Old 01-11-09, 06:51 PM   1 links from elsewhere to this Post. Click to view. #61 (permalink)
Lil' runnah's Avatar
Location: Savannah, Ga ...currently in Kandahar, Afghanistan
TLCA# 19480
thanks Nakman, I think that's about my only option now; to just upgrade the flasher and change all the bulbs.
In my post, I stated that the fuse has never blown... flasher just buzz's
I don't see a need for blinkers in the bumpers anyway so I am going to set it back to stock with new bulbs all around. Hell, I think im going to modify the Kaymar and weld plates in place of those lights anyway and form the sides to look better.
any idea how much the HD flasher costs? THe stock one from the dealer is over $50
06 4Runner V8 4WD-Shrockworks front bumper/custom rear bumper/Stubbs' sliders/King front and rear/Ramsey 8k winch/dual batts/34" MTR's
94 Landcruiser-3x locked/4:88's/35's/SLee 6"/part-time 2wd conversion/aux fuel tank/ARB front/Kaymar rear/dual batts/Snorkel/Warn 10k winch/Metaltech sliders
Lil' runnah is offline   Reply With Quote
Old 01-11-09, 08:48 PM   #62 (permalink)
addict.
nakman's Avatar
Way less than that, closer to $15-$20, iirc.
96fzj80, mostly stock except for the suspension, steering, gears, brakes, batteries, lights, bumpers, running boards, skid plates, stereo, speakers, cargo area, and tires. Also a 2001 Taco DC.
custom 80 series mic holders, dash bezels, seat repair parts, and clear ARB lenses, all available right now, right here www.gamiviti.com
and some of my best friends are TLCA members.
nakman is online now   Reply With Quote
Old 01-13-09, 08:07 PM   #63 (permalink)
TLCA# 19480
can someone PLEASE tell me where the "converter" is that some of you mentioned in earlier posts?
I swapped in the EP34 with the jumper from the oem flasher ....no change, just bzzzzzzzzzzzzzzzzzzz!!!!!!!!!!!!(when I try to turn on a turn signal)
This flasher works fine for the Hazards ...all 4 corners blink, the same flasher just doesn't work for turn signals. WTF!?
Old 01-13-09, 09:26 PM   #64 (permalink)
ppc
ppc's Avatar
If you have access to a multi-meter, check the current passing through the flasher when powered. Also check resistance to ground when off. Current should be half the value as compared to the 4-way flasher. To me it sounds like you have a dead short somewhere. Because the flasher is making/breaking the circuit at a high rate of speed there is not enough current continuously passing to blow the fuse. It could be a bad bulb, bad socket or bad wiring.
Phil
Supercharged 94
ppc is offline   Reply With Quote
Old 01-13-09, 10:30 PM   #65 (permalink)
TLCA# 19480
thanks PPC, that makes more sense than anything so far. I'll give it a try tomorrow.
I just changed all 4 bulbs and of course, no change in scenario.
I supplied an alternate 12v source to the fuse and same result so I think I can rule out the switch on the column. I know the bulbs are good and the flasher itself is good.
I think maybe your on to something with the short somewhere.
Now that I know the flasher is good, my digressing has turned into a hi-jack of this thread, my apologies ....back to the upgrade discussion
LinkBack to this Thread: http://forum.ih8mud.com/80-series-tech/44790-heavy-duty-flasher-upgrade.html
Posted By For Type Date
Flasher/Blinker help please! - Toyota 120 Platforms Forum This thread Refback 01-13-09 09:01 PM
electrical challenge - flasher issues? - Rising Sun Member Forums This thread Refback 09-03-08 08:27 AM
