LinkBack (3) Thread Tools Display Modes
Old 12-20-05, 03:20 PM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
fatherofdaughterofromer
Romer's Avatar
TLCA# 13968
Garage
Head Gasket Thread for the FAQ
IdahoDoug had a lot of great threads on the Headgasket issue, but no overall encompassing one. There were also a few other threads of merit. So I am starting this Thread to tie to the FAQ. Please feel free to add to it with any words of wisdon or other links that somone searching through the FAQ may want or need to know.
IdahoDoug finds coolent in the oil analyis and finds Gasket blown
AAAAAAAAGH! Head gasket's blown!!
Head Gasket progress
IdahoDoug finds Head is cracked after replacing Head Gasket
Disaster - head IS cracked...
Milling of Head provides more Power
Head's done - milled .010 off for a bit of power
Reinstallation of Head
Lucy's got her head on!
Dougs Head Gasket Wrap Up
Head gasket wrap up
If it wasn't for Bad luck . . . . (Happened on a different rig though)
You guys are not going to believe this. Blew another head gasket today!
Other Forum Members Contributions
Romer's thread on Robbie's work showing before and after pictures of Carbon build-up
Cruiserdans Offical 1FZ head gasket debate
Is it my head gasket????
Head Gasket issues more common on one year than another?
Lars Head Gasket/timing chain cover work
Landtank Head Gasket Evaluation - Photos no longer there
Landtank previous Head Gasket Thread
Discussion on potential ways to see if Head Gasket was done
And what else should you check while doing the HG
New added July 2007Masons thoughts after doing a HG job
New Nov 2008 monteburns headgasket write-up with pictures
Ken Romer ~ Friend of Shaman
96 LX450 - ROD's
06 4Runner - Wife's
03 BMW Z4 Roadster
05 AT Horizon
Romer is offline   Reply With Quote
Old 12-20-05, 04:56 PM   #2 (permalink)
CJF
Very cool.
Cheers,
Curtis
CJF is offline   Reply With Quote
Old 12-20-05, 05:00 PM   #3 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
one addition, pic of #6 from a recent 97 40th, badly blown,
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is offline   Reply With Quote
Old 12-20-05, 05:51 PM   #4 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
TLCA# 11332
That is a textbook #6 cylinder fire-ring failure.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
Old 12-20-05, 10:10 PM   #5 (permalink)
Lars's Avatar
Here was my gasket @ #6....
http://members.cox.net/desertcruiser/mygasket.jpg
Lars is offline   Reply With Quote
Old 12-20-05, 10:30 PM   #6 (permalink)
cruiserdan's Avatar
TLCA# 11332
The top photo is Rick's head gasket, replaced as a PM. You can see that the fire ring is about to pull away in the 2 o'clock position. The lower photo is the new head gasket. Look closely and you can see the extension of the fire ring all the way out to the edge of the gasket.
Old 12-23-05, 11:54 AM   #7 (permalink)
Pinoy 4WD Journey
4x4CPOSEADOG's Avatar
TLCA# I'll get one soon
Is there any head gasket replacement kit available? Is the material on the new head gasket updated to a stronger material? Just wondering what kind of head gasket material do they use on 100 series with 240 hp IFZ-FE.
Noel
97 LX450 unlock, IH8MUD decals, CDL/Pin7, HIRs, Cup Holder, 100 pads, GS LEDs, OEM grab bar, sidemarkers, ARB bar/XD9000, PIAA 520, 295/75R16 NTG, Kaymar Deluxe/tire carrier, OME850J/863, Slee speedo gear/SS brakelines/caster plates, ARB fridge, silicone PHH/FHH, Xantrex 1750 inverter, auto up and H2O temp mods. Need install: OEM subtank, BIC 95300B dual batt, blue fan clutch, OEM rear locker...
94 4Runner, OEM 4.88 gear, V6 3VZE
04 Taco Ext Cab SR5 V6 TRD RR DIFF LOCK, sliders
4x4CPOSEADOG is offline   Reply With Quote
Old 12-23-05, 01:18 PM   #8 (permalink)
ThinkTank Waterboy
landtank's Avatar
If you look closely the fire ring is more than twice the sze in the new gasket as the old one. They also supported it at the rear by reducing the size of the holes at the water jacket.
Rick Bigelow
'96 215k
Groveland MA 01834
landtank is online now   Reply With Quote
Old 03-09-06, 04:39 PM   #9 (permalink)
turbocruiser's Avatar
Also, if you look closely at the new, and old, HG you see that some of the coolant passages look to be either completely closed off or mostly closed off, what is up with that??? Would it help or hurt to take the knife to that area and open it all the way up??? Thanks.
97 FZJ80, Locked & Loaded, Safari Turbo, Safari Intercooler, Ceramic Coated Custom Exhaust, Ron Davis Racing Radiator, OME HD 2.5" Suspension, DBA Slotted Rotors, New Toyota Calipers All Around, Toyota Pads, 33" Revos, ARB Front Bumper, Center Diff Switch, Slee Stuff: Roof Rack, Step Sliders, Skid Plates, SS Brake Lines, DC Drive Shaft. HG PM'd, 9.5psi and climbing, My Rocky Mountain Mojo Mobile!
turbocruiser is online now   Reply With Quote
Old 03-09-06, 05:12 PM   #10 (permalink)
cruiserdan's Avatar
TLCA# 11332
I wouldn't. That was done for a reason. NO, I don't know the reason...
Old 03-09-06, 05:43 PM   #11 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
Originally Posted by turbocruiser
Would it help or hurt to take the knife to that area and open it all the way up??? :
It would hurt badly, coolant enters the block at the front and leaves the head at the front, if the gasket was fully open the front cylinders would get a lot more flow and therefore much more cooling the rear, the rear would get almost none.
The gasket is set up to control fluid flow. The majority of the coolant travels the length of the block cooling the block and then the majority enters the head at the back of #6 cylinder and flows foreword cooling the entire head.
you will note there are only 3 large holes in the head gasket, the rest are small holes, two of the large ones are at the very back, the third is on the exhaust side of the head at #6, you will also notice that all of the smaller holes are larger on the exhaust side, the majority of heat in an engine is found in the head, especially around the exhaust port.
The small holes add in cooler coolant from the block to make up for warming of the coolant at it travels foreword in the head to hopefully apply even cooling to all cylinders.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 03-09-06, 05:46 PM   #12 (permalink)
Makes perfect sense RT, thanks man.
Old 09-15-06, 01:16 AM   #13 (permalink)
Hi guys.
I thought you guys might like to know this.
The supra 2JZ Supra head stud kit from ARP is a straight swap into the 1FZ-FE. I use a 1FZ for drag racing and have done this mod. It allows you to put significantly higher clamping force on the gasket and should significantly reduce or eliminate the head gasket failures you guys are suffering.
Cheers
Sean
Australia.
MS-75 is offline   Reply With Quote
Old 09-15-06, 08:56 PM   #14 (permalink)
bjowett's Avatar
Good to know the 2JZ stuff will work... I ended up using ARP studs that were a little longer than the 2JZ units. If the shorter units hold 700hp in your car, there should be no problem using them with the stock engines most folks are running around here.
Brian
Jowett Engineering
Western Massachusetts
08 Tundra Double Cab 5.7 Supercharged AWD
93 FZJ80, locked, 4.6L, 6 speed, Orion FORSALE
04 VW Touareg V8 w/ locker (hers)
80 FJ40 , 83k, PS and AC
05 Yamaha RS Rage Snowmobile
06 Suzuki King Quad
93 VW Corrado Syncro AWD 3.0L
51 Jowett Jupiter Roadster
bjowett is offline   Reply With Quote
Old 09-15-06, 09:07 PM   #15 (permalink)
IdahoDoug's Avatar
A 1FZ for drag racing? Please start a new thread and tell us a bit about the engine and the mods you've done to it!
Thanks,
DougM
IdahoDoug is offline   Reply With Quote
Old 09-16-06, 10:32 AM   #16 (permalink)
cruiserdan's Avatar
TLCA# 11332
Thanks,
DougM
Yes, please do tell........
Old 09-16-06, 02:24 PM   #17 (permalink)
x2
Old 09-16-06, 03:10 PM   #18 (permalink)
bjowett's Avatar
You guys need to learn to use the search function!
http://forum.ih8mud.com/showthread.p...55#post1399755
Brian
Jowett Engineering
06 Suzuki King Quad
Old 09-16-06, 04:38 PM   #19 (permalink)
cruiserdan's Avatar
TLCA# 11332
Holy shit!
Look as the size of that turbo.........
Old 09-16-06, 05:56 PM   #20 (permalink)
IdahoDoug's Avatar
Not sure my search for a turbo'd 80 1FZ engine would have caught a thread title containing neither "80" nor "1FZ" that's actually in the 100 series forum. But thanks much for the link! Wow, that's some beef.
DougM
Old 09-16-06, 06:58 PM   #21 (permalink)
bjowett's Avatar
No, it wouldn't, I'll give you that....but when someone mentions drag racing a 1FZ...and has one other post....I go check it out.
Brian
Jowett Engineering
06 Suzuki King Quad
Old 08-22-07, 08:34 PM   #22 (permalink)
suprathepeg's Avatar
If only rock would make a steel slipperplate gasket for these engines.
suprathepeg is offline   Reply With Quote
Old 08-22-07, 08:57 PM   #23 (permalink)
clownmidget's Avatar
this comany was brought up in another thread and is worthwhile investigating for headgasket replacements...
http://www.scegaskets.com/products/titan.html
Mike R.
hmmm....nuthin'
Answer a fool according to his own folly.
clownmidget is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/71980-head-gasket-thread-faq.html
Posted By For Type Date
Engine Idoling hard??? Any sugestions? - WC Forums This thread Refback 04-26-09 01:20 PM
Toyota Tacoma Rusted Frames - Fly Fishing in BC This thread Refback 03-14-09 12:51 PM
Inquiring minds want to know - Page 3 - Expedition Portal Forums This thread Refback 11-02-08 02:19 PM
