Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Thread Tools Display Modes
Old 06-09-12, 07:04 AM   #1
Arsenal1
Arsenal1's Avatar
Garage
No spark, no fuel, Yes Crank
hey guys, my cruiser died two nights ago while idling for approx 10mins... I fired it back up and died immediately... I have all lights, CEL, replaced COR, tested EFI relay, checked all fuses, checked continuity on fusible links... fuel pump and related is good as I hard wired for a split second before I replaced the COR, touched the wires together and fuel shot out of return line at regulator.... Basically i've completed all requirements and checks listed in the FAQ...
Both symptoms of no fuel or spark happened simultaneously. As I'm getting power to the ECU its obviously something that controls both spark and fuel. How about the CPS??
aut viam inveniam aut faciam
1996 Land Cruiser , OME 3.5'' heavy, 35'' BFG mud track, LOCKED, Aussie auto rear locker.....65% complete front bumper fab, Warn 8274... Currently adding 30mm spacers to front and correcting caster..
Arsenal1 is offline   Reply With Quote
Old 06-09-12, 04:30 PM   #2
bsmart82
Crank sensor signal will cause it to loose both fuel and spark. Did you check for codes?
'93 FZJ80
'92 TSi auto
Toyota MDT
bsmart82 is offline   Reply With Quote
Sponsor 06-09-12, 05:00 PM
Sponsored Link
advertisement
Old 06-09-12, 05:00 PM   #3
Arsenal1
Arsenal1's Avatar
Garage
I attempted to check codes per several threads explaining the paperclip method but my CEL didn't flash. Although my CEL is on and illuminated.... This is probably due to my resetting the computer like an idiot prior to running across the threads for checking codes via paperclip method... I've worn my foot out kicking myself in the ***
Old 06-09-12, 05:03 PM   #4
Arsenal1
Arsenal1's Avatar
Garage
Anyone have voltage readings for CPS to test with multimeter???
Old 06-09-12, 05:03 PM   #5
george_tlc
Addict
george_tlc's Avatar
Your 96 should be obd2, you need a code reader, not a paperclip....
cheers,
george.
where ever you go, there you are....
US: '97 S/C 1FZ 80 Cruiser White CE, locked^3, sliders,arb,kaymar, m12000,dual batteries, oem subtank, LEDs, etc..... ki6ibx
OZ: '80 T/C SD33 MQ Patrol White, locked F/R, rack,sliders,arb,tyre carrier, 8274, dual batteries, LEDs, etc....
http://www.george4wd.taskled.com
george_tlc is offline   Reply With Quote
Old 06-09-12, 05:10 PM   #6
Arsenal1
Arsenal1's Avatar
Garage
thats what i'm screamin.... tried that route and discovered it has the obd1 diagnostics despite being classified as a 1996 via VIN lookup thru toyota dealership. Inside the door it states it was manufactured 8/1995.... who knows... There seems to be 2 connection ports, one under hood passenger side sitting on firewall that says Diagnostics and another inside fuse panel on drivers side....
Old 06-09-12, 05:11 PM   #7
Arsenal1
Arsenal1's Avatar
Garage
If I got fed some misinformation please send me in the correct direction.... You guys are the "Yodas" not I... Thanks again for the help I sure do appreciate it.
Old 06-09-12, 05:17 PM   #8
Koffer
Addict
Koffer's Avatar
the one you need to use is the one under the fuses in the dash . the other one under the hood is for ABS/trans etc .
Todd
64' FJ40, 86' BJ70, 96' FZJ80 , 66'M416 and a 92' M101CND
Koffer is offline   Reply With Quote
Old 06-09-12, 05:56 PM   #9
jonheld
Lifer
jonheld's Avatar
Garage
If there's a connector on the top of the fuse panel by the driver's left knee then you're OBD2, as that is the OBD2 port.
Jon Held
1991 FJ80 "Lumbering White Rhino"
Buy your FJ80 FSM here: http://www.sdsysdesign.com/tlc/fsm.html
"I do wish we could chat longer, but I'm having an old friend for dinner."
jonheld is offline   Reply With Quote
Old 06-09-12, 11:28 PM   #10
jbma327
I'm new here, but I do work on all kind of imports. It seems like you could be having issue with your ecu. First thing I would do is check all your fuses. Then go from there. Did do any wiring or work on your car prior to this situation?
jbma327 is offline   Reply With Quote
Old 06-10-12, 05:42 AM   #11
landtank
10k Club
landtank's Avatar
if it cranks over and does not fire I would look at the alternator. If it cranks over fires up and dies then I'd look at the MAF sensor.
Rick Bigelow
Groveland MA 01834
Find your LANDTANK items at AJIK Overland Exchange
Old 06-10-12, 08:56 PM   #12
mjl132
mjl132's Avatar
Garage
It will tell you under the hood on the drivers side if it's OBD II compliant.
1996 Toyota LC- Stock with 285/75/16 Terra Grappler's (sold)
1996 Lexus LX 450 (sold)
1995 LC FR/RR, CDL, 7 pin, 285s, ARB'd, 3rd world country pimp mobile
1978 Chevrolet Camaro
mjl132 is offline   Reply With Quote
Old 06-10-12, 09:29 PM   #13
Pin_Head
10k Club
Pin_Head's Avatar
And the muffler bearings!
Pin_Head is offline   Reply With Quote
Old 06-10-12, 09:36 PM   #14
Arsenal1
Arsenal1's Avatar
Garage
No wiring performed at all.... I've ruled out the alternator as the lack of spark and fuel came simultaneously... I haven't read anywhere that a faulty MAF would completely cut off spark and fuel at the same time.... I could be wrong but...
And yes to everyone that corrected me on the OBD2... yall were right... I'll bum a code reader tomorrow and hook that puppy up.
Old 06-10-12, 11:35 PM   #15
jbma327
The alternator will not cause the problem. If your car can turn over with the battery then there should be more then enough juice for your injectors, fuel pump, and lignitors to create spark.
The maf will cause too much or too less fuel, but will not affect spark.
How did you come to the conclusion that the motor is not getting fuel? Is the fuel pump turning on?
Old 06-11-12, 02:12 AM   #16
BlackLS1
BlackLS1's Avatar
there is that big wire harness next to the egr that sometimes gets melted due to the heat. you should check that. if you think its your MAF, try unplugging it and start it, Crankshaft position sensor is another thing to replace.
1994 FZJ80 Locked! 138,000 miles
BlackLS1 is offline   Reply With Quote
Old 06-11-12, 04:35 AM   #17
landtank
10k Club
landtank's Avatar
really
Rick Bigelow
Groveland MA 01834
Old 06-11-12, 07:39 AM   #18
Arsenal1
Arsenal1's Avatar
Garage
I don't want to double post but here's the scenario listed in my first post "I have all lights, CEL, replaced COR, tested EFI relay, checked all fuses, checked continuity on fusible links... fuel pump and related is good as I hard wired for a split second before I replaced the COR, touched the wires together and fuel shot out of return line at regulator.... Basically i've completed all requirements and checks listed in the FAQ...
Both symptoms of no fuel or spark happened simultaneously. As I'm getting power to the ECU its obviously something that controls both spark and fuel. How about the CPS??"""""
Old 06-11-12, 08:44 AM   #19
Tools R Us
10k Club
Tools R Us's Avatar
... checked continuity on fusible links...
The wire in the fusible links is somewhat brittle, can crack/break where it will pass the continuity test, but not carry enough currant to run the stuff. My favorite test is to simply pull on them, you should not be able to pull them apart. If one separates, it was bad/failed. The "correct test"; connect a meter to the link connection, should read battery voltage. Crank the motor, should still read battery crank voltage, if way low, it's bad.
Copper State Cruisers #007
Old 06-12-12, 01:08 AM
Sponsored Link
advertisement
Old 06-12-12, 01:08 AM   #20
jbma327
Hot wiring your fuel pump will not determine if you really getting fuel to your engine or not. The check if your ecu is sending signal to kick on your fuel pump, you can go in the engine bay and fine the rubber gas fuel line (connected to the fuel filter), squeeze it with your hand (should be soft), and at the same time have somebody turn the key to the ON position. If you feel the gas line getting hard(fuel pressure from the pump), then your ecu works on sending signals to your pump.
If you keep cranking the key, do you smell fuel? As if your engine is getting flooded with gas? If that's the case then you will know if your not getting spark.
Hope these info help
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
