Old 06-11-05, 09:52 AM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
differences between 95 & 96-97 models
I've looked at many threads on this site and it seems that on late model year 1995 land cruisers there are no differences with 96 & 97 models years. Is this correct? I had originally wanted to purchase a 97 model year but here in Canada we have a 10 year rule with respect to taxes and I have to pay 21% on top of the purchase price to get the car up here. If I was to buy a 95 I can play with the black book pricing (within reason) and save alot of cash. I'm only willing to do this if the 95 is virtually idential to 96-97 years. Can anyone confirm the differences. I need lockers,new dash style,leather and all the trimmings
If I'm getting the same options I would rather go for the 95 and try to find one with lower miles 50-70 k, as I will pay less for it. What are the going prices right now for a 95 in excellent cond.
If anyone can enlighten me on the differences above I would really appreciate it
skunkworks is offline   Reply With Quote
Old 06-11-05, 10:15 AM   #2 (permalink)
NorCalDoug's Avatar
TLCA# yes, I have one
No mechanical differences between 1995, 1996 and 1997 80 series Land Cruisers.
There are some cosmetic (i.e. badging) differences between the model years, but nothing to really be concerned about.
Welecome aboard
a couple pairs of pink panties...
Another convert to the Church of Latter Day Swank, a sub-cult of Shahrislam
"...Opportunity doesn't knock, you have to kick the fuckin door in and drag the bitch out screamin." -- Ullr
"I have more respect for people who change their views after acquiring new information than for those who cling to views they held thirty years ago. The world changes. Ideologues and zealots don't." - Michael Crichton
NorCalDoug is offline   Reply With Quote
Old 06-11-05, 10:17 AM   #3 (permalink)
Riley's Avatar
I think the major difference is the OBD. The 96 is OBD-2 but the 95 isn't full OBD-2 compliant. It's like 1.5 or something.
Other than that, I think they are about the same. I like my 95.
95 locked FZJ80 - 851/860, Outback rack, MTRs & sliders.
06 IS250 - 6 speed manual, RWD
Riley is offline   Reply With Quote
Old 06-11-05, 10:20 AM   #4 (permalink)
PACNW96's Avatar
From Sleeoffroad web site:
1995-1997
1996 saw the introduction of the Lexus LX450 Model.
Exhaust system changed from side by side catalytic converters to in-line converters. The exhaust also routes below the frame rail just behind the catalytic converters to avoid excessive heat on the passenger floor-boards.
Front grill changed from the word TOYOTA written across the front to the new Toyota symbol.
Headlight mounts are different from 1991-1994 vs 1995-1997 and will not interchange.
Redesigned dash board with airbags as standard equipment.
Headliner changed to two piece molded units.
Emission system on engine changes. Changed from a Mass Air Pressure meter to a Mass Air Flow meter. Certain plumbing was also removed.
Supercharger & Turbo systems available for 1995-1997 models.
ECU updates and truck became voluntary OBD-II compatible. Fully compatible in 1996 models.
Wheel Lug nuts change from conical to washer type.
Airbags become standard
Automatic transmission changes to the A343F. Some 95's were produced with the A442F. The transmission type is printed on the label on the driver door.
1997 saw the introduction of the 40th Anniversary editions as well as the Collectors Series.
1997 the rear swaybar brackets that attach the bar to the frame were changed from a plate side that attached to the side of the frame to a bracket style that attached to the bottom of the frame.
ABS wires on the front were moved upward and no longer run down the front control arm.
Radiator is a 2 row aluminum
Good luck,
Russell
96' FZJ80 - Moonglow/Grey Interior, ARB Bull Bar, OME 850/860, Slee Blue Bushings, 285/75/16 Nitto's, Speedo Gear, CDL, Hella 500 Fogs, Toshiba HIR's, Silicone PHH - Baselined
- Purchased from original owner @ 77K-(12/04)
04' WRX, Modified - 292HP/319LB-FT
"Phil 4:3-8"
PACNW96 is offline   Reply With Quote
Old 06-11-05, 10:42 AM   #5 (permalink)
NorCalDoug's Avatar
This would be the only significant difference between a 95/96 and a 97 model listed above. The rest were differences between 93/94 and 95-97 models.
Old 06-11-05, 11:02 AM   #6 (permalink)
Thanks NorCalDoug and everyone for the replies.
Concerning the trannies are they both equally good. Also the third seat row was available right. I bought a 1997 land cruiser dealer sales catalogue and I'm looking at the standard equipment...its pretty impressive
Now I just have to find one. I was thinking about buying one in FL and driving it up.... I have easy access to rigs in any of the the northern states including and east of Ohio,NY,VT etc... Any of the markets softer than others.
How much should I be looking to pay for a low mile 95.
Old 06-11-05, 11:52 AM   #7 (permalink)
PACNW96's Avatar
Both transmissions are great, but everyone on this board has their opinion which is better. The later transmission has 2nd gear start option, but it's been discussed the earlier transmission is more heavy duty....do some research on this forum and you will see many opinions.
As you will find prices will fluctuate wildly from location to location. In Washington there are a couple low mileage 96' and 97's in the Autotrader going for between 17k-19k, which is quite expensive. Check out Autotrader.com to get an idea of prices in various locations.
"Phil 4:3-8"
Old 06-11-05, 01:19 PM   #8 (permalink)
Supamod
Gumby's Avatar
TLCA# 5658
Garage
The smaller transmission is highly desirable, because that's what I have. Bigger is not always better, look at Junk's momma. There is a mid-year changeover. I'm not sure which month it was, mine is a 7/95 with the later trans.
The 95 is not fully OBD-II compliant. That's really the only other difference I have been able to find 95-97. It looks like all the monitors are there, but I have not been able to get some info on the scan tool I should be on a 96.
Lower mileage trucks go WAY up in price. A well maintained 130K is not very scary and can be had for 2/3 the price of a sub-80K rig. ($10K vs. $15K)
I was talking to a re-seller who does a lot of LCs. He sells a lot from up here and ships them down south.
Gumby is offline   Reply With Quote
Old 06-11-05, 02:31 PM   #9 (permalink)
General's Avatar
What about the exhaust??
Interesting thread....I heard (and read in one off-road tech article) that the '97 has a stainless steel exhaust. I have not been able to verify it though.....
General is offline   Reply With Quote
Old 06-11-05, 11:45 PM   #10 (permalink)
Bear80's Avatar
TLCA# 14779
There is a difference in the springs and heights of the springs. The front springs on a '95 are shorter than that of a '97. The rear depends on god knows what.
Just thought I'd add this here, but I'm going to start a new thread about the diff in springs.
40th FZJ80 - Range Rover Recovery Vehicle
Alamo City Land Cruisers
-Benjamin-
Bear80 is offline   Reply With Quote
Old 06-12-05, 10:39 AM   #11 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
TLCA# 11332
Not restricted to 97 and not a non-ferrous stainless, IE they still get a surface corrosion.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
Old 06-12-05, 04:53 PM   #12 (permalink)
OZCAL's Avatar
Welcome Skunkworks
Is that a Lockheed reference?
Guys are there differences between Canadian models and US models? I know there are all sorts of differences between US and OZ trucks in the same model year.
David
'97 80
'97 LX 450
OZCAL is offline   Reply With Quote
Old 06-12-05, 08:35 PM   #13 (permalink)
cruiserdan's Avatar
TLCA# 11332
Canada never got new 80 series "Land Cruisers" only Lexus LX 450's
That is a bit of a pay-back because we never got BJ70's....
Old 06-13-05, 07:38 AM   #14 (permalink)
aamiggia's Avatar
All of the CDN LX450's came with factory lockers. I think the only option was the roof rack, rear wind deflector, and the tow hitch. Oh, and the over priced built-in cell phone.
Also, all CDN models have daytime running lights.
We're one ahead because we also never got the 100 series
"The REVOLUTION will not be televised!"
TLC Dreaming
1987 Suzuki Samurai LWB TDI (project)
1998 BMW M3 (dd)
aamiggia is offline   Reply With Quote
Old 06-13-05, 08:49 PM   #15 (permalink)
yes
Old 06-13-05, 11:17 PM   #16 (permalink)
northerner
semlin's Avatar
Dan strictly speaking I don't think you americans have ever had any BJs at all.
Which is a shame
in more ways than one
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
64, 2x65 honda ct 200
67, 2x68, 3x69, 72, 75 Honda ct90
83 Honda ct70
48 Ferguson TE20
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
wfc 4812-2635-4880
semlin is offline   Reply With Quote
Old 06-13-05, 11:54 PM
elum
This message has been deleted by elum. Reason: stupid...
Old 05-27-07, 09:15 AM   #17 (permalink)
Really? I could have sworn that I've seen canadian lx's w/o factory lockers...
1976 FJ40. I never should have sold it...
1986 HJ60. Same Fate, Same Regret...
1995 FZJ80. 140k, Locked, CDL button, pin 7, 285's <FORCED TO SELL> Looking for another, this time for good!!
arbetrader is offline   Reply With Quote
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/48190-differences-between-95-96-97-models.html
Posted By For Type Date
Noob needs info on LC's - TTORA Forum This thread Refback 07-17-08 05:33 AM
Noob needs info on LC's - TTORA Forum This thread Refback 07-15-08 10:25 PM
