LinkBack (11) Thread Tools Display Modes
Old 10-11-05, 02:51 AM   #61
TLCA# 14984
I kind of get it, so the wheels are driven by a ring instead of an axle shaft? Sorry for being such a neophyte I'm trying to learn.
Nick Martinez
TLCA # 14984
07' Tacoma PreRunner 5spd Brought home 12/29/06
05' SR5 Tacoma Brought home 4/24/06 Flipped 12/06/06
1991 FJ80 155k - Traded in 4/25/06
nyk438 is offline   Reply With Quote
Old 10-11-05, 04:50 AM   #62
That will leave a mark.
TiredIronGRB's Avatar
TLCA# 16625
TiredIronGRB is offline   Reply With Quote
Old 10-11-05, 08:05 AM   #63
shocker's Avatar
TLCA# 10895
If you look at this picture....
You can see that the front axle is about 5" above the center of the wheel.
That is because there is a "portal" hub at each end of the axle (shown in the diagram in the post above) that extends down the 5", which the wheel is then mounted to.
Other vehicles that have portals are Mercedes Unimogs. H1's use portals as well, only in a fully independent suspension design.
shocker is offline   Reply With Quote
Old 10-11-05, 08:48 AM   #64
heavy foot...broken parts
Uncle Ben's Avatar
TLCA# 3007
That is very cool! One issue I wonder about is the distance between the steering knuckle and the wheel hub flange. It would seem the tire would rquire deep wheel wells in order to make a complete swing lock to lock. Am I missing something here?
"j**ps make great...traction!"
Kevin ehrlick tlca #3Ø07
rising sUn
stay on the trail
louisville, colorado B
'64 fj-40 (wild rice), '97 fzj-80 40th aNniversary (ricecake)
ST. FUAW!
Uncle Ben is offline   Reply With Quote
Old 10-11-05, 08:52 AM   #65
TLCA# 16625
That's why the wheels are backspaced 8" (the width of the wheel) that way the pivot point is the same as a conventional axle.
Old 10-11-05, 09:38 AM   #66
Fochdog's Avatar
TLCA# 15036
What is the overall gear ratio for the axle?
Ring and Pinion Ratio * Geared Hub Ratio.
The HUMMER H1 is 4.92 ratio IIRC.
Newly relocated to Mid-coast Maine, USA
1997 FZJ80 40th Edition (w/ OEM Lockers, OME 850/860 with Bilsteins, Slee Slider-Steps, CDL w/ "Pin 7" and 33" Swamper LTBs)
Fochdog is offline   Reply With Quote
Old 10-11-05, 09:43 AM   #67
TLCA# 16625
6:1
Old 10-11-05, 09:59 AM   #68
Front Locker Opportunist
Riad's Avatar
TLCA# 15815
So, these axles are from what type/year of unimog? Is the maint. of these axles is in the same level as doing a birf job or more complicated as far as the axle seals and bearings are concerned? Great work . Did you make those drive shaft flange yourself? This is the MOST clean and quick swap I have ever seen. OUTSTANDING!!
My FZJ80
Riad is offline   Reply With Quote
Old 10-11-05, 10:01 AM   #69
Josh83's Avatar
TLCA# 11847
They aren't from a Unimog, they are Volvo.
Josh
08 FJC - my first new vehicle!
91 FJ80-coming soon
Josh83 is offline   Reply With Quote
Old 10-11-05, 10:09 AM   #70
Riad's Avatar
TLCA# 15815
OOps! That's what I meant to say, VOLVO. Thanks for the correction. BTW, have you used the stock/custom sway bars or there none? What's your take on that?
My FZJ80
Old 10-11-05, 10:14 AM   #71
Uncle Ben's Avatar
TLCA# 3007
Ahhhh....that makes sense, hard to tell from the pictures....thank you!
rising sUn
stay on the trail
ST. FUAW!
Old 10-11-05, 10:19 AM   #72
Something clever
Arya Ebrahimi's Avatar
Looks awesome!
I can't help but comment on the fact that it looks VERY narrow though. Seems you would want a little less backspacing on the wheels to widen the stance a bit. Maybe it's just an illusion, but the stance looks narrower than stock.
Ary
HOKIES UNITED
Arya Ebrahimi
'94 FZJ80 200k miles, locked, 285 Revo's, ARB Bullbar, Hella 4000's, homemade drawers
My mini-truck buildup thread...updated 9/10
Mini-truck's first trip!! With PICS! 11/10
Arya Ebrahimi is offline   Reply With Quote
Old 10-11-05, 10:47 AM   #73
TLCA# 16625
It's about the same, 72" outside of tire to outside of tire. The extra weight of the axles helps keep it firmly planted as you can see here with the Volvo 6x6 I had side angles are no problem.
Old 10-11-05, 09:23 PM   #74
TLCA# 16625
I updated the build page tonight, it shows the timeline a little better.
http://tired-iron.mounet.com/Grace4x...LC/default.htm
Old 10-12-05, 03:19 AM   #75
grown up MOD
reffug's Avatar
TLCA# 14549
Originally Posted by Arya Ebrahimi
Looks awesome!
Ary
I kinda thought that as well Ary. I really love the concept but would definately want some wider tires / larger footprint with that height rig. Course I could probably tip it over no matter what.
"If it wasn't a Landcruiser and hadn't been built the way it was you do realize you would be DEAD." VA State Police Officer
reffug is offline   Reply With Quote
Old 10-13-05, 07:45 PM   #76
TLCA# 16625
Some flex shots...
Old 10-13-05, 08:09 PM   #77
how does the flex compare to regular axles?
89 FJ62
Bryan062087 is offline   Reply With Quote
Old 10-13-05, 08:11 PM   #78
TLCA# 16625
I would thing it's about the same since the suspension was unchanged. I never got to wheel it before the swap. This truck had never been off road.
Old 10-13-05, 08:29 PM   #79
agomez's Avatar
Some of these guys are hard to please but I am very impressed with the straight foward out of the box engineering you used to make the volvo axles work, not to mention all the measuring you had to do . You are a can do kind of guy very impressive. This kind of thinking usually pushes everyone to the next level, but what do I know, the most off roading I do is turning around on a old farm road to go the other way on a two lane paved highway...
Cheers Andy
2000 uzj100
1995 Fzj80 Pearl Gray mallcruiser with damage multipliers front and back
tacos al cabron
agomez is offline   Reply With Quote
Old 10-13-05, 08:43 PM   #80
AMMO's Avatar
TLCA# 15002
HUMMMMM 8 Lug Hummmmmmm, drool drool...
-Ammo
94 FJZ80,locked,EMU'd,snorked,AMMO Sliders,plated,FAB'd, int LINEX'd,body lifted,over-head consoled,AMMO HD tie-rods,Sparco, rollin on 17's wrapped in 37's Iroc's *Now more gooder w/ 5.29's* LINK MOTORSPORTS Recovery Vehicle
http://www.linkmotorsports.com
AMMO is offline   Reply With Quote
Old 10-13-05, 09:19 PM   #81
shocker's Avatar
TLCA# 10895
Looks freaking awesome!
Do the lugnuts actually protrude out further than the rim? Anything you can do to keep them from getting mangled?
Old 10-13-05, 09:57 PM   #82
spressomon's Avatar
WOW! Have been a fan of portals/MOGS for along time...and more recently LC. All I gotta say is...I want one. Make mine a TD too
Congrats...that is alot of work, mods, measurin, knuckle bust'n, cuss'n, patience...but you perservered!
Modded '99 for overlanding/exploring: 35's, 4.88's, AO drawers, Slee rr, TJM fr, ARB fr locker, ear candy, Waeco CF-50, PowerGate with 2nd battery, home brew sliders & t-case skid plate, 9.5XP/X-line, LF 170's, OEM 864's, Foxes x 4, 12mm BL, Carl's UCAs, ... KE7NCM
Old 10-13-05, 10:02 PM   #83
...should be studying
Cruiserhead05's Avatar
Tired iron,
I emailed the previous owner, Todd. Sent him a link to this thread. He's love what you've done with the truck and he should be very proud. Just thought id pass that on.
-Brandon-
FZJ80
'89 Cressida - 1JZ Sleeper
Cruiserhead05 is online now   Reply With Quote
Old 10-14-05, 05:47 AM   #84
TLCA# 16625
Yes, they do a little but they are massive and with the Volvo 6X6 I had it never was an issue and I wheeled the crap out of it.
Old 10-14-05, 06:43 AM   #85
fj803fe's Avatar
TLCA# 11255
TiredIron-lookin at your web-site photos and just a quick glance. VERY COOL BTW. I would say you will GREATLY increase areticulation with the right shock set up. Because it looks to me your shock mounts (on the rear axle installed picture) near the stock location in relation to the portal drop and the axle housing is sitting at stock height, it appears that your shocks are severely limited from the get go. You could probably go with 14" shocks w/o new springs and see a much larger droop. Otherwise, check out ActionJackson's web site and see his double shock set up-he created a new stud on the control arm w/ OME shocks and went near to the stock upper mount-I would guess this way stock shocks would be about sized correctly.
I may be missing something from the photos though. VERY NICE... In Vegas they may call that "money baby, money!"
84 BJ60, 92 '80, 00 '100-All with toys here and there-more toys and trucks laying in wait :-D
"I think of all the challenges that people with disabilities face and if they can get up each day with a smile, and then conquer that day, than so can I."
fj803fe is offline   Reply With Quote
Old 10-14-05, 06:57 AM   #86
TLCA# 16625
I think I will order a set of 2" heavy springs and shocks today, I think the 3" would be too much lift. I kinda hate to go with larger springs I like being able to say "Sure, you can run 38s on stock springs"
Old 10-14-05, 08:27 AM   #87
shocker's Avatar
TLCA# 10895
It's been discussed before I think, but the difference between the OME medium (851/860) springs and heavy (850/863) springs is about an inch in height, as the spring rates are the same.
http://forum.ih8mud.com/showthread.p...&highlight=863
If you just want 2" of lift, you might want to go with just the "medium" springs. Talk with whoever you order
