Home Forum Gallery CruiserFAQ Tech Links Merchandise
IH8MUD Forum
Go Back   IH8MUD Forum > Toyota Tech Forums > 80-Series Tech
Join IH8MUD on Google+   Follow IH8MUD on Twitter   Visit IH8MUD on Facebook
80-Series Tech Tech regarding the 80/81-series Land Cruiser, including the Lexus LX-450 -- FZJ80.com
Thread Tools Display Modes
Old 07-26-11, 08:42 AM   #1
excessive
excessive's Avatar
Garage
How bad is it to rotate the engine backwards
97 LX 450
I did a search, but did not come up with any answers.... so anyway, while doing the replacement of the oil pump seal I accidentally rotated my engine in the wrong direction (counter-clockwise) when trying to loosen the crank pulley bolt. How bad is this? Anything I should check for damage? I have done some goggling and it seems that it could damage the timing chain / tensioner
This little project just may cause me my sanity
excessive is offline   Reply With Quote
Old 07-26-11, 09:09 AM   #2
Kernal
Lifer
There's been a few threads about it and someone did it in the past without any issues. Wait for someone who's actually pulled an engine apart to chime in with a better answer.
Kernal is offline   Reply With Quote
Sponsor 07-26-11, 09:18 AM
Sponsored Link
advertisement
Old 07-26-11, 09:18 AM   #3
kidglove13
Lifer
kidglove13's Avatar
I did it with out issue, I did not rotate it alot but I did rotate it backwards FWIIW
Roger
94 80 Series Land Cruiser
Ole Bessy
kidglove13 is offline   Reply With Quote
Old 07-26-11, 09:26 AM   #4
Tools R Us
10k Club
Tools R Us's Avatar
Not going to damage anything.
Copper State Cruisers #007
Old 07-26-11, 09:50 AM   #5
excessive
excessive's Avatar
Garage
thanks for the info guys.
I was trying very carefully not to rotate backwards, but my 14mm socket slipped off the flywheel and the engine rotated about 1/4 a revolution in the wrong direction.
Old 07-26-11, 10:20 AM   #6
robertaleon
robertaleon's Avatar
Garage
Same job - wife helping while I was underneath watching the 14mm, she rotated about 1/6 of a turn on the 30mm counter-clockwise ("Ooops - I'm a girl"). No harm done.
Did you find the socket?
1995 Red Mica FZJ80, deleted running boards, unlocked, BFG TA KO 285/75/16, front flaps, Garmin 60 CSx GPS, LR cup holder, PHH metal pipe bypass and FHH, Koyo rad, main wiring harness rewrap, Medium OME 2.5", OEM belts+oil pump+crankshaft seal completed replaced, HG job DONE!!
robertaleon is offline   Reply With Quote
Old 07-26-11, 10:53 AM   #7
excessive
excessive's Avatar
Garage
not yet, i bought this today, when i get home from work i will check out the inside the bellhousing.
Old 07-26-11, 11:00 AM   #8
js93cruiser
Addict
js93cruiser's Avatar
Garage
i know on the 22re engine it will loosen the tensioner and skip teeth on the timing chain....might be the same for the 1fz
96 lx,3-link,14" fox coilovers,37" TA KM 2"s,tg sliders,5.29's,no slip rear,Aussie front, nitro chromo shafts and birfs,pp rear shafts,cv d-shafts,custom bumpers front and rear,marks pt kit,Aisn hubs,PSC hydro assist,chromo hub gears, arp'd,Toyota 1 ton front axle, custom rock rings
js93cruiser is offline   Reply With Quote
Old 07-26-11, 11:06 AM   #9
alia176
Lifer
alia176's Avatar
you're fine. I've rotated engines backwards more times than I can count.
~Ali~
'96 his
'97 hers
Tighten your nuts and lube your shafts.
alia176 is online now   Reply With Quote
Old 07-26-11, 11:37 AM   #10
Tools R Us
10k Club
Tools R Us's Avatar
Maybe, if the chain is big time stretched, parts are very worn, but I have never seen it happen. Have done or seen to done tons of times. Attempt a big obstacle, fail, slide backwards, the tire force kills the engine, turns it backwards, collect your thoughts, start the engine, make the obstacle, no harm, no foul.
Old 07-26-11, 01:52 PM   #11
excessive
excessive's Avatar
Garage
I think the chain tensioner in our motor works by simply pressing on the timing chain, so hopefully that would not cause timing to be messed up. I know in the shop manual it says do not turn the motor in the wrong direction.
Hopefully it will be ok - I guess I'll find out if/when i get everything back together.
Old 07-26-11, 03:09 PM   #12
Pin_Head
10k Club
Pin_Head's Avatar
My buddy's son parked his Toyota pickup with 22re on a hill and left it in 4th gear without the parking brake on. Overnight, it slowly rolled down the hill with the engine turning backwards about 200 yards to the bottom of the ravine. After winching it out, it started right up. No damage!
YMMV
Pin_Head is offline   Reply With Quote
Old 07-26-11, 03:19 PM   #13
CJF
Lifer
Too funny.
My own bone-head maneuver was to try to push start my 82 Toyota Longbed (22R) by letting it roll backwards and then popping the clutch. Guess what gear I *wasn't* in.
That was back in 1995. Still driving it today with no issues.
CJF is online now   Reply With Quote
Old 07-26-11, 06:08 PM   #14
Tools R Us
10k Club
Tools R Us's Avatar
Originally Posted by excessive View Post
... I know in the shop manual it says do not turn the motor in the wrong direction. ...
Most shop manuals say that. Likely not because of causing damage but, it is bad technique. When a motor is turned backwards, the timing relationship between the crank (timing mark) and the cam (distributor, etc) changes, so parts can be installed out of time, etc. You can turn it backwards, then just need to turn it back forwards enough to remove the slack, restore the timing relationship.
Old 07-26-11, 07:25 PM   #15
TX Cruiser
You mainly worry about that on interference motors. One of mine requires that you rotate the engine 10 degrees CC to properly tension the timing belt. Once the timing is verified, I always have to rotate it backwards to get the balance shafts to sync. Belt stretch.
It's going to be a damn good "pop" if harm was done. Matters not what you have, belt or chain. As reiterated above, no harm.
2- 91 FJ80's, one smashed
In the family
74 FJ40 w/PTO winch, tow bar
83 FJ60
84 FJ60
90 FJ62 w/damage inducer
94 FZJ80 w/damage multiplier
95 FZJ80 " "
03 UZJ100
TX Cruiser is offline   Reply With Quote
Old 07-26-11, 07:34 PM   #16
Wrench
Lifer
Wrench's Avatar
The engine runs backwards when you drive in reverse. So no harm done.
<>< Hardcore Rock Crawling 80. Marks Crawl Box, 5.29's, 40" Iroks and now with Longfields! Yeah!
Weld it. Break it. Weld it. Break it. Rock crawling is fun.
Live Free & Wheel
R.I.P Bobby Long
Wrench is offline   Reply With Quote
Old 07-26-11, 08:13 PM   #17
excessive
excessive's Avatar
Garage
Thanks for the replies everyone, i don't feel worried about it anymore! I knew i was just being paranoid, but I am building this rig for ultimate reliability, so I wanted to make sure im not jeopardizing reliability in any way.
Old 07-26-11, 09:45 PM   #18
neoworm
neoworm's Avatar
Garage
might wanna think about that.
2003 UZJ100 ---- details and images in the garage.
neoworm is offline   Reply With Quote
Old 07-26-11, 10:21 PM   #19
Conundrum
Garage
I had a 550 Polaris snowmobile that had the engine "reverse" directions to go in reverse.
Conundrum is offline   Reply With Quote
Old 07-26-11, 10:41 PM
Sponsored Link
advertisement
Old 07-26-11, 10:41 PM   #20
cruiserdan
Parts Geek, M1 Mechanic
cruiserdan's Avatar
What?
Original owner 93 FZJ80,locked,blown,water/methanol injected(like a WWII fighter aircraft),lifted,winched,snorkeled,slidered,Sleeed ,moneypit. Balanced on a pin head. 95 FZJ80 trail truck (hers), 94 FZJ80 320K with a knock. 2009 Dodge Challenger SRT8, 465 horse HEMI, 6 speed manual trans, cop-attracting-red. Kimberly Kamper and some Garands.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
vBulletin® ©2000 - 2013, Jelsoft Enterprises Ltd.
Garage Plus, Vendor Tools vBulletin Plugins by Drive Thru Online, Inc.
©2000-2013 - Tie Rod Media, LLC - ALL RIGHTS RESERVED
