06-27-05, 02:11 PM
| | 250+ Club
| Different Size Spare? Does anyone have any thoughts either way about having the spare tire be a different size than the other 4? I have 285/75 R16’s on my Cruiser and I assume the standard spare up underneath. If I only plan to use the spare in emergency situations and may never be more that say 75 miles from somewhere to get the 285’s back on is this ok/no? Any thoughts? Anyone do this right now?
Barrypt5
__________________ '97 LX450 Locked (w/CDL switch) ~102k
ARB'd (10k T-Max Winch) - Lightforce 240 Blitz'd - Custom Rear Bumper
295/75-R16 MT RT03's OME 2.5" 850/860's - MetalTech Sliders
'04 Corolla 5spd 38mpg "on-Road Trip Rig"
"It is not the mountain we conquer but ourselves." - Sir Edmund Hillary |
06-27-05, 03:37 PM
| | Site Addict
| I wouldn't worry about it. Most car mfgs now put the little doughnut tires in as spares which are relatively much smaller than what you're talking about. And you see a lot of people driving on them at 75mph too!
__________________ Tom '97 FJZ80 CE sans the manly lockers but with the manly Kazuma SC...it blows, and it's a good thing
AirLift1000 with Load ControllerII and Slee Dashboard Beverage Restraint System
'02 MR2 Spyder
'01 Avalon
...long live the Scamp...the Scamp is gone. |
06-27-05, 04:40 PM
| | still solving problems...
__________________ a couple pairs of pink panties... Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam "...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr "I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton |
06-27-05, 05:36 PM
| | ThinkTank Waterboy
| As a "data point" let us now how long the VC lasts once the spare is mounted.
__________________ Rick Bigelow
'96 215k
Groveland MA 01834
If you're not the lead dog, the view never changes |
06-27-05, 06:03 PM
| | Forum Regular
| You'll probably end up purchasing another 285 tire to replace the damaged one. Why not have the correct one as a spare and only have to change it once?
Steve
94'
__________________ 94 FZJ80, Nitto Terra Grapplers 295's, Hanna sliders, CDL Switch, Aussie Locker, Lifted Spare, Slee front bumper, M12000 with incabin controls, Slee skid plate, OME springs/shocks, A-piller mounted aux temp gauge, Surepower battery system, Aux condensor fan, 1500 watt inverter, hand throttle, CB. |
06-27-05, 07:26 PM
| | Site Addict
| I run 295/75 and have a 255/85 for a spare. Essentially the same diameter, skinnier so it sits up higher when stored, and about $70 less than the 295.
If I trash a 295, the 255 will just be on long enough to get me to a Discount Tire. But I won't have to worry about trashing my VC.
__________________ Tim A
TLCA #2620
'97 LX-450, 163K miles SOLD to BUCKRU |
06-29-05, 01:58 PM
| | 250+ Club
| I would go to one of those used tire places and buy a used 285/75/16 or see if one of your buddies has an old one around somewhere.
should be able to get a fairly decent one for $25 or less and get it mounted for another $5 to $10
of course theres a lot of treadless baldies out there that someone might try to sell you, but as long as it holds air even a bald 285/75-16 is a better spare tire than the 275/70-16 under there now
ps - somewhere in hers's a spare tire lift (IIRC a couple washers and a longer bolt) that you might want to do, my ass is sagging pretty low to begin with, the spare tire hanging down doesnt help matters |
06-29-05, 04:32 PM
| | 250+ Club
| Sorry I'm new.  What does VC mean?
__________________ Josh '97 LX450 - Factory Lockers, CDL Switch, Pin 7 mod, Cupholder, OME HD 2.5", 285/75/16 Revo A/Ts, JK Sliders, Hanna Rear Bumper, ARB front bumper. '94 Toyota Supra Turbo |
06-29-05, 04:43 PM
| | ThinkTank Waterboy
| Viscous Coupler. There is one in the t-case. When there is a difference in the rate that the 2 driveshaft spin it begins to lock to compensate for what it thinks is wheel spin. Now with an odd ball tire on the truck the driveshafts will rotate at different speeds which will lock up the VC, however there is NO wheel spin, it is a high traction situation which can be damaging to the drive train.
'96 215k
Groveland MA 01834
06-29-05, 04:49 PM
#10 (permalink)
| | California Expatriate
| I could be pulling this out of my who who hole, but I beleive at least one auto manufacturer has had a recall since they had an undersized spare on a full time system like the US 80. The recall was due to the undersize spare creating too much heat and ruining the center diff if the spare was used. (I'm probably wrong about the recall but I'm sure their have been warnings issued by auto manufacturers to that effect)
As a mater of a fact I think my subaru has a full sized mini spare for the same reason. The spare is skinny but just as tall as the normal tires.
__________________ '97 LandCruiser (Slee bits with OME418 and SOF4RH springs; Slee step sliders; African Outback full length roof rack; ARB front bumper, Hella 4000s; Kaymar rear bumper, tire carrier, jerry can carrier; BFG AT 315/75/16 on OEM steelies)
'09 WRX STi |
06-29-05, 04:56 PM
#11 (permalink)
| | case quarter
| real world experience, not theory, you can use a different size tire for a spare, but do not lock your difs!
__________________ Eric Hagan - Auburn, AL - is up shunt creek without a paddle
94 - locked up like two dogs |
06-29-05, 05:03 PM
#12 (permalink)
| Quote: |
Originally Posted by Land Speeder real world experience, not theory, you can use a different size tire for a spare, but do not lock your difs! | How long have you been driving around like this? Also where not wondering if you can drive around with different sized tires, but rather whether it's a good idea.
Just let us know how it goes and how many miles you've driven like this. As Doug said we need some data points.
'09 WRX STi |
06-29-05, 05:04 PM
#13 (permalink)
| Also forgot to point out that 91-92s don't have a VC so you don't count
'09 WRX STi |
06-29-05, 05:35 PM
#14 (permalink)
| | case quarter
| Quote: |
Originally Posted by barrypt5 If I only plan to use the spare in emergency situations and may never be more that say 75 miles from somewhere to get the 285’s back on is this ok/no? Any thoughts? Anyone do this right now?
| I was answering the above question. That's my data point, not tryng to argue the point, because I know what I know.
"Nothing is right or wrong, but thinking makes it so"
I drove like this about 5 or so miles down the road and flexed it in an empty lot. for about 15 minutes then back. And because I've seen this topic come time and again, I decided to do tight turns in circles to see for myself, and had no problems.
I'm not saying the setup is ideal, I am just saying, by experience, it is possible.
So if I don't have a VC, and doing this messes up a VC, and someone has a VC, then they should not do this.
06-29-05, 05:57 PM
#15 (permalink)
| | She idles just fine
| I'll make the blanket statement that you should never run different diameter tires on any axle to which power is being delivered. If you follow this advice, you'll never regret it. To do otherwise invites more problems than you already have. Hey, you've already got a flat, why trash your drivetrain too? Differentiation (be it side to side or front to back) is made far more perilous when you run different diameters--not to mention it fawks up your handling and braking characteristics.
__________________ Sparkplugs are Irrelevant. 1984 BJ42; 1988 BJ73; & 1993 KZJ70
2004 R1150RT-P; 2002 GL1800A; 2000 R1150GS; 2002 KL250G; 1997 XR400R(sold to stinky); 1984 CT110; 1971 CT90K3; 1970 CT90K2; 1974 ST90 In Search of More Gubs . . . |
06-29-05, 07:42 PM
#16 (permalink)
| | Utarded
| Diesel's advice is good- for full time 4wd vehicles.
You can run different sized tires on a regular 4wd vehicle with open differentials. Example: my FJ60. You can run different sized tires on the rear (powered) axle as long as you still have an open diff. If you have an automatic locker (aussie, lock right, etc...) don't try it.
__________________ Eric, Utah operations commander- Tall Corn Cruisers.
1993 Landcruiser, 197K miles. Lifted, Locked, Slidered, Slee'd, Snork'd, Winched, bobbed. Daily driver. ROTW
1975 Piggy. Awesome edition. LPG/Petrol. |
06-29-05, 07:51 PM
#17 (permalink)
| | case quarter
| I figured that when I install my Aussie this weekend I would no longer be able to use a different size.
But since now, what have I been damaging (no sarcasm, genuinely want to knwo)? If the reason is because of a VC, and I don't have one, what else would I be damaging. When I did the real world testing, I felt no binding at all.
What happens to all the people who never check thier tire pressure and allow it to be waaaay off?
And per the VC description given earlier, what's the difference between a VC and a locked center diff? They both appear to be doing similiar things.
06-29-05, 07:54 PM
#18 (permalink)
| | Utarded
| Land Speeder, your truck (if it is indeed minus a VC) is like my FJ60 example, a traditional 4wd. Running a smaller size spare will hurt nothing, even on a powered axle.
I thought though, that 91-92's were still full time 4wd? If this is the case, do they not use a VC? Do they use some other method?
06-29-05, 07:56 PM
#19 (permalink)
| | Utarded
| Also, a VC acts like a limited slip differential in ways. It allows a certain amount of slipping between two ends of the power 'chain' before it locks up. A traditional 4wd center diff is an 'open' differential in 2wd mode, and LOCKED in 4wd mode.
In 2wd it allows as much spinning and slipping as you want to take. In 4wd, it allows zero slipping and I bet if you put your rig in 4wd and drove on pavement in circles that rear tire would chirp.
06-29-05, 08:01 PM
#20 (permalink)
| | Site Addict
| Just to clarify, part time 4wd trucks have no center differential. |
| Thread Tools | | | | Display Modes | Linear Mode |
