumby
C 5/23/2005 5/29/2005 cc93cruiser
D 5/30/2005 6/5/2005 T Y L E R
E 6/6/2005 6/12/2005 cruiserdan
F 6/13/2005 6/19/2005 Hltoppr
G 6/20/2005 6/26/2005 airlaird
H 6/27/2005 7/3/2005 Aussie Cruiser
I 7/4/2005 7/10/2005 Biff
J 7/11/2005 7/17/2005 NMostofi
K 7/18/2005 7/24/2005 Fochdog
L 7/25/2005 7/31/2005 Landtoy80
M 8/1/2005 8/7/2005 concretejungle
N 8/8/2005 8/14/2005 sjcruiser
O 8/15/2005 8/21/2005 Beowulf
P 8/22/2005 8/28/2005 Tucker74
Q 8/29/2005 9/4/2005 TX_TLC
R 9/5/2005 9/11/2005 White Shark
S 9/12/2005 9/18/2005 MaddBaggins
T 9/19/2005 9/25/2005 turbocruiser
U 9/26/2005 10/2/2005 Romer
V 10/3/2005 10/9/2005 clownmidget
W 10/10/2005 10/16/2005 Texus
X 10/17/2005 10/23/2005 cruiseruser
Y 10/24/2005 10/30/2005 Scott_sFZJ80
Z 10/31/2005 11/6/2005 NorCalDoug
WAVE 2
1 11/7/2005 11/13/2005 cc93cruiser
2 11/14/2005 11/20/2005 -uhuru-
3 11/21/2005 11/27/2005 MTNRAT
4 11/28/2005 12/4/2005 TiredIronGRB
5 12/5/2005 12/11/2005 neowulf
6 12/12/2005 12/18/2005 davegonz
7 12/19/2005 12/25/2005 dmc
8 12/26/2005 1/1/2006 rgsii
9 1/2/2006 1/8/2006 LR_RESQ
10 1/9/2006 1/15/2006 Cruiserhead05
11 1/16/2006 1/22/2006 PKP80
12 1/23/2006 1/29/2006 ManrigDude
13 1/30/2006 2/5/2006 blupaddler
14 2/6/2006 2/12/2006 Hayes
15 2/13/2006 2/19/2006 topeod yobbo
16 2/20/2006 2/26/2006 NorCalSam
17 2/27/2006 3/5/2006 Houston FZJ80
18 3/6/2006 3/12/2006 convert
19 3/13/2006 3/19/2006 markt
20 3/20/2006 3/26/2006 beno
21 3/27/2006 4/2/2006 FZJ80 FIREMAN
22 4/3/2006 4/9/2006 FirstToy
23 4/10/2006 4/16/2006 BRKLYN1
24 4/17/2006 4/23/2006 apcoleman
25 4/24/2006 4/30/2006 MaddBaggins (Part 2)
26 5/1/2006 5/7/2006 Darwood
27 5/8/2006 5/14/2006 jklubens
28 5/15/2006 5/21/2006 Josh83
29 5/22/2006 5/28/2006 clarkrw3
30 5/29/2006 6/4/2006 bull
31 6/5/2006 6/11/2006 z80
32 6/12/2006 6/18/2006 FZJFillmore
33 6/19/2006 6/25/2006 Dusty
Wave 3
01 6/26/2006 7/2/2006 racerdave
02 7/3/2006 7/9/2006 ginericfj80
04 7/17/2006 7/23/2006 Nay
06 7/31/06 08/06/06 Chotchy
08 08/15/06 08/22/06 Wild Yoates
09 08/22/06 08/29/06 desertdude
11 9/4/2006 9/10/2006 TCH2FLY
12 9/11/2006 9/17/2006 Semlin
14 10/9/2006 to 10/16/2006 Walking Eagle
16 10/16/2006 to 10/25/2006 FJBen
17 10/25/2006 to 11/5/2006 Romer
18 11/5/2006 to 11/12/2006 Land Schmoozer
19 11/12/2006 to 11/24/2006 xiero
20 11/24/2006 to 12/04/2006 DanKunz
21 12/18/06 tp 12/25/06 Alkaline747Trio
22 12/252006 to 01/01/2007 Bear80
Wave 4
1/1/07 to 1/8/07 BBM Rick
1/8/07 to 1/15/07 cc93cruiser
1/15/07 to 1/22/07 e_parise
1/22/07 to 1/29/07 Hayes
1/29/07 to 2/5/07 TiredIronGRB
2/5/07 to 2/12/07 95eighty
2/12/07 to 2/19/07 lx450landcruiser
2/26/07 - 3/4/07 bhaines
3/5/07- 3/11/07 80krazE
3/12/07 - 3/18/07 Texus
3/19/07 - 3/25/07
