LinkBack (4) Thread Tools Display Modes
Old 06-25-08, 03:00 PM   #121
nicholas's Avatar
Originally Posted by IdahoDoug View Post
L,
It takes a bit of force, because you're actually bending the lower mounting tab a bit in order to pull the metal pipe a quarter inch from the block or so. Loosening the top mount allows this bit of 'rotation' to occur. You can't do this untill the PHH is off, and the purpose of it is to provide a bit of clearance to get the new section of hose on. Once on, you push the pipe back against the block, and the clamps hold it there once tightened, then installing the top mount further secures it.
DougM
I finished the PHH at 3:30AM after a 4 hour ordeal. In hindsight 90* needle nose pliers would have been nice to remove the inner spring clamp. The cotter pin clamp was easy to remove. I used the unorthodox bending of the lower tab method mentioned above to make enough room to install the new silicone hose. Obviously this is not the preferred method, but I wanted to get it done and I didn't have the tools handy to remove the lower bolt.
I thought I might add a little tip I discovered that may help someone in a similar bind, especially if stuck away from home.
I wasn't worried about losing anitfreeze so I just removed the clamps using similar methods mentioned in this thread. I found that the antifreeze that was leaking out from removing the cotter clamp actually helped me slide the engine block side clap off.
After removing the the old hose with needle nise pliers I removed the top bolt and non-PHH that runs along the top of the engine bay. This allowed me to swilvel and bend the lower tab to make room for the new hose.
I placed the new hose on the engine block and aligned the down tube with the new hose as best I could. I was having trouble bending the pipe back into the original position when I saw the OEM bottle jack handle on the floor.
The hook end of the jack handle fits perfectly on the pipe and it allowed me to push and bend the pipe back to near original position with enough leveravge.
My only worry about using this method is that bending the lower tab might cause a leak by breaking the weld near the tab on the pipe. This didn't seem to be the case and it seems like others have had success with this method.
It feels good to have it done. Let hoep I won't have to mess with it for another 10+ years.
97LX450, 141K, 285CooperSST's, OME851/860's, S/C, CDL 7-Pin, Landtank MAF, Slee SS lines, 100 pads, silicone PHH, Raventai temp, CDan parts throughout($5K+). Chillin' in Cornfeilds (IA) studying.
nicholas is online now   Reply With Quote
Old 07-04-08, 05:52 PM   #122
I just got done replacing my PHH. After reading all of the threads, I was thinking that it might be a little easier than it was. I couldn't get the lower bolt loose which ended up not being a major problem.
I did use a heat gun to soften up the new hose a little. I am halfway through replacing all of the other coolant hoses. My fingers need a rest.
94 Landcruiser
milehighroller is offline   Reply With Quote
Old 07-04-08, 07:48 PM   #123
98 SNAKE EATER's Avatar
Samco Sport and the clamps they came with
The original came out easily and looked like it could go another 111,111 miles
98 SNAKE EATER is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/6994-phh.html
Posted By For Type Date
engine diagnosis pointers - Rising Sun Member Forums This thread Refback 08-28-08 09:19 AM
80 series where to buy, what to look out for - Page 2 - Expedition Portal Forums This thread Refback 08-04-08 01:37 AM
Lexus Owners Club (USA) Forums > Blown Head Gasket This thread Refback 02-06-08 09:38 PM
Blown Head Gasket - Lexus Owners Club (USA) Forums This thread Refback 01-01-08 09:42 PM
Loans | Jordan XXI | Magic the Gathering trading | Free Host | Books
