Home Forum Gallery CruiserFAQ Tech Links Store
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
Follow IH8MUD on Twitter Visit IH8MUD on Facebook
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
LinkBack (87) Thread Tools Display Modes
Old 10-20-05, 03:05 PM   84 links from elsewhere to this Post. Click to view. #1
RavenTai's Avatar
93-97 Coolant Temperature Gauge Modification
Why
To prevent us from worrying about coolant temperature fluctuations and the service calls that would result Toyota designed the coolant temperature gauge to be numb to changes in temperature in a band centered near normal operating temperature. This makes for a gauge that moves towards the center during warm up and then just sits there unmoving under normal conditions. This is nice until the engine heads towards an overheat, the gauge will not tell you anything until you are well on your way.
One way around this is to install an aftermarket temperature gauge, there are some down sides to this, they are expensive and use up space that could be used for other things. You also loose the stock look of the interior if that is important to you. The upside of an aftermarket gauge it that you get actual markings of the temperature instead of reletive needle position on a mostly blank background.
Fortunately this numb zone is caused by just 2 components soldered on the circuit board of the gauge. All we need to do is replace a Zener diode and a 75 ohm resistor with 2 new resistors one 50 and the other 110 ohms. The amount of work to mod the gauge I would think is comparable to properly installing an aftermarket gauge and should take you 3 hours or less.
Many Thanks to Semlin & David Dearborn ( dd113 ) for donating gauges, this mod would not have been possible without them.
Also thanks to all that contributed to the development thread. this was a group effort. thsi is also a good place to go if you want to look "under the hood" on how all of this works.
How
Please note that like any work you can damage you truck by performing this modification, you are responsible to see that everything is done correctly, resulting damages rest solely on your shoulders. But anything can be repaired if you have enough time and money.
Tools required
#2 philips Screw driver
#2 philips stubby or ratcheting angle screwdriver
Small Pair of dikes
Pick set
Small soldering iron (~40 watt)
.032” Flux/rosin core solder
De-soldering braid and/or bulb
Drill (smaller the better) array of drill bits
And although a digital multimeter is not required to do the mod it is recommended.
Parts
edit 1/08, Fixed links thanks to NLXTACY
50 Ω 3 watt 1% wire wound mil spec resistor.
Mouser P/N 71-RS2B-50
MFG P/N RS02B50R00FB12
RS02B50R00FB12
110 Ω 3 watt 1% wire wound mil spec resistor.
Mouser P/N 71-RS2B-110
MFG P/N RS02B110R0FB12
RS02B110R0FB12
Originally Posted by tonyteb View Post
FYI
Australian Supplier for the 2 resistors
Wirewound Resistors - Through Hole 3watts 110ohms 1%
RS02B110R0FB12
http://www.x-on.com.au/details-new.a...RS02B110R0FB12
Wirewound Resistors - Through Hole 3watts 50ohms 1%
RS02B50R00FB12
RS02B50R00FB12 - Price from: $1.07 | Vishay/Dale | Passive Components | Resistors | Through Hole Resistors | Wirewound Resistors
These resistors are 82 cents each, shipping will cost much more than the resistors them selves so get 2 each or more just in case, especially if you know other 80 series owners you will collectively will save on shipping.
If you have any bulbs out in the cluster now is a good time to order them from Dan. from left to right the bulbs are
air bag, ABS, AT/Oil temp, CDL, blank, check engine, seatbelt, cruise, high beam,__________ space________brake, low oil, A/TP (tecase neutral wile trans in park) blank, front locker, rear locker, air filter clogged (not lamped in the US), and finally door open
there are also the gear indicatoor lights and the back lighting for the cluster.
Accessing the gauge:
For removing the cluster See the FSM it has some good pictures, here it is in my words. All directionals (left/right. foreword/aft up/down) down are trucks view. The dash can be damaged during disassembly, there are many push pull clips, if you are doing it right these only take light pressure to release, always pull the panel strait out as close as possible to the clip and never pry at the opposite end of the panel from where the clip is, if it feels like you are about to break something you probably are.
1. Remove the drivers knee panel by removing the 2 screws on either side of the hood/fuel release, one screw one the lower right side and one near where the hand throttle would be ). Gently Pull along the upper edge and release the 3 clips. Disconnect the speaker wire. You can let it hang by the fuel/hood cables and work around it or go through the trouble of removing them, to remove the releases remove the screws and pull the release all the way out then slide them forward
2. The next dash section up wraps around from the key cylinder over the steering column to the left hand buttons. Start at either end and gently pull working your way through the 8 clips, release the connectors to the locker switch, light dimmer and mirror control. Each one of the connecters releases in a different way, the dimmer is a side press, the mirror control a top press and the diff lock switch has a very small release on top of the connector. A pick is quite handy here.
3. Remove the upper half of the steering column cover by removing the two most aft screws on the bottom of the column then releasing two clips at the front of the cover. The bottom half can stay.
4. Remove the Cluster finish panel, this panel houses two vents on either side of cluster and is slightly tricky. Remove the two screws at the top center. It has two clips at either end just outside the vents but also has some interference to the dash pad, first release the clips by pulling but not too far then work the panel around the dash pad (see pic ) to not cock the panel at any time, only pull strait out. The clips that hold the vents to the panel cannot take much load
5. Now with the cluster exposed you will see 4 white legs with a screw in each, there are two above and two below the cluster. Remove these, carefully work the left side of the cluster out, you will have to pull the right side out some also, the right side interferes slightly with the upper center dash. After you get the left side out some you will be able to push the cluster outboard and the center dash inboard and work the cluster past. The first goal is to get the left side of the cluster out far enough to get you hand in (see pic) , you will release two wire bundle connectors there, with those two released you will have enough slack to be able to flip the top of the cluster aft and down to access the other two connectors and then pull the cluster out
6. Remove the gauge from the cluster. first the cluster splits in two, the gauges and a white backing are one half, the "glass" and black mask in the other. There are clips around the perimeter lift each one in turn by hand and the two halves will split, after the glass is off be careful not to set the cluster on its face, the cards and needles are kind of fragile. Try not to not touch the face cards of any of the gauges, fingerprints leave marks, there are 4 screws (see pic) back these screws out partially and then press them with moderate finger pressure. the gauge will seam stuck at first but then will pop up a little bit, if is fells wrong or partially attached stop and give it a good looking over, completely remove the screws and then work the gauge out, it had some slight interference with the tack card but it can be worked out of there. Be careful the tach needle does not receive any load.
Modify the gauge
If you do not know how to work with solder give these a read
7.1.1 Soldering Basics
EPE "Basic Soldering Guide"
First need to secure the gauge so that you will have two free hands but the gauge is not resting on the needles, there is an area of the PCB that can be clamped in a vice at a corner, when you need to apply even light force to the PCB also support it with your hand, do not bend the PCB.
More secure clamping method provided by Rookie2 IH8MUD.com Forum - View Single Post - 93-97 Coolant Temperature Gauge Modification
The two components we are interested in are a 75 ohm resistor and a Zener diode (see pic) both of these have two connections each for a total of 4 connections, the resistor looks somewhat like a peanut and is just over ¼” long on the back of the PCB it is marked with a zig-zag line , the zener diode is a tiny red bead it is marked on the PCB by a rectangle with a stripe at one end.
First we need to remove both of these components, de-solder these 4 connections straighten out the wires and push them through, if you have any troubles with them hanging up on solidified solder use the tip of your soldering iron. Using the soldering iron as a tool is handy as it will keep the solder flowing wile you move stuff around. Then remove any excess solder as necessary to have the holes open to allow insertion of the new components, a small amount of solder left on the pad of the PCB is acceptable and actually desirable.
The 110 Ohm resistor will replace the 75 ohm resistor; first bend the leads of the resistor to until they are parallel to each other and perpendicular to the resistor. You do not want to bend them tight right as it comes out of the resistor, this may form cracks in the wire that could cause the lead to break with vibration rendering the gauge useless. Set a ~1/8” drill bit against the resistor touching both the resistor and the lead, bend the lead 90* over the bit this will form a radius. You want the two legs spaced as close as possible to the width of the two holes in the PCB, trim the two leads just enough to get between the PCB and the face card of the gauge, This resistor can get hot in use so we want air flow around it, we also want to keep it away from the clear plastic light guide and the needle motor, I let it naturally hang with gravity and put it closer to the PCB (but not to close) than the face card and it seamed about right (see pic) solder it in place then trim the excess lead.
The zener diode is replaced with the 50 ohm resistor. The holes for the zener diode were smaller than the leads of the resistor, chuck up a very small drill bit (same size as the lead of the resistor) in a drill and turn the chuck by hand to enlarge the holes. These holes are closer together than the width of the resistor so you will need to bend one of the legs into a joggle, make a180° bend at the end of the resistor then a 90°bend at about the middle of the resistor, bend the other one 90* at a location that will achieve proper spacing, trim the leads so that more than enough will go through the hole to support the resistor. this resistor does not get hot and due to its location is easier to install this one on the bottom of the PCB opposite of the other resistor. There is clearance in the cluster to do so just keep it tight against the PCB (see pic)
If you have a meter check the connections. the resistance of the joints should no be more than 1 ohm higher than the resistance you get with your probes touched together, Check the resistance from the sense post (top post in the pictures) to the two close legs of the two resistors, the other leg of the 110 ohm resistor is checked to the + post (lower left in the pictures) , the other leg of the 50 ohm resistor is checked to the nut marked “U”, there is a thin coating on the nut you need to pierce to make a connection
Extra credit: add these characters to the 4 existing characters on the bottom of the gauge 注:中温安定ではありません。 (may not display correctly on some computers)
The original 4 say "middle temperature stable, the new text is "no longer middle temperature stable" Thanks Mot
Reassembly is reverse of disassembly, one note wile pushing the cluster back into position look at the left side between the vent and cluster the bundle can get caught up on a vertical piece of the dash and pinched preventing the cluster from seating, gently help it around this piece with a screwdriver
Originally Posted by boydmick
The only thing I can add is when reinstalling the gauge cluster, be sure to use the shorter screws for the top two locations.
I didn't keep track of which screw came from which spot and started to put a longer screw in the top. It bottomed out on the dash pad and pushed it upward just a bit. As soon as I noticed, I replaced the screw with a shorter one. No contact then.
Boyd
Results
You now have a gauge that will move with all temperature changes within its sensitive range.
Full sweep peg to peg is 94°
Pegged hot 244°
Top of red is 227°
Bottom of red 217°
Center is approximately 189°
Cold line is 160°
Pegged cold 150°
Notes
“Center” is pretty much horizontal. It is the middle between the bottom of red and the cold line, witch is not the same as center of the full range of the gauge. Some describe “center” as the just below the middle, also the needle sits high above the face card with the markings making it quite susceptible to parallax error, at any rate after warm up wherever your needle sat before mod is the “center” point for our purposes.
Please give feedback on how this goes for you. And what changes can be made in the directions to make it clearer. If you find any tips or tricks along the way please post 'um up
93-94 trucks Thanks to the effort of Semlin a mod is in the works.
Edit 3-15-05, the same mod also works for 93-94 trucks within a few degrees, accessing the gauge may be a little diffrent as the dash is diffrent on the 93-94 trucks, if anybody does one of these would you mind taking notes on accessing the guage.
91-92 trucks so far nobody has championed this one.
1988 FJ62
1996 LX450
1999 LS400
A Government Is a Body of People, Usually Notably Ungoverned
RavenTai is offline   Reply With Quote
Old 10-20-05, 03:06 PM   #2
RavenTai's Avatar
pictures
1988 FJ62
1996 LX450
1999 LS400
Sponsor 10-20-05, 03:07 PM
Sponsored Link
advertisement
Old 10-20-05, 03:07 PM   #3
RavenTai's Avatar
more pictures
1988 FJ62
1996 LX450
1999 LS400
Old 10-20-05, 03:12 PM   #4
ThinkTank Waterboy
landtank's Avatar
Nice job, I ended up with both resistors on the inside of the board. I was considering what you did with the 50ohm but was in to much of a hurry to wait for your response.
Rick Bigelow
Groveland MA 01834
Find your LANDTANK items at AJIK Overland Exchange
Old 10-20-05, 03:27 PM   #5
Tools R Us's Avatar
Great mod!
Copper State Cruisers #007
Tools R Us is online now   Reply With Quote
Old 10-20-05, 03:32 PM   #6
RavenTai's Avatar
It will have the same effect either way. getting to that spot did not look like much fun and since this one does not get hot I opted for the easy way out.
1988 FJ62
1996 LX450
1999 LS400
Old 10-20-05, 03:36 PM   #7
RavenTai's Avatar
Thansk TRU
1988 FJ62
1996 LX450
1999 LS400
Old 10-20-05, 03:41 PM   #8
The quick brown fox .....
Beowulf's Avatar
Thanks Raven. You did a great job leading up to this mod and an especially good job on this post that documents everything.
-B-
97 FZJ80 - Locked, 315 GY MT/Rs, 4.88s, Slee 4", George's sliders, Slee bumpers, Warn M12000, OBA, Yaesu 7800, Outback drawers, INTI rack + other stuff.
Old 10-20-05, 04:09 PM   #9
concretejungle's Avatar
Oh, man, great mod! I will have to be amongst the elite in order to pull that off. Maybe a little later down the road.
95' FZJ80 OME med./J lift, ARB rack, ARB Bull Bar w/tmax 12,500, 35" truxus, Aussie locker-rear, Center Diff Lock, Sliders, IPOR Skid, IPOR rear bumper, upgraded slee sticker, custom dents, more to come. . .
Go 80, or go unsatisfied
concretejungle is offline   Reply With Quote
Old 10-20-05, 04:14 PM   #10
informationjunky's Avatar
http://forum.ih8mud.com/showthread.php?t=58967
Upstate Cruisers
http://www.upstatecruisers.net/
TLCA 6149
86 FJ60 - first and RIP
95 FZJ 80 - second RIP
97 LX 450 - Current
locked, ARB, 850J's Front and 863's rear, slee drop blocks, 315's, and M12000, Devo sliders, Iron Pig rear bumper, skid on garge floor
98 LX 470 - wifes
"IH8MUD is a private business, operated as a sole dictatorship. Everyone gets a vote, but only mine counts." - Woody
America's downfall - a lack of common sense.
informationjunky is offline   Reply With Quote
Old 10-20-05, 04:40 PM   #11
MTNRAT's Avatar
I think this has to go in STICKY in mods.
Sean
97 lx450, factory lockers, slee springs, 315/75R16 MTR,s,4.88s, supercharged,ARB, m12000, slee rear bumper and tire carrier, slee sliders,
MTNRAT is offline   Reply With Quote
Old 10-20-05, 04:47 PM   #12
RavenTai's Avatar
Thanks -B-,
CJ dotn let the long winded detailed text fool you, If you can folow directions you can do this mod, no electrical knolege required. just put the parts in the right place.
IJ sorry I am more a jack of all trades, I am not an EE. BTW are you still looking for the parts to fix your side damage? I know where a white LX is sitting in our area. PS is good.
1988 FJ62
1996 LX450
1999 LS400
Old 10-20-05, 05:28 PM   #13
Originally Posted by RavenTai
Thanks -B-,
Na, I figure if I fixed it I would crunch it on the next ride. Thanks though. "Jack of all trades" smarter than most EE's I've worked with.
Upstate Cruisers
TLCA 6149
97 LX 450 - Current
98 LX 470 - wifes
Old 10-20-05, 07:12 PM   #14
Raven,
Thank you for all the hard work. This is on my short list.
1997 FZJ80, locked, ARB bumper, Landtank MAF, 285 Michelins, auto up window mod, breathers relocated, 194k miles
1974 FJ40, front disks, 2F motor from a bus
1987 Grand National
1947 Indian Chief stroked to 80"
hobbes is offline   Reply With Quote
Old 10-20-05, 07:15 PM   #15
Sweet! I have to get in the cluster and replace my burned CEL so that I can pass AZ emissions (among other things)! Of course, the D light is out too. Great writeup for getting into the instrument cluster. I may do this mod while I'm in there.
- Craig
Whipp is offline   Reply With Quote
Old 10-20-05, 07:32 PM   #16
Lockd97's Avatar
Excellent work!
This isn't a STICKEY yet?!?!
Scott-
97 40th S/C'd Landtank MAF WBO2 Locked CDL
OME 850/860's shocks NITTO's air bags heated seats
98 Tacoma S/C'd w/fuel mods piggyback'd
Lockd97 is offline   Reply With Quote
Old 10-20-05, 07:36 PM   #17
You want to do what...?
e9999's Avatar
RT comes through again!
excellent engineering job, my friend, this is no hacking, this is good thinking...!
Man is this forum great or what? But it's all cuz of you supermechs types...! Talented but also willing to go the distance for the group...
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar Tradesman full rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!).
: '03: 125K
DDs: Accord, Prius
: souped-up DR650
Old 10-20-05, 09:01 PM   #18
RavenTai's Avatar
cleaned up the text a bit and fixed the resistor links (cannot copy shortened links directly from forum pages) got some things about lights I want to add but no time right now, wile I had the cluster out I did note the position of all the lights at the bottom.
IJ & Eric you guys are too kind,
Hobbes & Whipp have at it and tell us how it goes. AFIK as of right now only mine and Ricks are modified, both of us are pleased with them, both of our trucks also had earlier beta versions of the mod. (too sensitive)
MTN & Locked let Junk know about it and he may put a link to it in the FAQ,
1988 FJ62
1996 LX450
1999 LS400
Old 10-21-05, 07:07 AM   #19
Great work Raven; this will go to the top of "todo" list.
D.F.Morse
1994 FZJ80 Kazumatized 85000 mi
1979 FJ-40 75000 mi
Here endith the lesson
dfmorse is offline   Reply With Quote
Old 10-21-05, 12:50 PM
Sponsored Link
advertisement
Old 10-21-05, 12:50 PM   #20
CreeperSleeper's Avatar
Garage
Sean
Agreed. Thanks to everybody to helped develop this. I would read the development thread, but I was way lost. You guys are amazing.
Chad - KE7VSA
Cascade Cruisers - Jefferson State Cruisers
facebook.com/CreeperSleeper - facebook.com/CascadeCruisers - facebook.com/McCulloch.Insurance
FZJ80 - 37's, lifted, locked, geared, cut and dented. *SOLD*
'84 P/U - 37's, locked, linked, etc Project Turn-Key
'00 LX 470 - daily, expo & tow rig
CreeperSleeper is offline   Reply With Quote
Trackbacks are Off
Pingbacks are Off
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/64252-93-97-coolant-temperature-gauge-modification.html
Posted By For Type Date
Forum Toyota Land Cruiser Owners Club • Zobacz w?tek - jak sobie poradzi? z przegrzewaj?cym si? silnikiem This thread Refback 05-01-12 01:38 AM
View topic - Hilux Temperature Gauge Erratic | Australian 4WD Action This thread Refback 03-06-12 01:00 AM
H4K • Se emne - Temperature Gauge Mod This thread Refback 03-03-12 07:57 AM
sonde de temperature moteur - Page 9 This thread Refback 01-12-12 01:11 PM
93-97 Coolant Temperature Gauge Modification - Page 12 This thread Refback 12-14-11 07:46 AM
OIL LEAK 1KZTE EGR CONTROL - Page 2 This thread Refback 12-13-11 04:27 AM
Ptarmigan mods - 1995 FZJ80 - Rising Sun Member Forums This thread Refback 12-05-11 10:10 PM
The Toyota Landcruiser Owners Club :: View topic - Fitting a seperate cooler to auto box This thread Refback 10-18-11 03:46 PM
99 UCF21 dead speedo? - Club Lexus Forums This thread Refback 10-04-11 04:11 AM
Living well in Tamarindo, Costa Rica: Travel, Land Cruisers, Gardening, Food, and Jewelry: January 2010 This thread Refback 09-22-11 04:29 AM
Forum Toyota Land Cruiser Owners Club • Zobacz wÄ…tek - jak sobie poradzić z przegrzewajÄ…cym siÄ™ silnikiem This thread Refback 08-17-11 04:32 AM
Tarbe's 80 series - Page 2 This thread Refback 08-10-11 11:40 PM
Thanks - Estima Owners This thread Refback 05-02-11 09:58 PM
RangeRovers.net • View topic - Temperature gauge feed This thread Refback 05-01-11 02:48 PM
4x4Wire's TrailTalk Forums: Anyone tried the Raventai gauge mod on our trucks? This thread Refback 04-29-11 01:35 PM
RangeRovers.net • View topic - Temperature guage feed This thread Refback 04-23-11 11:31 PM
Untitled document This thread Refback 02-27-11 09:09 AM
Latest Sandcruiser v4.4 This thread Pingback 02-07-11 03:17 PM
Tarbe's 80 series - Page 2 - Expedition Portal Forum This thread Refback 01-30-11 12:52 AM
Possible Temperature Gauge Deadzone Solution - ToyotaDiesel.com This thread Refback 12-24-10 12:59 AM
Sandcruiser.com | Adventure Continues | Page 4 This thread Refback 12-15-10 09:36 PM
Water temp gauge? This thread Refback 12-09-10 08:32 PM
Forum Toyota Land Cruiser Owners Club • Zobacz wÄ…tek - jak sobie poradzić z przegrzewajÄ…cym siÄ™ silnikiem This thread Refback 11-27-10 08:54 AM
Some cooling info with the 1st gen cluster....need confirmation - YotaTech Forums This thread Refback 09-07-10 10:14 AM
fyi!!!head gasket or internal coolant leak... - Club Lexus Forums This thread Refback 08-30-10 02:26 PM
Forum Toyota Land Cruiser Owners Club • Zobacz wÄ…tek - jak sobie poradzić z przegrzewajÄ…cym siÄ™ silnikiem This thread Refback 08-16-10 07:40 AM
Forum Toyota Land Cruiser Owners Club • Zobacz wÄ…tek - jak sobie poradzić z przegrzewajÄ…cym siÄ™ silnikiem This thread Refback 08-12-10 03:05 PM
Offroad 80's • View topic - 1hd-ft gettig hot This thread Refback 08-08-10 03:44 AM
The Toyota Landcruiser Owners Club :: View topic - Temperature Guage This thread Refback 07-21-10 08:20 AM
Offroad 80's • View topic - 1hd-ft gettig hot This thread Refback 06-30-10 11:29 PM
Toyota 4WD Surf Owners :: View topic - Possible Temperature Gauge Deadzone Solution? This thread Refback 05-29-10 04:44 PM
Living well in Tamarindo, Costa Rica: Travel, Land Cruisers, Gardening, Food, and Jewelry This thread Refback 04-21-10 02:09 AM
Hilux Temperature Gauge Erratic - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 04-14-10 09:13 AM
sonde de temperature moteur This thread Refback 04-03-10 07:20 AM
Offroad Express 4wd Forum | OffroadExpress 4wd Forum This thread Refback 03-28-10 11:23 PM
Living well in Tamarindo, Costa Rica: Travel, Land Cruisers, Gardening, Food, and Jewelry: Fixing Gauges This thread Refback 01-25-10 01:33 PM
Lexus Owners Club (USA & Canada) > Instrument Panel Replacement Light Bulbs This thread Refback 12-26-09 08:39 PM
Instrument Panel Replacement Light Bulbs - Lexus Owners Club (USA & Canada) This thread Refback 12-22-09 10:00 AM
Hilux Temperature Gauge Erratic - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Refback 11-25-09 07:12 AM
Hilux Temperature Gauge Erratic - Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. This thread Pingback 11-25-09 02:59 AM
Temp gauge needle - TTORA Forum This thread Refback 11-19-09 04:53 PM
Toyota Landcruiser 100 Series ‘98-‘04 Temp Gauge Mod :: LandCruiserWiki.info This thread Pingback 11-18-09 02:30 AM
DARWIN4X4.NET - THE TOP END'S 4X4 ONLINE COMMUNITY • View topic - 80 running warm This thread Refback 11-08-09 03:00 PM
Have we all seen this yet? - Page 3 - Hilux Surf Forum This thread Refback 10-28-09 12:48 PM
Toyota Landcruiser Owners Club (UK) :: View topic - Temperature Guage This thread Refback 10-21-09 01:58 PM
DARWIN4X4.NET - THE TOP END'S 4X4 ONLINE COMMUNITY • View topic - 80 running warm This thread Refback 09-21-09 02:25 PM
Outer Limits 4x4 Board :: View topic - 1HDT Over heat! This thread Refback 04-08-09 01:26 AM
Toyota Landcruiser 100 Series ‘98-‘04 Temp Gauge Mod | Paul's esoteric meanderings This thread Pingback 04-05-09 11:00 PM
Outer Limits 4x4 Board :: View topic - Want to make your OEM Toyota temp gauge work properly? This thread Refback 03-30-09 02:53 AM
Outer Limits 4x4 Board :: View topic - Want to make your OEM Toyota temp gauge work properly? This thread Refback 03-30-09 12:46 AM
BMWClub > Sa eliminam buffer-ul de la ceasul de temperatura. This thread Refback 03-07-09 09:12 AM
Sa eliminam buffer-ul de la ceasul de temperatura. - BMWClub This thread Refback 02-26-09 02:53 AM
whos interested if i make these? - Page 7 - Hilux Surf Forum This thread Refback 01-27-09 12:20 PM
sonde de temperature moteur - Page 9 - Forum 4x4 This thread Refback 01-14-09 11:35 AM
Offroad-Express • View topic - turbos on hilux surf This thread Refback 01-01-09 02:02 PM
Overlander 4WD :: View topic - Does your vehicle handle the heat ? This thread Refback 11-22-08 03:07 AM
Removing the buffer in the stock temp gauge - Page 2 - Bimmerforums - The Ultimate BMW Forum This thread Refback 11-04-08 12:15 PM
Temp gauge needle - TTORA Forum This thread Refback 10-05-08 06:03 PM
Possible Temperature Gauge Deadzone Solution - ToyotaDiesel.com Forums This thread Refback 07-21-08 04:44 AM
Temperature Gauge Modification. This thread Refback 07-12-08 04:54 AM
Offroad-Express • View topic - turbos on hilux surf This thread Refback 07-09-08 07:16 PM
Ptarmigan mods - 1995 FZJ80 - Rising Sun Member Forums This thread Refback 07-08-08 06:33 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 04-26-08 10:33 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 03-24-08 11:19 PM
keeping up with the Mall Cruiser's - Rising Sun Member Forums This thread Refback 03-21-08 10:10 PM
Lexus Owners Club (USA & Canada) > Starting To Worry About My Lx450 This thread Refback 03-16-08 12:40 PM
Starting To Worry About My Lx450 - Lexus Owners Club (USA & Canada) This thread Refback 03-08-08 12:57 PM
Offroad 80's :: View topic - Are people here in OZ blowing Head Gaskets on 1FZE Engines? This thread Refback 03-08-08 06:33 AM
Modified temperature gauge - Hilux Surf Forum This thread Refback 03-06-08 02:24 PM
Overlander 4WD :: View topic - Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT This thread Refback 03-02-08 09:51 PM
Overlander 4WD :: View topic - Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT This thread Refback 02-29-08 08:30 PM
Overlander 4WD :: View topic - Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT This thread Refback 02-29-08 08:12 PM
Overlander 4WD :: View topic - Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT This thread Refback 02-29-08 08:07 PM
Starting To Worry About My Lx450 - Lexus Owners Club (USA & Canada) This thread Refback 02-26-08 12:14 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 01-24-08 04:17 AM
Offroad-Express • View topic - turbos on hilux surf This thread Refback 01-16-08 08:01 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 01-01-08 03:00 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-31-07 11:53 PM
OEM Temperature Gauge - Flat Spot - YotaTech Forums This thread Refback 12-30-07 07:31 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-30-07 05:45 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-29-07 09:28 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-29-07 09:17 PM
TLCC-H Forums -> 80 Series Temp Gauge Mod This thread Refback 12-24-07 10:10 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-18-07 03:58 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-18-07 11:32 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-17-07 05:39 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-16-07 08:58 PM
vBulletin® ©2000 - 2012, Jelsoft Enterprises Ltd.
©2000-2012 by IH8MUD.com - ALL RIGHTS RESERVED
