80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Old 10-18-03, 06:57 PM   #1 (permalink)
80and100cruisers's Avatar
Ground Clearance
As I was looking under my 100 earlier today I remembered that ground clearance is supposed to be around 9 inches. I pulled out a ruler and the lowest point on the front is 6 inches. It is the lower part of the independent suspension. Do they measure from the center when they get the factory numbers? The center was about correct with the factory specs. I would assume the part I measured would clear most things because it is so close to the wheel. Makes me wonder about all factory clearance numbers ??? For the 80s and earlier would they measure from the bottom of the diff in the axels?
-Matt
80and100cruisers is offline   Reply With Quote
Old 10-18-03, 09:18 PM   #2 (permalink)
Ground Clearance
Typically it's measured under the diff.
cruiserman is offline   Reply With Quote
Old 10-19-03, 03:33 AM   #3 (permalink)
Ground Clearance
Even on an IFS?
-Matt
Old 10-19-03, 03:56 AM   #4 (permalink)
Jonathan_Ferguson's Avatar
Ground Clearance
Yes and that is why Fake 4WD's appear good on Paper, But when the Springs compress out Bush. :-*
Jonathan_Ferguson is offline   Reply With Quote
Old 10-19-03, 01:49 PM   #5 (permalink)
Ground Clearance
[quote author=80and100cruisers link=board=2;threadid=6473;start=msg52490#msg52490 date=1066556003]
Even on an IFS?
[/quote]
Matt:
I'd have to go and look at an IFS setup, but is the lowest part right at the wheel? If so, the concept is that, while this may be the lowest point, you would actually be placing the tire on top of the obstacle (eg rock) and the wheel would travel over it. The Diff is low point and it doesn't move.
Cheers, Hugh
CDN_Cruiser is offline   Reply With Quote
