Home Forum Gallery CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
Follow IH8MUD on Twitter Visit IH8MUD on Facebook
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
LinkBack (12) Thread Tools Display Modes
Old 11-02-05, 06:37 PM   12 links from elsewhere to this Post. Click to view. #1
buckroseau understudy
Cruiser Jimmy's Avatar
Tranny Rebuild -Shadetree Mechanic Style
Fellows, I've decided to rebuild my tranny myself for the education.
The below is a narrative of an email to Rodney in OZ about the tranny.
The trans (A440F) has been acting weird lately for the past 6 days and it's finally come to a head. For the past 5 days the trans felt like it "released" the engine before it would upshift from 2nd to 3rd. By "released" I mean that the engine would rev say from 3500 rpms up to 4500 rpms before the trans would step into 3rd gear.
Well yesterday, the trans does not want to upshift to 3rd gear. I have to feather the gas to find 3rd, but that's only momentary.
At the same time I have checked reverse and found that I have to go to full throttle for reverse to kick in, otherwise I can go to 1/4 throttle before the rigs ever starts to move.
History of the Trans:
About three years ago the trans was rebuilt by a local tranny shop.
It over heated [A/T Oil Temp light] on 2 or 3 separate occasions after the rebuild and I replaced the fuild every time it over heated. Then I bought a tranny cooler from AutoZone and installed, the largest square inch I could find.
Not that this has anything to do with the trans operation, but the speedo cable broke last week the same time the trans started acting up. I just replaced the speedo cable last night.
Additionally, I was wheeling about a month ago and this hill was giving me hell. On four occations I got to the top of the hill and the rigs was rev'ing but not going anywhere. (wonder if I burnt something, ya' think)
Well, Rodney came back and basically stated what I suspected, the 3rd gear clutch is burnt, 3rd clutch also controls reverse operations.
So I've started the operation and will be replacing the clutches once I pick them up.
By the way, I bought the A440F rebuilt book from Toyota. That's the first thing one should do.
Future search requests:
Tranny rebuild
Transmission rebuild
Rebuild transmission
Here's a MUD salute to the operation.
TLCA Chapter Club
'78 FJ45 Longbed,'83 FJ60
On the BRP Can-Am Spyder Marketing Tour
Cruiser Jimmy is offline   Reply With Quote
Old 11-02-05, 06:40 PM   #2
Here's one with the tranny fully disassembled.
Wish me luck.
Edit 12-29-05:
Disassembly is pretty easy. Take out the 11 bolts that hold the ATF oil pump to the body, take out the six bolts that hold the two brake housing in place in the body and everything else just comes right out.
You'll have a little trouble taking the oil pump out if you don't have a special tool. This is easily overcome by placing two bolts on the oil pump (used for pulling it out with the SST) and rotating it until it breaks free.
Once the pumps out just start taking the components out.
TLCA Chapter Club
Sponsor 11-02-05, 06:45 PM
Sponsored Link
advertisement
Old 11-02-05, 06:45 PM   #3
peebles24's Avatar
Jim dosen't that require special tools. I know the chevy trannies I've rebuilt do. Oh and by the way good luck, if you need some help give me a holler. I will come if the wife will let me off the leash.
Chad
1991 FJ80 mostly stock, for NOW. First ever Toyota
1976 FJ40 with a bunch of stuff done. SOLD you will be missed.
check out my ROTW http://forum.ih8mud.com/showthread.php?t=84748
Second Toyota and I'm sure there will be more.
www.hoosiercruiser.org
Check out a web site I put together about my trucks and the Hoosier Cruisers http://www.cardomain.com/ride/2113715
or you can visit me on myspace http://www.myspace.com/cruiserpeebles
peebles24 is offline   Reply With Quote
Old 11-02-05, 06:50 PM   #4
Chad
Yeah it does. I have tried to get them from the Sealership but they say it's only a purchase for the service guys. Most of the special tools I need are for attachments to a dial indicator, but two or three special tools are for compressing springs. If I can't get the springs off, I'll have them made by a local machine shop, that's my only option.
TLCA Chapter Club
Old 11-02-05, 06:52 PM   #5
ThinkTank Waterboy
landtank's Avatar
I know that Slee offers a swap for Rodneys transmissions with the modified valve body. Was that option considerably more than what you're doing here?
Rick Bigelow
Groveland MA 01834
Find your LANDTANK items at AJIK Overland Exchange
Old 11-02-05, 06:57 PM   #6
Here's the problem.
These clutches are from the Brake Band & Multi-Disc Clutch (or Clutch C2 when looking at the manual.) These clutches should have material on it. Guess that's way I had no up shift.
TLCA Chapter Club
Old 11-02-05, 07:01 PM   #7
Yes, it was a serious consideration. I wanted to buy an Extreme tranny/valve body from Rodney but my wallet had other plans.
The rebuild kit from "Axiom" is sub $1K for all seals, gaskets, clutches and steel plates.
TLCA Chapter Club
Old 11-02-05, 07:01 PM   #8
Benji's Avatar
One brave man, good luck. If you need help, give me a hollar.
Hoosier Cruisers http://www.hoosiercruiser.org/
84 FJ60 - TLCA # 14119
Benji is offline   Reply With Quote
Old 11-02-05, 07:07 PM   #9
http://toyota.spx.com is where to get the toyota special tools.
Rich is offline   Reply With Quote
Old 11-02-05, 07:10 PM   #10
Here's the first measurement:
Using a dial indicator, measure the thrust clearance of the input shaft
Standard thrust clearance: 0.40-0.90mm
My result: 1.1mm
TLCA Chapter Club
Old 11-02-05, 07:14 PM   #11
Rich,
Thanks so much. My two local Stealerships did not give me any value added information. One would not give me the information and the other did not know what I was talking about, "SST. . . What's an SST"
I hope he was new!!!
TLCA Chapter Club
Old 11-02-05, 07:31 PM   #12
Here's a shot of a steel plate. It must be replaced.
TLCA Chapter Club
Old 11-02-05, 07:34 PM   #13
Parts Geek, M1 Mechanic
cruiserdan's Avatar
Regretably the SST's he inquired about are discontinued.
Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock. 2009 Dodge Challenger SRT8, 465 horse HEMI, 6 speed manual trans, cop-attracting-red. Kimberly Kamper and some Garands.
Old 11-02-05, 07:39 PM   #14
CD, Even the SST kit that's on SPX?
TLCA Chapter Club
Old 11-02-05, 07:53 PM   #15
Here are all the clutches
Edit 12-29-05:
The three sets of smaller clutches are what hold preasure to the gearing. The larger clutches are for braking when changing gearing.
TLCA Chapter Club
Old 11-02-05, 08:08 PM   #16
IdahoDoug's Avatar
Awesome. Simply awesome.
DougM
'93 FZJ since new, 2.2kw starter, Revo 275s (Michelin Alpins in winter), locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin X-Ice in winter. 1987 Vanagon Syncro
IdahoDoug is offline   Reply With Quote
Old 11-02-05, 08:40 PM   #17
Rookie
Great pics, keep us posted.
One question - doesn't the tranny weigh a ton?
How'd you get it in your workspace to begin with?
g.
absurdum80 is offline   Reply With Quote
Old 11-02-05, 08:52 PM   #18
baxter650's Avatar
3 years on a rebuild, i hope you at least gave them a call to tell them they suck at rebuilding.
1980 PU 350 TPI SBC 38" Swampers
1993 FZJ80 6" slee lift 37s
1978 FJ40
2011 FE570s HUSABERG
My 83 BJ60 bobbed, SOA, frame up, money pit, build. http://forum.ih8mud.com/60-series-wa...t=pics+tonight
IF BIGGER IS BETTER THEN TOO BIG SHOULD BE JUST RIGHT.
TLCA#20985
baxter650 is offline   Reply With Quote
Old 11-02-05, 09:53 PM   #19
cruiserdan's Avatar
If it's the 09350-36010-01 yes, it is discoutinued.
Old 11-02-05, 09:54 PM
Sponsored Link
advertisement
Old 11-02-05, 09:54 PM   #20
Bummer.
Lubens, I'd suggest that you call the contact number at SPX. They are not a Toyota company. They are a partner of Toyota. OTC is a tool manufacturer that SPX acquire, and they make general purpose automotive tools in addition to the special tools they manufacture for a number of auto companies. It is possible that for some of the Toyota SSTs they may have an OTC version that may be sufficiently similiar to get the job done.
Trackbacks are Off
Pingbacks are Off
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/65907-tranny-rebuild-shadetree-mechanic-style.html
Posted By For Type Date
fj62 transmission q's - Toyota Nation Forum : Toyota Car and Truck Forums This thread Refback 12-12-11 11:00 AM
RMLCA - Rocky Mountain Land Cruiser 4x4 Association This thread Refback 01-05-11 05:37 PM
Off-roaders Club Forum > ესეც ჩემი TOY This thread Refback 06-26-10 12:39 PM
ესეც ჩემი TOY - Off-roaders Club Forum This thread Refback 05-08-10 12:20 PM
A440F Transmission - TLCWiki This thread Refback 12-08-09 07:24 AM
Untitled document This thread Refback 09-17-09 11:09 AM
[3FE] Re: A440F Rebuild web/link site? This thread Refback 12-19-08 07:19 PM
Toyota4X4.RU > <> This thread Refback 10-07-08 05:06 PM
Toyota4X4.RU -> This thread Refback 07-16-08 05:46 PM
Toyota4X4.RU -> This thread Refback 05-03-08 01:35 AM
Toyota4X4.RU > This thread Refback 01-09-08 08:28 PM
fj62 transmission q's - Toyota Forums :: Toyota Nation This thread Refback 01-08-08 07:46 PM
vBulletin® ©2000 - 2012, Jelsoft Enterprises Ltd.
2000-2012 by IH8MUD.com - ALL RIGHTS RESERVED
