80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 03-16-06, 02:09 PM   #1 (permalink)
Hulk's Avatar
What rear OME springs/shocks should I get?
I'm lifting the 80 in the next 2 weeks. I got a good deal on some mildly used OME850 OME Heavy front coil springs and some N73 OME shocks & bushings. Plus I'm buying a new-in-the-box caster correction kit.
I need to buy rear springs and shocks. My back end will be heavier than stock: my new back bumper is being custom made at Wadsworth Offroad right now. (The best way to describe it is that it will be a cross between the Slee bumper and the 4x4 Labs bumper, but different.)
Question: what do you think I should get for the springs on the back? I see three choices:
OME860: 0-200 lbs over stock
OME863: 200-440 lbs over stock
OME864: 300-600 lbs over stock
I was thinking I should get the 863s. What do you think? Also, which shock should I use: the N74E or the longer N74L?
N74E: Open: 24.4" Closed: 14.6"
N74L: Open: 26.4" Closed: 15.6"
Also, do you think I need spacers in the front to make it sit level? I have an ARB winch front bumper, but no winch (yet).
I was also planning on buying the OME-SD24 steering stabilizer. Any other parts that I should get? I'd like to have everything I need, so I can get this done over a weekend.
TIA!
Matt Farr, TLCA #4189 · WØRDY
Webmaster, Rising Sun 4WD Club of Colorado · Webmaster, TLCA · my Facebook page
1981 FJ-40 "The Hulk" + 1996 FZJ-80
Hulk is offline   Reply With Quote
Old 03-16-06, 02:16 PM   #2 (permalink)
DuManchu's Avatar
You need all of this stuff:
2 x OME 850 Front Coil Springs
2 x OME 863 Rear Coil Springs
2 x N73 Nitrocharger Shocks
2 x N74E Nitrocharger Shocks
1 x SD24 Steering Damper
1 x Caster Correction Bushings
http://sleeoffroad.com/products/80_suspension.htm
-Andrew
- Andrew Booth -
1994 FZJ80 - SOLD :(
1998 Volvo V70 XC - 122K Miles - Navy/Tan - Um.. roof rack?
"That thing you burnt up isn't important to me. Not any more. It's the Fluid Catalytic Cracking Unit; it makes shoes for orphans. Nice job breaking it, hero." - GLaDOS
- Tornado Alley Cruisers
- WallopHandle - Golf etc.
- REtired Greyhounds As Pets - KC REGAP
DuManchu is offline   Reply With Quote
Old 03-16-06, 02:40 PM   #3 (permalink)
Tools R Us's Avatar
How much weight do you plan on carrying?
If your going with 315+ tires you will need to space the bump stops, in that case the longer shock will work better. For little tires the short shocks will work fine.
TIA!
Depends on how much weight your going to add and where it is.
Copper State Cruisers #007
Tools R Us is online now   Reply With Quote
Old 03-16-06, 02:54 PM   #4 (permalink)
Hulk's Avatar
I'm running 285 BFG ATs right now. I'm not planning to go bigger at the moment.
I'll probably carry several hundred pounds of gear and tools on the trail. However, most of the time that stuff will be in my garage.
Old 03-17-06, 05:50 PM   #5 (permalink)
Hulk's Avatar
Decided to go with the 863 and N74E setup. This seems like it will do everything I need. Thanks!
Old 03-17-06, 05:57 PM   #6 (permalink)
fatherofdaughterofromer
Romer's Avatar
Garage
Matt, for what its worth I run the med springs all around with spacers on the front.
Since you have heavies on the front, you might as well do heavies on the rear. It's more height than anything else. The heavies do not provide any additional strenth, just 1" more in height.
This is in the FAQ under modifications, maybe this will help:
Don't swap the Med for Heavy OEM Springs
You will like the fact that it started over a camp fire at Cruise Moab last year.
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
