Old 10-07-05, 03:53 PM   #1
Shipwreck's Avatar
TLCA# #4695
2nd Start button and Power button issues
Question:
Is it necessary for the indicator light on the dash to be working before the computer allows lock-up of the transmission during 2nd Start mode or Power mode?
Background:
'97 FZJ80 w/ 102k mi purchased last May. "D" Drive indicator lamp was out when I bought the truck. Shortly thereafter the lamp for "Power mode" went out. I never really tested to see if the "Power mode" still worked properly after the indicator lamp went out. Recently (like an idiot) I tried as suggested here to give a whack to the dash to see if I could get the indicator lamps to come back.
Well instead of coming on, the "2nd start" indicator lamp went out.
So now the "D" light is out, the "Power" light is out and the "2nd Start" light is out. It also appears that the power mode and 2nd start mode are not functioning. Ive pulled the switch and tested it according to the FSM and it checks out OK. I pulled the dash out and checked connections at the combination meter, but I'm waiting for the lamps to come in before testing for burnt bulbs. I've ordered new bulbs for the dash and am hoping that by completing the circuit the computer will get the proper signal and actuate the tranny as it should. Or should I start thinking about a problem at the computor and tranny connections.
'75 FJ40 at work
'97 FZJ80 on the sand
Craig Park
PMC
TLCA #4695
Shipwreck is offline   Reply With Quote
Old 10-07-05, 04:08 PM   #2
Hi ive got exactly the same problem my drive light power and 2nd start dont light up and i dont think there working ???
steve uk is offline   Reply With Quote
Old 10-07-05, 05:56 PM   #3
firetruck41's Avatar
TLCA# 14300
My "PWR" dash light does not work but "PWR" mode works fine. Not sure about the "2nd" button as the dash light works, but I have never actually tried using it yet.
Ben Silva
IH8MUD Site Supporter since July 2004
1996 Lexus LX 450, 130k, locked, Cooper STT 285s, OME 850/863, CDL/Pin 7, 30qt freezer, 2@aux fuse blocks, aux powerpoint, 850w inverter
1998 Lexus LX 470, 139k Sold
1993 FZJ80 198k miles Sold
firetruck41 is offline   Reply With Quote
Old 10-08-05, 12:03 AM   #4
My '97 D and PWR lights do not work. However, PWR works. For that matter, so does D. Heh.
Check again if your 2nd gear start is working - I suspect it is. If so, likely so is the PWR feature. Do you know how the 2nd feature works?
DougM
'93 FZJ since new, 2.2kw starter, Revo 275s, locked, big Hellas, rr fog, rr flood, rr Airlift, synthetics, ARB bullbar. 97 FZJ - exact same stuff but Michelin Alpins in winter "Slicker than owl shit on a wet log." - Carter
IdahoDoug is offline   Reply With Quote
Old 10-08-05, 12:24 AM   #5
OZCAL's Avatar
One way to know for sure that your 2nd start is working is when you depress it accidentally prior to starting up a steep driveway out of your subterranean parking garage and the engine revs but doesn't generate enough torque to get up the hill. Ask me how I know
David
OZ - '97 80, 269,000 k's (Australian GXL) RHD, subtank, CDL, hand throttle, steel wheels w/Dueler 285/75/16s, cloth seats; dual batts, George's LEDs, Yakima rack
CAL - '97 LX 450, 136,000 miles (US spec) stock + CDL, George's LEDs.
OZCAL is online now   Reply With Quote
Old 10-08-05, 12:29 AM   #6
Another excellent test is to accidentally bump it somewhere in the 10 minutes before you find yourself in a hurry and pull out in front of a truck. You'll leave a dent in the floor mat and won't need any coffee the rest of the day.
DougM
Old 02-28-07, 11:02 PM   #7
Originally Posted by Shipwreck View Post
Question:
Background:
Has the problem been identified? I also experience the same on a 99 cruiser (No 'D", "PWR", or "2nd Start" symbols). I also wondered if it is tranny problem.
tk45s is offline   Reply With Quote
Old 03-01-07, 06:35 AM   #8
TX_TLC's Avatar
TLCA# 14457
It is ok to start a new thread when you resurrect two and no one replies. 99 times out of a 100 your "problems" are most likely burnt out bulbs.
Have you tried the tests given in both threads??? Results???
1994 FZJ80, stock, emerald green, 148k
TLCA #14457
LSLC Member
TX_TLC ROTW
"We will know how long they last when the first one wears out."
TX_TLC is offline   Reply With Quote
Old 03-01-07, 07:46 AM   #9
TLCA# 17929
You might try popping off the button itself in the center console and just cleaning out the dirt etc. My indicator light for the 2nd start went out even though it was still actually starting in 2nd. Cleaned out the button and the indicator light worked again. May just not be making good enough contact.
Josh
KCCruiser is offline   Reply With Quote
Old 03-01-07, 08:07 AM   #10
98 SNAKE EATER's Avatar
DougM
LOL
Reminds me of the Skip Shift system (CAGS) in my T/A
Damn thing would force me to shift from 1st to 4th while driving under light throttle to save on fuel
A scary thing when trying to accelerate through a busy instersection in 4th
After a week, I bypassed the system completely cause it was more of a hazard than anything else....
98 SNAKE EATER is offline   Reply With Quote
Old 03-01-07, 09:04 AM   #11
TLCA# 14300
Your bulbs are burnt out, very common.
Ben Silva
Old 03-01-07, 12:55 PM   #12
Thanks for all the suggestions! I tried this:
1. pusing down the power button. it stayed there, but no indicator light was on. ------ At driving side, there was no expected effort on high rev up shifting.
2. pushing down the 2nd start button. It popped up the power button, but it did not stay there, and no indicator light was on. ----- At driving side, it showed no effect.
BTW, I found the indicator lights -- there are 3 square ones under "L". The left one is 2nd start and right one ECT PWR.
I ordered a repair manual last night. Probably next weekend I will have some home project to do.
Old 03-01-07, 01:15 PM   #13
Unleash the Beast
LX_TREME's Avatar
TLCA# 4500
<--never leave it on, don't need to -too quick and too much power both PWR and 2nd start button lights work nicely
LX_TREME is offline   Reply With Quote
Old 03-01-07, 01:31 PM   #14
I have the same problem with mine "D", 2nd & PWR light in the dash were out when I bought the truck. I replaced the bulbs but 2nd & PWR light does not come on when activated even after changing the bulbs. I haven't tried cleaning the switch may be that will do the trick otherwise I'll leave it like that for now , truck runs okey so far.
cayeb is offline   Reply With Quote
Old 03-05-08, 07:26 PM   #15
Halodude's Avatar
same thing
Let me know what you guys come up with...I have the same issue. No D, 2nd, pwr light on the dash or at the buttons. What gives????
[b]97' LX 450
"In difficult times, the boldest plans are best'
Halodude is offline   Reply With Quote
Old 03-28-08, 09:54 AM   #16
Atoyot1031's Avatar
TLCA# 18402
I have my D, but no PWR light or 2nd (just went out last week). Guess I'll be tearing apart the dash to change some bulbs. I'll make sure to test the others to see if I have anything else out before I go through the trouble.
Atoyot1031 is offline   Reply With Quote
Old 03-28-08, 12:13 PM   #17
Shipwreck's Avatar
TLCA# #4695
Wow. Old thread that I had forgotten about. Since I was the original poster I guess it's time to report back as to how I fixed my issue.
I had two problems: The dash light bulbs burned out. And also, the switch for the "power and "2nd start" was gummed up with old spilled coffee so that it worked only intermittently. After I took apart and cleaned the switch and then replaced the bulbs, everything works as it should.
What I found out is that (as several people posted here) there is no direct relation to the function of the "2nd start" or "power" functions and continuity of the indicator bulbs. The bulbs can burn out and the functions still operate.
Because the "power" and "2nd start" are rarely used for most of us I think we just don't notice a problem until one of our dash bulbs burns out and then we check all the switch functions.
'75 FJ40 at work
Craig Park
PMC
TLCA #4695
Electricity | Loans | Deals On Products | Debt | Mortgage Calculator
