Front Locker Opportunist
OK Lift is DONE!
Got the 3" drop brackets from MAF and got to work. Just finished'em. The truck rides lot better now. Steering is back to normal. I have Slee sliders so I had to be creative on the DS front u-bolt. I had to remove that u-bolt permanently and cut off about .05" from the bottom portion of the mount from the slider. The brackets are wider than the frame so part of the brackets stick out. So right now my DS slider 's front ubolt mount is sitting on the portion of the bracket that sticks out. I have used a lock nut and a bolt on the top hole (same size as the u-blots) of slider and tightened it enough so it doesn't have any play or move at all. I have also adjusted the rest of the u-bolts on the whole slider so it is properly leveled. Also, DS bracket holes did not properly lined up with the cross member holes. So I had to grind the inner most hole of the bracket, make it a little wider so the bolt goes in smoothly.
That's it! I will post the pictures tomorrow. ![]() Note: Turns out the locknut and bolt idea is not gonna work, I'm gonna have to think of some thing else to re-enforce that bracket on DS. Please feel free to chime in. Last edited by Riad; 12-24-05 at 08:44 AM. |
Ya we need Pics cool I'm running the 4"maf kit and it rocks
Pinoy 4WD Journey
Can't wait to see the pictures.
__________________ Noel 97 LX450 (lockers retro 50%), CDL, Pin 7, HIRs, Cup Holder, 100 pads, George's LEDs, OEM grab bar, sidemarkers, ARB winch bar, PIAA 520, 295/75R16 NTG, Kaymar Deluxe with tire carrier, OME850J/863, Slee speedo gear, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter. Awaiting installation: XD9000, OEM subtank, slee SS brake lines, 3* blue bushings/caster plates, BIC 95300B dual batts. .... 94 4Runner, OEM 4.88 gear, V6 3VZE 04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, groucho sliders |
ThinkTank Waterboy
I'm not sure I could carve up a set of Slee sliders like that for those drop brackets.
__________________ Rick Bigelow '96 215k Groveland MA 01834 If you're not the lead dog, the view never changes |
Pinoy 4WD Journey
Are these drop brackets just for the front? Do you have a drop brackets in the rear for panhard rod?
#7 | |
Vacation Spots | Info Videos | Loans | Home Insurence | Loans |
