Old 02-19-06, 07:17 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
clownmidget's Avatar
rear axle service photos
these are primarily for Romer or anyone that would like to include any of these photos for the FAQ stuff.
I had my rear third removed to re-gear and took the opportunity to rebuild the rear axle, put in some new brake pads, adjust the parking brake, and put new u-joints in the rear driveshaft.
enjoy
top: the parts and numbers from Dan
middle: wheel off, ready to remove caliper - two 17-mm bolts on the back side, the lower one a tight fit for a socket due to the lower shock mount.
bottom: caliper off, sitting on top of axle housing. Should be secured with wire to ensure no stretching of the brake hose.
Mike R.
hmmm....nuthin'
Answer a fool according to his own folly.
clownmidget is offline   Reply With Quote
Old 02-19-06, 08:08 PM   #2 (permalink)
next...
Top: Two bolts to pop off the rotor. Note to the newbie - you can't have your parking brake on and remove the rotor
Middle: brass hammer to strike the hub body to loosen the cone washers.
Bottom: success! I noticed that the ones on the bottom tended to loosen from striking the top.
Mike R.
hmmm....nuthin'
Old 02-19-06, 08:12 PM   #3 (permalink)
next...
Top: all cone washers removed and axle loose, ready to be pulled out.
Middle: using an impact driver to loosen the spindle nut lock screws
Bottom: loosening the lock nut, I used the OTC SST.
Mike R.
hmmm....nuthin'
Old 02-19-06, 08:19 PM   #4 (permalink)
next...
top: behind the lock ring is the thrust washer with the notch that sits in the groove on the top of the spindle.
middle: popping out the axle oil seal that sits inside of the spindle.
bottom: spindle cleaned and ready to start rebuild
Mike R.
hmmm....nuthin'
Old 02-19-06, 08:24 PM   #5 (permalink)
next...
top: with the hub body off the spindle you can remove the bearings. to do the inners, you'll need to remove the inner seal.
middle: once the bearings are out you can drive out the races using a brass drift placed in the two opposing notches in the hub housing.
bottom: this is pretty much out of place but once you've got it all buttoned back up this is how I prep the rear caliper for the new pads.
Mike R.
hmmm....nuthin'
Old 02-19-06, 08:31 PM   #6 (permalink)
next...
Once the bearings and races are out, it's no big deal from here to just clean everything up, drive in the new races, pack the new bearings with grease, and re-assemble using the new parts.
Started the replacement of the u-joints on the rear driveshaft. I had the rear drive shaft off already in order to have the rear third setup with the new gears.
top: oem u-joint from Dan these are worth it in my opinion. the quality is just better and the cups are pre-packed w/grease.
middle: start by removing the c-clips that sit on the inboard of the yokes. I use a mid-sized flat screwdrive that works great. One or two whacks and it lifts it just enough to insert the tip and flick it off.
bottom: gap to start flicking
Mike R.
hmmm....nuthin'
Old 02-19-06, 08:37 PM   #7 (permalink)
next...
Once you have all four clips removed you can press out the cups. You can use a vise or just use your floor and a 5-lb sledge :hillbilly
top: pressing out the cups. Bottom is 32-mm socket (from the s/c crank pulley) and top is a 7/8".
middle: cups pressed out about half way
bottom: another angle
the idea is to press out the bottom one just enough to pull it out with some visegrips and not pushing out the top one all the way. It's no big deal if you do push out the top one all the way into the center of the yoke because you can just start it back in and drive it through, just a little more time and effort.
Mike R.
hmmm....nuthin'
Old 02-19-06, 08:42 PM   #8 (permalink)
next...
top: bottom cup has been pressed out, now flip and drive out the opposing cup. I used a big drift.
middle: driving out opposing cup
bottom: flange yoke portion. I remove the shaft cups first so it's easier to manage the flange yoke portion.
Mike R.
hmmm....nuthin'
Old 02-19-06, 08:47 PM   #9 (permalink)
next...
top: removing the cups on the flange yoke.
bottom: all the new parts
Install is pretty straight forward. Just be sure to orient the spider so you can reach the grease fitting once it's assembled. Again, I start on the flange yoke by placing the spider in the yoke, then start the cups on each side. The same sockets let you press in the cups flush so the grooves for the c-clips are now visible on the inboard edge. Tap in the c-clips and you're done. Be sure to add grease once the shaft is back in place.
Mike R.
hmmm....nuthin'
Old 02-19-06, 09:26 PM   #10 (permalink)
fatherofdaughterofromer
Romer's Avatar
TLCA# 13968
Garage
Excellent write-up and now part of the FAQ. That's a perfect FAQ type thread. Thanks for contributing.
Ken
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
Old 02-20-06, 12:12 AM   #11 (permalink)
northerner
semlin's Avatar
great photos/write up -- a question and a comment
first - am i correct that the inner and outer oil seals on the rear are the same p/n's as the front oil seals? I ordered a rear repack kit a while back and I wondered why I had extras of the big ones at hand when I did my friend's front wheel bearings?
second -- if this is to be a faq you might want to mention popping off the brake fluid reservoir lid before compressing the rear caliper like that.
oh and definitely get toyota u-joints. my aftermarkets lasted only 18 months.
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
64, 2x65 honda ct 200
67, 2x68, 3x69, 72, 75 Honda ct90
83 Honda ct70
48 Ferguson TE20
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
wfc 4812-2635-4880
semlin is offline   Reply With Quote
Old 02-20-06, 06:49 AM   #12 (permalink)
Hey Romer/Semlin, thanks and yeah, it should be clearly noted that I did not do a "complete" write-up!
Definitely pop the cap for any brake work!
A FSM or a Haynes at least should be on hand before proceeding.
The front and rear seals are different. I'm not certain if you are asking about the small axle seals or the larger "oil" seals (as the FSM calls them) that are on the back of the hub holding the inner wheel bearings in place but they are all different. The big seals are almost identical though with the only difference that is apparent being a raised lip on the rear set that is not on the fronts. They are the same diameter, etc though.
One section that I did not write about that requires the manual is re-installing the lock nut to the correct torque AND then lining up the hash marks on the lock nut pins to the hashes cut into the end of the spindle allowing you to sink the lock screws completely into the thrust washer in two of the threaded holes 180-deg apart. Bottom line, get a manual it makes lifer so much easier.
Mike R.
hmmm....nuthin'
Old 02-20-06, 07:10 AM   #13 (permalink)
Central Scrutinizer
MoGas's Avatar
TLCA# 17188
Very nice write up.
The only thing that I would do differently is to use the bleed screw to relieve the brake fluid when compressing the caliper. The fluid does not circulate through the brake system, it just moves back and forth a few inches, so the fluid in the caliper has been heated and is generally pretty nasty looking and I personally, don't like the idea of forcing "dirty" fluid backwards through the system and causing potential ABS issues. You may introduce a small amount of air into the caliper this way, but, after any brake job you should bleed the brakes out anyway.
Dave
Mine: 1993 FZJ80, Classic White.
ARB Commercial, Warn 8274, Aussie Locker, Hanna Sliders, CDL, P7, JD HIRs, Slee harness, Dual Batteries, 850/863, Slee 25mm spacers, SS brake hoses, Norcold 60.
Hers: 1988 FJ62, Red, OME Dakar, Norcold 45, "El Rojo Grande"
1986 4x4 Hilux 22RTE
1965 M416 Trailer.
Copper State Cruisers Member #85
"I would remind you that extremism in the defense of liberty is no vice. Let me remind you also that moderation in the pursuit of justice is no virtue."
Barry Goldwater
MoGas is online now   Reply With Quote
Old 02-20-06, 07:13 AM   #14 (permalink)
apcoleman's Avatar
TLCA# 15215
Thanks for all of the pictures. I plan on getting this done once it warms up in the spring.
Tony
95 LC ROTW
03 ///M3
apcoleman is offline   Reply With Quote
Old 02-20-06, 07:21 AM   #15 (permalink)
concretejungle's Avatar
TLCA# 14646
Great pics clown. Funny you posted those because i tried to replace the ujoints in my rear driveshaft this past weekend. I had no problems removing the c-clips, but i hammered and hammered and couldn't get the joint hammered out enough to get the cap off. :(
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 02-20-06, 08:04 AM   #16 (permalink)
desertdude's Avatar
TLCA# 2911
Awesome and timely write up Mike - I am about to do this in a few days and have collected all the new parts from Slee - including the U-joints - How did you know?
One question ; is there anything else special that needs to be done to the lock ring once you reinstall? Any special preload?
Pasquale - KE7GVY
DesertDude Films, LLC <> DesertDude Music.com <> 110 Project Group, Inc
"Taking the path less credentialed"
desertdude is offline   Reply With Quote
Old 02-20-06, 11:13 AM   #17 (permalink)
Rookie2's Avatar
Yep. It's all nicely spelled out in the FSM.
1997 LX-450, Basically stock.
Rookie2 is offline   Reply With Quote
Old 02-20-06, 12:20 PM   #18 (permalink)
desertdude's Avatar
TLCA# 2911
ah yeah ...I have tha manual and have the info - but thought it was good to post it here - and there is also screws on the lock ring - nice to include that too for folks who don't know
Pasquale - KE7GVY
Old 02-20-06, 01:36 PM   #19 (permalink)
snowwolf's Avatar
Just like to add, it's far easier to use the socket/box spanner idea like you have done, but use a vice instead of the hammer, it's a more gentle and more forcefull, just like to say the photo's were great and will use your imput
snowwolf is offline   Reply With Quote
Old 02-20-06, 02:00 PM   #20 (permalink)
Turbo Diesel Lover
Tapage's Avatar
when you readjust and tight the hub nuts .. you measure teh torque or just at your felling .. ?
HJ-60 2H-T Intercooled Tencha
Old 02-20-06, 02:46 PM   #21 (permalink)
TLCA# 14646
Holy crap, i just pictured in my mind what you are describing and it does sound like the way to go. I'll give that a shot this time through.
Old 02-20-06, 03:39 PM   #22 (permalink)
no bueno
Skillet's Avatar
TLCA# 16078
Thumbs up
Good stuff!
Very nice write-up.
I will be doing this soon myself and will use this as a guide.
Thank you!
1993 FZJ80
1973 FJ40
oh no you didn't...
Skillet is online now   Reply With Quote
Old 02-20-06, 05:58 PM   #23 (permalink)
Echo_29's Avatar
Location: There is no place, anything like this place, anywhere near this place…so this must be the place!
TLCA# 14104
Nice write-up Mike--how long did this all take?
Scott
96 FZJ-80 | Hi-Desert Pinstripes
Northern California TLC Wagons
Echo Park, Los Angeles, CA
Echo_29 is offline   Reply With Quote
Old 02-20-06, 06:07 PM   #24 (permalink)
spartan's Avatar
Did you use bolts to pull rotor and drive shaft or did they come right off / out?
TX
1997 40th, One Owner, Front 850 OME + 30MM Poly Spacers / Rear 860 OME, Castor Correction, Bilsteins, ARB, 9000# Superwinch, Hella 1000's / 500's, Samco Silicone PHH, Landtank seat rail extensions, Husky Liners F-R, 285 Revo's.
spartan is offline   Reply With Quote
Old 02-20-06, 06:35 PM   #25 (permalink)
Dave, you're spot on. In fact I'd say that anytime you start to tear apart your actual "focused" repair you have on hand any "complimentary" parts that might come into play once you've committed your labor. In this case, I hadn't anticipated replacing the rear disc brake pads, breaking off a lug or futzing around with the emiergency brake. But once you get in there, you notice your pads are too thin to bother putting back in, you break a lug off and you remember how crappy the e-brake is fxning. Luckily I had the rear pads around, had plenty of extra lugs and lug nuts (DO THIS NOW!- not when you really, really need one in a pickle), and luckily the e-brake pads were in great shape.
I will be flushing out the brake fluid too though as it's just good to do and costs under $10 even using synthetic.
Thanks for the reminder
Originally Posted by MoGas
Very nice write up.
Dave
Mike R.
hmmm....nuthin'
Old 02-20-06, 06:37 PM   #26 (permalink)
dude, yeah it's in the FSM and I didnt' want to completely plagarize it
I tried to touch on it above about lining up the lock nut/ring hash marks with those on the spindle so the screws will seat into the thrust washer. And Beno & Co. thread already showed the pre-load fish scale test and gives the proper torque. It's all good though...
Mike R.
hmmm....nuthin'
Old 02-20-06, 06:40 PM   #27 (permalink)
Yes, if your vise is big enough and properly mounted it's a no brainer. I was by myself and my vise is sitting under the workbench unmounted so I went with my strong suit :hillbilly
You've got to not be timid in removing them, don't fear the sledge
Mike R.
hmmm....nuthin'
Old 02-20-06, 06:45 PM   #28 (permalink)
well you asking caffeinated or not?
It's tough to give a true time frame because I started with the driveshaft sitting on my garage floor and the rear third absent from the rear axle. And I had just had all the cone washers wacked free less than a week before so they were not nearly as tough the first time around.
But I started Sunday around 9:30 and was finished by 4:30 including an oil change, filling the rear diff, adjusting the e-brakes, replacing the wheel lug, and the general aimless milling about with a socket in my hand and no idea what I was going to do with it. "Ever stop to think, and then forget to start?"
Mike R.
hmmm....nuthin'
Old 02-20-06, 06:46 PM   #29 (permalink)
desertdude's Avatar
TLCA# 2911
Thanks Mike for clearing that up- I just did the removal today - had a real hard time getting the rotor off - I removed the Ebrake cable and clocked down the adjuster to the bottom - could not get the drivers side off could not even spin the wheel - I had to put a wheel back on and use it as leverage - I finally got it off after much struggle - ( only 40K miles on the 80)
Mike - you made my day much easier with this write up
( ken - please delete all my posts in your final FAQ
Pasquale - KE7GVY
Old 02-20-06, 06:49 PM   #30 (permalink)
TX, my rotors just slid off. That's also why I made note to make sure your e-brake is OFF. I can't count how many times I've seen folks struggle at this 30-sec step because they are so well trained to put that e-brake on, especially when jacking up the truck. The two small bolts 180-deg apart on the rotor are 8-mm if I remember correctly.
The driveshaft comes off with two 14-mm spanners. I use a 6-pt and a 12-pt (also a gearwrench version). I spin the driveshaft with a large screwdriver in the rear flange yoke just in front of the rear diff.
TX
Mike R.
hmmm....nuthin'
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/80429-rear-axle-service-photos.html
Posted By For Type Date
Foro HDJ Series :: Ver tema - como llegar al rodamiento de la rueda trasera en un 80? This thread Refback 07-22-08 05:05 AM
