Old 05-11-05, 12:38 PM   #31 (permalink)
Parts Geek, M1 Mechanic
cruiserdan's Avatar
TLCA# 11332
Originally Posted by Biff
So whats the difference between the J springs and the heavies?
The J's are taller, about an inch I think.
http://i487.photobucket.com/albums/r...Gastrap063.jpg
http://i487.photobucket.com/albums/r...frifles004.jpg
Old 05-11-05, 12:46 PM   #32 (permalink)
Montana Cruiser's Avatar
Originally Posted by e9999
so basically, if the rates are linear and the same for both heavy and med, and the springs are linear, that would mean that there should be no difference whatsoever dynamics wise between a heavy and a med+spacer the same length, right?
How about sturdiness, stability etc?
This is exactly what I'm getting from reading this ..... however, this would not explain why people with heavies and light additional weight experience a rougher ride. So either this theory is flawed or the people with the heavies and rough ride are "feeling" something thats not there?
2000 4Runner Sport Edition PP 1" Lift Coils / 32" Tires / Norcold / RTT / ARB coming soon!
SOLD! 97' FZJ80 "Junior" Black/ARB winch bar/OEM Lockers
Montana Cruiser is offline   Reply With Quote
Old 05-11-05, 12:46 PM   #33 (permalink)
shocker's Avatar
TLCA# 10895
Think that was covered in post #19
Originally Posted by Shocker
All these springs probably lift the vehicle their stated height if you have the weight on your cruiser that they are rated for. In other words, add 200 - 300 lbs. to the back of a cruiser with heavy springs and it will probably sit at the same height as the mediums without the extra weight.
J spings would sit an inch higher than the heavies with the same weight.
shocker is offline   Reply With Quote
Old 05-11-05, 01:07 PM   #34 (permalink)
Originally Posted by semlin
we really need an engineer on this thread but here's another comment from a guy with no physics after grade 10.
is arb saying the springs are physically identical except one is longer or are they saying that the springs are physically different so that, even though one is longer, they both have the same load bearing capacity. I think they are saying identical but longer.
assume you have two springs of exactly the same construction but one is longer than the other. Wouldn't the longer spring have a greater weight bearing capacity? under the same load, wouldn't the shorter spring be more compressed in normal operation? I am assuming every spring has an optimum load rate at which further compression diminishes the responsiveness of the spring. I think the longer identical spring will have a higher optimum load rate.
Conclusion? I think heavies are better for more load/weight. How much better I don't know. If you just want to cure stink bug, then spacers may be more appropriate.
I would suspect that the heavies are comprised of material of a lower tensile strength in order to have the same Lbs/inch rating, if you remember that cutting a spring down increases its Lbs/inch rate!
1994 HDJ80 1HD - T Lockers CDL switch & 7pin mod 100 Front Pads Nato Pint Swivle Tow Hook
Gold Finger is offline   Reply With Quote
Old 05-11-05, 01:13 PM   #35 (permalink)
I have that arse about tit I mean a Higher tensile stength
Old 05-11-05, 01:27 PM   #36 (permalink)
davisdrafting's Avatar
To simplify things you’ll have less space between
your spring coils using short springs+shims compared
to longer springs of the same rate and the same amount
of weight.
What does this mean, simply you’ll have less compression
travel with springs+shims i.e. less space between coils.
91 FJ80
OME J's
Custom Spacers
33” Geo-Landers
110AC
DeSmog, No Cat’s
Flow Master 3"in, dual 2.5" out through bumper
H41 4spd
Manual TC
davisdrafting is offline   Reply With Quote
Old 03-21-06, 11:23 PM   #37 (permalink)
tech_dog's Avatar
If I'm reading this, the person from ARB that provided the info got the model numbers backwards. That hardly installs confidence.
There has to be someone who has both heavy and medium in their garage. Can someone rig them up to measure them, load them up with 100 lbs, and then measure them again? That would settle this once and for all.
1994 FZJ80 - Original Owner, dual battery, 2.5" OME Heavy/Medium, 295/75/16 Terra Grapplers, Slee front and rear bumpers, dimmable Lightforce 170s, Hanna Sliders, Slee transfer case skid plate, Warn 9.5XP, LED interior lights, Slee interior spare tire carrier, yellow box, orange dot mod
2006 LX470 - Original Owner, Daily Drive, no mods
tech_dog is offline   Reply With Quote
Old 03-21-06, 11:51 PM   #38 (permalink)
sc40's Avatar
man this thread is good, but let me get this right,
j's with load siit one inch above heavies with the same load.
and heavies sit one inch above med. with the same load.
right?
"I understand the J**P thing, thats what i drive a toyota"
'94 FZJ-80 - In dash GPS, TJM, 285's, OME lift.
'77 FJ-40 - Frame off restoration, close to stock
sc40 is offline   Reply With Quote
Old 03-21-06, 11:57 PM   #39 (permalink)
SR.GRINGO's Avatar
So I'm running the same height as J's with the heavies and two trim packers on each spring?
94 Locked, 4.88's, snorkel, York, new HG, sliders, Mot's grab bar, corbeau seats
SR.GRINGO is offline   Reply With Quote
Old 03-22-06, 07:56 AM   #40 (permalink)
always broke
alkaline747trio's Avatar
Here is what I am gathering from this..
Mediums: 2.5" lift no load
Heavies: 3.5" lift no load, 2.5" lift loaded 200#
J's: 4.5" lift no load, 3.5" lift loaded 200#, 2.5" lift loaded 400#
Sound about right?
What?
Upstate Cruisers
alkaline747trio is offline   Reply With Quote
Old 03-22-06, 08:01 AM   #41 (permalink)
You want to do what...?
e9999's Avatar
my 863s got me 4" of lift with truck empty.
A bunch of recovery stuff in the back, I'd say at least 200 lbs, more like 300 lbs gave a 1/2" drop. A trailer in the back did about the same.
Ride is just fine and it's great to have the extra clearance and not drag the butt any more. Need to adjust LSPV but trivial and there is a bit of rake when unloaded but I don't care. Sure glad I went with 63s and not meds...
: '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
: '03: 115K
DDs: Accord, Prius
: souped-up DR650
Old 03-22-06, 09:05 AM   #42 (permalink)
cruiserdan's Avatar
TLCA# 11332
Sound about right?
No.
Old 03-22-06, 09:24 AM   #43 (permalink)
nickw's Avatar
So I wonder what springs I should get? Can anyone help?
I was thinking Heavy/heavy.
Up front:
ARB bumber
Warn M8000
Back:
big roof rack
rear ladder
tire carrier and 258/75/16 BFG AT
plus I carry about 100-150lbs of gear.
Getting:
Sliders (as soon as I make em)
Rear drawer system (as soon as I make it)
I was thinking heavy/heavy but mayne I should get heavy/J's?
Thanks,
Nick
1988 BJ74 / Lots of goodies - Sold
1990 HDJ81 / Fully outfitted loaded beautiful truck - Rolled
1985 BJ60 / Beautiful Stock truck - Stolen
nickw is offline   Reply With Quote
Old 03-22-06, 09:36 AM   #44 (permalink)
Admin
woody's Avatar
TLCA# 1548
Garage
I run heavy fronts and medium rears (with BroncoII-IIRC bags for towing/loading times - deflated for daily use)
Front has an ARB and a 10k T-Max winch. Std OME lift length shocks all around, caster bushings (installed with Slee's kewl little press dealio).
Prior to the winch/bumper and while running med/med's, it rode a little rough...with the added weight and the heavy/med setup, I'm quite pleased with the daily ride. There is minimal rake as well, sits close to level.
sliders are coming, but that weight is centered and won't effect rake...
Brian 'woody' Swearingen
Owner, IH8MUD.com
Owner, ROCKCRAWLER.com
Forum Questions? Click Here! .. .. .. .. 2009 IH8MUD Wheelin Schedule!
'America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.' Abraham Lincoln
'Everyone wants to save the porpoises, but no one cares about the tuna'
woody is online now   Reply With Quote
Old 03-22-06, 09:56 AM   #45 (permalink)
always broke
No.
Then correct me...
What?
Upstate Cruisers
Old 03-22-06, 10:04 AM   #46 (permalink)
cruiserdan's Avatar
TLCA# 11332
Then correct me...
Search my friend, search.....
An un-loaded 864 lifts about the same ammount as an unloaded 863J (both of which are about an inch or so heigher than an 863). It takes twice the weight to lower 864's to any given height as it takes to lower 863J or 863.
I would not run 864's unless you pack a lot of extra weight all the time.
Read this thread:
http://forum.ih8mud.com/80-series-tech/69927-js-up-front-heavy-rear.html
Old 03-22-06, 10:14 AM   #47 (permalink)
Hayes's Avatar
TLCA# 15907
We're talking 850 vs. 851 here.
We also seem to be operating under the (logical) assumption that 860 and 863 have the same rate (just like the front), but this has not been explicitly stated.
Anyone?
I think davis drafting (post #36) hit on the only difference between 850 and 851 with spacers. You'll have slightly less travel with the 851+spacer setup compared to the longer 850. But I bet the difference is negligible.
I guess it would depend on the number of coils in the spring. (More coils would "bottom out" sooner)
Springs are interesting things.
My physics go thru college, but I doubt I have a better understanding than everyone else here.
My understanding of springs, as I think through this question:
Per length of coiled spring,
More coils = less deflection per unit of compression = less force to compress = softer spring.
Fewer coils = more deflection per unit of compression = more force to compress = harder spring.
To make the 850 taller than the 851 OME would have to either add more coils, "stretch" the spring, or a combination of both. I would guess that a combination of both would be needed to keep the same spring rate. This would probably also net no change in travel between maximum compression and unsprung length?
Of course, this ignores the effect of different materials in the springs.
Just thinking out loud here.
Hayes
P.S. I haven't had the opportunity to compare the ride of 850/863 vs 851/860, but with a light rear end, the bumps are a bit harsh under the rear axle.
Hayes
Hayes is offline   Reply With Quote
Old 03-22-06, 10:20 AM   #48 (permalink)
cruiserdan's Avatar
TLCA# 11332
From Beo...........
Originally Posted by Beowulf
OME Springs:
General rules:
unladen 864=5" lift or 2" w/400 kg load (20mm wire)
....... 863=4" lift or 2" w/250 kg load (19mm wire)
....... 860=2" lift or 1.75" w/a gas tank (18mm wire)
....... 850=2" lift w/some weight(dual batteries etc)
....... 851=2" lift w/bar & winch, dual batteries, etc
....... Stock springs 16mm wire.
Spring......bar...free.......nbr.....coil......spr ing
number......dia...height....coils....weight....rat e (lbf/in)
..................DS..PS
Front
850.........17mm..495/505mm..9.8.....7.3kg......220 lbf/in
850J........17....515/525....9.8.....7.3........220
851.........17....475/485....9.8.....8.1........220
861.........16....480/490...10.4.....7.0........220
Rear
860.........18....480/490....8.3.....8.1........220
862.........17....460/470....9.0.....8.0........240
863.........19....480/490....8.3.....9.2........250
863J........19....505/515....8.3.....9.2........265
864.........20....480/490....8.3....10.3........320
Spring...bar...free ht...# of...coil....spr rate
number...dia....DS/PS....coils..weight..(lbf/in)
850......17mm..495/505mm..9.8....7.3kg....220
850j.....17....515/525....9.8....7.3......220
851......17....475/485....9.8....7.3......220
861......16....480/490...10.4....7.0......220
860......18....480/490....8.3....8.1......220
862......17....460/470....9.0....8.0......240
863......19....480/490....8.3....9.2......250
863j.....19....505/515....8.3....9.2......265
864......20....480/490....8.3...10.4......320
OME shocks
............. Open ......... Closed
............ length ........ length
N70 ......... 614 .......... 354
N71E ........ 620 .......... 370
N74E ........ 620 .......... 370
N73 ......... 614 .......... 354
N73L ........ 667 .......... 387
N74L ........ 667 .......... 387
I see there are a couple of minor discrepancies. As I recall, I got these from 2 different sources.
-B-
Old 03-22-06, 10:34 AM   #49 (permalink)
Hayes's Avatar
TLCA# 15907
There's the info right there.
860 and 863 have different spring rates.
That would verify the harsh feeling with a light rear end.
I guess the higher spring rate of the 863's are responsible for the increased ride height rather than the longer spring in the 850 - 851 comparison.
Hayes
Old 03-22-06, 03:38 PM   #50 (permalink)
Bruneti's Avatar
850's would have the advantage of no spacers to fail or flatten.
851's + spacers has the advantage of lower cost if you already own the springs and don't mind risking a spacer failure and it's fairly low cost replacement.
If you don't own either set yet, I believe several people have run the 850f/860r combo successfuly with a stock bumpered rig and been level without any spacers. I'm sure every rig differs a bit, so there may be no perfect answer.
CDan - Thanks for re-posting the spring info that Beo had put together. Does anyone know the spec's on Slee's 4" lift and how it fits into all of that info? I would love to know the spring rates that are used on his 4" kit, but haven't asked to see if it's "confidential" or not.
1996 LX450 w/ factory lockers, Optima Red Top, HIR 9011 Hi & Low Beams, OME 850J/863, Slee Blue CC Bushings, Bilstein HD Shocks, ARB winch-bar, 295/75/16 Terra Grapplers, yellow box speedo correction, LED domes, CDL switch w/pin 7 mod.
Bruneti is offline   Reply With Quote
Old 03-22-06, 04:10 PM   #51 (permalink)
XXXR's Avatar
And finally... when I do run the ARB Bullbar and add the 10mm spacers... how does this throw off the caster? What about alignment? I'm also running light springs in the front. (851's)
XXXR is offline   Reply With Quote
Old 03-22-06, 04:46 PM   #52 (permalink)
northerner
semlin's Avatar
xxxr your questions are really for another thread. stock caster varies on 80s as does the impact of bumpers and spacers between trucks. The short answer is that once you do it you will need to have your resulting caster measured then proceed accordingly. if you are very paranoid have your stock caster measured and we can then make an educated guess of the impact but it would be such a guess that I would not waste my money.
93 fzj80
66 fj40L
m101cdn trailer
91 LS400 sedancruiser
64, 2x65 honda ct 200
67, 2x68, 3x69, 72, 75 Honda ct90
83 Honda ct70
48 Ferguson TE20
"Diplomacy is the art of having someone else impose your will on you" Lester Pearson
"I have the conch" Piggy
wfc 4812-2635-4880
semlin is offline   Reply With Quote
Old 03-24-06, 09:34 AM   #53 (permalink)
XXXR's Avatar
I'm running the 2.5 lift with the caster correction bushings... I just wondered if the spacers would raise the front enough for it to be an issue, or if the Bar would sink it enough to return to it's proper height. I ordered a set, as I plan on a bar next year.
You're right though, this is a specific that relates to caster and not just spring height.
Old 03-28-06, 02:57 PM   #54 (permalink)
XXXR's Avatar
So... ya'll think I need the spacers with an ARB Bull, winch ready, but no winch uninstalled?
I purchased a set of 1.25 (I think, I know they are just over an inch from Man O Fre) spacers for when I add the Bull. I was looking forward to leveling the rig out anyway, but I don't want to run with the rear squat either. Anyone run this?
THANKS!
Old 03-29-06, 09:41 AM   #55 (permalink)
dmc
dmc's Avatar
TLCA# 11141
A good reference page since ARB's site is less than stellar...
OME spring rates
I won't get into what everyone should run on their truck. My preferred set up is J's up front and 863s in the rear. Sat level and rode great. Don't ask why I don't run it anymore. i'm dumb.
dmc
dmc is offline   Reply With Quote
Old 03-29-06, 11:07 AM   #56 (permalink)
Supporting Vendor
frankies off road's Avatar
two diffrent springs of the same rate one being longer,the longer spring will still have a stiffer rate because there will be more coils for compresion,coil spring gain rate as the coils are compresed.so more coils to compress more actual spring rate.
frankies off road is offline   Reply With Quote
Old 03-29-06, 04:41 PM   #57 (permalink)
ed97fzj80's Avatar
TLCA# 15645
dmc
What shocks did you use -- Ls up front and ordinaries in the back?
ed97fzj80 is offline   Reply With Quote
Old 03-29-06, 05:43 PM   #58 (permalink)
dmc
dmc's Avatar
TLCA# 11141
I ran regular OME shocks front and rear. I now have J's all around with spacers up front and L shocks. If my truck isn't loaded all the time it rides like a rock. I sold that set up to someone else thinking I wanted to run 315s. now i'm not so sure i made the right choice.
dmc
Old 03-29-06, 09:00 PM   #59 (permalink)
MoJ
MoJ's Avatar
TLCA# 14112
I ran regular OME shocks front and rear. I now have J's all around with spacers up front and L shocks. If my truck is loaded all the time it rides like a rock. I sold that set up to someone else thinking I wanted to run 315s. now i'm not so sure i made the right choice.
dmc
dmc -
Thanks for mentioning that. I have medium all around right now with MR G up front. I have the J's springs sitting in my garage but thinking I would end up just using them on the front and either keep the 860 rears or go for some 863s. I've been thinking about keeping the regular OME shocks in. I guess the only drawback would be not gaining any droop.
MoJ is offline   Reply With Quote
Old 03-29-06, 09:43 PM   #60 (permalink)
cruiserdan's Avatar
TLCA# 11332
850J/864 and standard shocks here. I have not felt the need for L shocks with this setup. Bear in mind that the extra drop costs you compression and the net total travel remains about the same.
