LinkBack (44) Thread Tools Display Modes
Old 05-09-09, 07:26 PM   #331 (permalink)
citadel's Avatar
add me to the list.. completed the mod today.. the gauge rises a lot slower after cold start up and has been settling in at the half way point... it is well over 90 here in Texas so I will take the mid point position of the gauge as a good sign....
97 40th Cruiser
Front ARB,LED Lights, real HID Retrofit,Mobil 1 only,new 40th Leather,Gentex Rear View Mirror, Pioneer Avic,Bilsteins,2.5" OME Med, 285/75/16 Geolanders,grab bar, python alarm,3" MAF drop brackets,z-34 vent,CDL,4X4 Labs rear bumper,custom roof rack
citadel is offline   Reply With Quote
Old 05-09-09, 07:28 PM   #332 (permalink)
ThinkTank Waterboy
landtank's Avatar
Originally Posted by BenMara View Post
ok did the resistor mod. at idle and around town its about half way, a lil below or above. now when i get goin on the highway about 60-75 it creeps up about 1-2 widths before red.
Should i be worried?
Yes you should. I'd look into your fan clutch.
Rick Bigelow
'96 215k
Groveland MA 01834
Old 05-22-09, 11:17 AM   #333 (permalink)
Hill & Gully Rider
80t0ylc's Avatar
Thanks RT, for this very helpful thread and all the research and effort by you and all who contributed. Cost was minimal (little over $3) thanks to Davework who organized a buy and delivery. I'm now very familiar with the "black hole" behind the steering wheel. Being as mine is a '94, I combined your dash dis assembly with my FSM and it worked out ok. FSM called out to remove heater duct #2, combination switch & turn signal bracket. None of which was necessary to remove. My steering column cover is in such poor shape, it was the biggest challenge & source of much frustration.
I'd suggest using a pair of hemostats (they're like a locking pair of needle nose pliers) for bending the resistor leads and as a heat sinc while soldering. They'll help you be able to custom bend the resistor leads exactly as you want. Also, the use of resin core solder will clean the joints as you solder for better results. Do not use acid core - that's for making plumbing joints.
I couldn't find the "extra credit" characters on my gauge plus I couldn't read the one I was supposed to add, so that was a wash. I wished I'd had more artist skills so I could put the new temps at the right spots on the face of the gauge. Maybe a decal could be fabbed by someone with the right connections, for future newbies digging in to it.
Thanks again to all who helped!!!
'94 FZJ80 w/220K+miles; FF & Disc Brake Rear Axle, ARB w/Ramsey8K, Kaymar w/spare pivot, "Redneck Enginuitive Bellypan" skid plate, 2 batts. & isolator, OME 850/863 Springs w/OME N73/N74 Nitro Shocks, SS Brakelines, OME caster kit & steering damper, CDL W/Pin 7 mod., Temp.gauge mod, Amsoil converted, F.O.R. sliders soon. Green Diamond Tires: Icelander M/T LT265/75R16-E - Tom - The battle to defeat neglect is won or lost here and now.
80t0ylc is offline   Reply With Quote
Old 05-22-09, 08:37 PM   #334 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
nice work guys,
there was some talk about a decal for a while, the repeatability of the mod is decent but not perfect bringing the precision of any markings into question
1988 FJ62 on 33s
1996 LX450 on 33s
RavenTai is online now   Reply With Quote
Old 05-22-09, 08:45 PM   #335 (permalink)
Cruiserdrew's Avatar
TLCA# 11734
Yeah, but Raven you deserve MAJOR props for this. I love being able to know at a glance what's going on. Once done, it totally changes the way you look at your temp gauge. It is helpful to calibrate with a scan gauge, but once done it's amazingly repeatable.
Andrew
Cruiserdrew is online now   Reply With Quote
Old 05-28-09, 08:19 PM   #336 (permalink)
IH8MUD Junkie
JerseyCruiser's Avatar
TLCA# 17061
I have a 93 with the 100/150 resistor combo and I need to know what temperature I'm at with reference to the needle position. The only temperature chart I see is for the 50/110 on a 95-97 and being that that a 93 gauge will read slightly higher than a 95-97 I need someone with a 93-94 to chime in. One last thing at what temperature would one stop and turn off the vehicle to prevent any damage I would take a guess at 220?
George
1993 FZJ80 127,000 OEM rear locker, rear Slee bumper, Hanna Sliders, front ARB, Warn M12K, Lightforce 240's, Snorkel, OME 850/863, BFG AT KO 285’s, CDL with Pin 7 Mod, George's LEDs and more to come!
Gotham City Land Cruisers
JerseyCruiser is offline   Reply With Quote
Old 05-28-09, 09:49 PM   #337 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
I could be wrong but as far as i know only the standard mod (110/50) has had any thorough testing for temperature.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 05-28-09, 09:57 PM   #338 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
you are right and I should clarify, I have never seen a particular gauge not show repeatability compared to itself, but of the three I have put through testing (one 96. one 97 one a 93) there was a difference of a few degrees,
Weather there is a difference between years or is there just a variation from gauge to gauge is unknown.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 05-28-09, 11:03 PM   #339 (permalink)
IH8MUD Junkie
TLCA# 17061
You are correct. Did you ever find out what the difference is between the 93-94/ 95-97 gauges? Some in this thread said the 93-94 runs a bit hotter just wondering if its just the engine setup or is the gauge slightly different in its readings.
George
Old 05-29-09, 05:28 PM   #340 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
I found a difference between one particular 93 vs a 96 and a 97, this was the gauge isolated by itself in the test bed not attached to a vehicle, it is worth noting this particular 93 gauge did make a trip from BC Canada to Georgia back to BC and back to GA again before testing.
I cannot say weather this few degree difference was just that particular gauge or was it a trend that would apply to all 93/94 gauges. was it my error is setting up the test bed? with a sampling of just one none of this can be answered. it is just a few degree's for the most part not a problem.
1988 FJ62 on 33s
1996 LX450 on 33s
Old 06-11-09, 10:19 AM   #341 (permalink)
Hill & Gully Rider
80t0ylc's Avatar
Keeping track
After putting some miles on my rig with this mod it becomes very apparent how effective the temp gauge is now in monitoring how hard engine is working & cooling system health. With original gauge design, I was blissfully naive about how stable my engine temps were. I highly recommend this mod to all 80 owners with the 1FZ-FE engine. I can imagine how valuable it is for this engine with a SC setup. With the aluminum head on the cast iron block, I consider it indispensable for getting as much mileage as possible out of your HG, original or not. Just my .02 - YMMV
Last edited by 80t0ylc; 06-11-09 at 10:32 AM. Reason: cooling system effectiveness
Old 06-11-09, 10:25 AM   #342 (permalink)
TLCA# 11734
Give away
I have, I think 4 extra sets of these resistors from Moser. These are the high quality ones recommended for this mod. If you would like a set to do yours (not because you're a hoarder) send me your address and I'll send you a set, at least until they are gone.
This is a great mod and the 80 should have come like this from the factory, though I understand why it didn't!
Edit:
6/28/2009 My supply is now all gone. I hope the recipeints enjoy this great mod as much as I have.
Andrew
Old 06-11-09, 11:13 AM   #343 (permalink)
maniacv's Avatar
TLCA# 19340
I have one extra set if anyone needs them.
Paul
1997 White FZJ80
Locked | Supercharged! | 4x4 Labs Bumper | Slee Step Sliders | Slee T-case skid | CDL/pin 7 | Landtank seat mod |
George's LEDs | Stebel Compact Truck Horn | 10k cst Blue Fan Clutch | Temp Gauge Mod
maniacv is online now   Reply With Quote
Old 06-11-09, 01:23 PM   #344 (permalink)
malottki's Avatar
I would love a set of the resistors. Just did some hauling from tennessee and I would stare at my temp gauge hopping it wasn't getting to hot. Email me at malott_ki@hotmail.com.
Thanks.
93 fzj80 Emerald green, 180K miles, 2.5 lift
malottki is offline   Reply With Quote
Old 07-17-09, 03:47 PM   #345 (permalink)
Rookie
94 80 temp gauge
I was cruising down the CA-91 from Riverside to Orange in my 94 80 when the temp gauge needle went past the red zone, and remained pegged above the red zone. I exited the CA-91 as soon as possible and pulled over to safe spot and inspected. Everything seems to be intact, with no signs of leakage or smoke. The expansion tank was empty (as I filled it up 2600 miles ago from IL-CA XC trip), but the radiator was full. I was able to get home, refilled the expansion tank , and waited until the following morning to test run the engine from dead cold. The temp gauge needle is still pegged above the red zone, and when the ignition is off the needle points all the way down still.
Will this temp gauge mod fix the problem or do I need to get a new gauge assembly all together? Any other advice would be appreciated. Thanks...
CanyonRig is offline   Reply With Quote
Old 07-26-09, 11:52 PM   #346 (permalink)
vkfzj80's Avatar
TLCA# 17207
did the temp gauge mod today, went for a quick drive 10-15 min and the needle was about centered, we'll see how things look on the longer drives,
thanks to those that have put this mod together and created very easy to follow docs.
95 TLC, factory locked, CDL switch
F.O.R. lift kit, 4.88 gears, 315 Dick Cepek FCII
vkfzj80 is offline   Reply With Quote
Old 07-31-09, 11:11 AM   #347 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
RavenTai's Avatar
sorry for the delay, I have been out of town
It is possible that the mod could fix your gauge if for instance if one of the two components we replace with the mod has a broken lead, but it is more likely that you have a short to ground in the wire leading from the sensor to the gauge or a short in the sensor itself, I believe that wire is in the bundle that runs near the EGR pipe, that bundle often has issues due to excessive heat,
I would pull the cluster and check the resistance of the circuit to ground at the cluster plug, see the development thread (link in first post of this thread) for charts showing expected resistance vs temperature. you could also do the mod to the gauge while it is out.
1988 FJ62 on 33s
1996 LX450 on 33s
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/64252-93-97-coolant-temperature-gauge-modification.html
Posted By For Type Date
Have we all seen this yet? - Page 3 - Hilux Surf Forum This thread Refback 10-28-09 01:48 PM
Toyota Landcruiser Owners Club (UK) :: View topic - Temperature Guage This thread Refback 10-21-09 02:58 PM
DARWIN4X4.NET - THE TOP END'S 4X4 ONLINE COMMUNITY • View topic - 80 running warm This thread Refback 09-21-09 03:25 PM
Outer Limits 4x4 Board :: View topic - 1HDT Over heat! This thread Refback 04-08-09 02:26 AM
Toyota Landcruiser 100 Series ‘98-‘04 Temp Gauge Mod | Paul's esoteric meanderings This thread Pingback 04-06-09 12:00 AM
Outer Limits 4x4 Board :: View topic - Want to make your OEM Toyota temp gauge work properly? This thread Refback 03-30-09 03:53 AM
Outer Limits 4x4 Board :: View topic - Want to make your OEM Toyota temp gauge work properly? This thread Refback 03-30-09 01:46 AM
BMWClub > Sa eliminam buffer-ul de la ceasul de temperatura. This thread Refback 03-07-09 10:12 AM
Sa eliminam buffer-ul de la ceasul de temperatura. - BMWClub This thread Refback 02-26-09 03:53 AM
whos interested if i make these? - Page 7 - Hilux Surf Forum This thread Refback 01-27-09 01:20 PM
sonde de temperature moteur - Page 9 - Forum 4x4 This thread Refback 01-14-09 12:35 PM
Offroad-Express • View topic - turbos on hilux surf This thread Refback 01-01-09 03:02 PM
Overlander 4WD :: View topic - Does your vehicle handle the heat ? This thread Refback 11-22-08 04:07 AM
Removing the buffer in the stock temp gauge - Page 2 - Bimmerforums - The Ultimate BMW Forum This thread Refback 11-04-08 01:15 PM
Temp gauge needle - TTORA Forum This thread Refback 10-05-08 07:03 PM
Possible Temperature Gauge Deadzone Solution - ToyotaDiesel.com Forums This thread Refback 07-21-08 05:44 AM
Temperature Gauge Modification. This thread Refback 07-12-08 05:54 AM
Offroad-Express • View topic - turbos on hilux surf This thread Refback 07-09-08 08:16 PM
Ptarmigan mods - 1995 FZJ80 - Rising Sun Member Forums This thread Refback 07-08-08 07:33 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 04-26-08 11:33 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 03-25-08 12:19 AM
keeping up with the Mall Cruiser's - Rising Sun Member Forums This thread Refback 03-21-08 11:10 PM
Lexus Owners Club (USA & Canada) > Starting To Worry About My Lx450 This thread Refback 03-16-08 01:40 PM
Starting To Worry About My Lx450 - Lexus Owners Club (USA & Canada) This thread Refback 03-08-08 01:57 PM
Offroad 80's :: View topic - Are people here in OZ blowing Head Gaskets on 1FZE Engines? This thread Refback 03-08-08 07:33 AM
Modified temperature gauge - Hilux Surf Forum This thread Refback 03-06-08 03:24 PM
Overlander 4WD :: View topic - Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT This thread Refback 03-02-08 10:51 PM
Overlander 4WD :: View topic - Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT This thread Refback 02-29-08 09:30 PM
Overlander 4WD :: View topic - Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT This thread Refback 02-29-08 09:12 PM
Overlander 4WD :: View topic - Digital Engine Temp Gauge w/Alarm to overcome OEM DEAD SPOT This thread Refback 02-29-08 09:07 PM
Starting To Worry About My Lx450 - Lexus Owners Club (USA & Canada) This thread Refback 02-26-08 01:14 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 01-24-08 05:17 AM
Offroad-Express • View topic - turbos on hilux surf This thread Refback 01-16-08 09:01 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 01-01-08 04:00 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 01-01-08 12:53 AM
OEM Temperature Gauge - Flat Spot - YotaTech Forums This thread Refback 12-30-07 08:31 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-30-07 06:45 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-29-07 10:28 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-29-07 10:17 PM
TLCC-H Forums -> 80 Series Temp Gauge Mod This thread Refback 12-24-07 11:10 AM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-18-07 04:58 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-18-07 12:32 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-17-07 06:39 PM
Toyota 4WD Surf Owners :: View topic - Factory Temp Guage can be fixed for sixty cents This thread Refback 12-16-07 09:58 PM
